Directory Problem
HI all
i have a customer that become a new UCME System. I configured it bu i get all things working but the directory Services not.
Requesting Requesting and @ the End Host not found .....
I have tried many ways with telephonys-service commands and so on but nothing work .
Can some one Help me ?
Here my config
Last configuration change at 12:59:53 UTC Fri Aug 24 2012 by admin
! NVRAM config last updated at 13:06:36 UTC Fri Aug 24 2012 by admin
version 15.1
hostname ucme
boot-start-marker
boot-end-marker
card type e1 0 0
logging buffered 51200 warnings
no aaa new-model
network-clock-participate wic 0
no ipv6 cef
ip source-route
ip cef
ip dhcp excluded-address 172.16.0.0 172.16.1.10
ip dhcp excluded-address 172.16.1.110 172.16.255.255
ip dhcp pool Telefonie
   network 172.16.0.0 255.255.0.0
   default-router 172.16.1.1
   option 66 ip 172.16.1.1
   option 150 ip 172.16.1.1
   dns-server 172.16.1.1
   domain-name xxx
ip domain name xxx
ip host ucme 172.16.1.1
stcapp ccm-group 1
stcapp
stcapp supplementary-services
port 0/1/0
  fallback-dn 129
port 0/1/1
  fallback-dn 77
port 0/1/2
  fallback-dn 61
isdn switch-type primary-net5
crypto pki trustpoint TP-self-signed-410002068
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-410002068
revocation-check none
crypto pki certificate chain TP-self-signed-410002068
certificate self-signed 01 nvram:IOS-Self-Sig#1.cer
voice-card 0
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
sip
  registrar server expires max 3600 min 3600
  no update-callerid
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice register global
mode cme
source-address 172.16.1.1 port 5060
authenticate register
voice translation-rule 1
rule 1 /^/ /00\1/ type national national
rule 2 /^/ /000\1/ type international international
voice translation-rule 2
rule 1 /140/ /141/
voice translation-rule 3
voice translation-profile BM_to_VZ
translate called 2
voice translation-profile Eingehend
translate calling 1
voice translation-profile VOICE_SECURITY_AUDIT_BLOCK
translate called 3
license udi pid CISCO2921/K9 sn FCZ162420AC
hw-module ism 0
hw-module pvdm 0/0
username admin privilege 15 secret 5 $1$hfoD$oHMLRxU4esq6EZH2/X32k0
username adg password 0 1234
redundancy
controller E1 0/0/0
pri-group timeslots 1-28
ip tftp source-interface GigabitEthernet0/0.100
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
no ip address
duplex auto
speed auto
description DATA-VLAN
encapsulation dot1Q 1 native
ip address 192.168.2.1 255.255.255.0
description VOICE-VLAN
encapsulation dot1Q 100
ip address 172.16.1.1 255.255.0.0
interface ISM0/0
ip unnumbered GigabitEthernet0/0.1
ip virtual-reassembly in
service-module ip address 192.168.2.2 255.255.255.0
!Application: CUE Running on ISM
service-module ip default-gateway 192.168.2.1
interface ISM0/1
no ip address
shutdown
interface GigabitEthernet0/1
duplex auto
speed auto
interface GigabitEthernet0/2
description $ES_LAN$
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn sending-complete
no cdp enable
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http path flash0:/GUI
ip dns server
ip default-network 192.168.1.0
ip default-network 192.168.2.0
ip route 172.17.0.0 255.255.0.0 172.17.1.1
ip route 192.168.2.2 255.255.255.255 ISM0/0
tftp-server flash0:phone/7942-7962/apps42.9-2-1TH1-13.sbn alias apps42.9-2-1TH1-13.sbn
tftp-server flash0:phone/7942-7962/cnu42.9-2-1TH1-13.sbn alias cnu42.9-2-1TH1-13.sbn
tftp-server flash0:phone/7942-7962/cvm42sccp.9-2-1TH1-13.sbn alias cvm42sccp.9-2-1TH1-13.sbn
tftp-server flash0:phone/7942-7962/dsp42.9-2-1TH1-13.sbn alias dsp42.9-2-1TH1-13.sbn
tftp-server flash0:phone/7942-7962/jar42sccp.9-2-1TH1-13.sbn alias jar42sccp.9-2-1TH1-13.sbn
tftp-server flash0:phone/7942-7962/SCCP42.9-2-1S.loads alias SCCP42.9-2-1S.loads
tftp-server flash0:phone/7942-7962/term42.default.loads alias term42.default.loads
tftp-server flash0:phone/7942-7962/term62.default.loads alias term62.default.loads
tftp-server flash0:phone/7915/B015-1-0-4.SBN alias B015-1-0-4.SBN
tftp-server flash0:GUI/admin_user.html
tftp-server flash0:GUI/admin_user.js
tftp-server flash0:GUI/CiscoLogo.gif
tftp-server flash0:GUI/CME_GUI_README.TXT
tftp-server flash0:GUI/Delete.gif
tftp-server flash0:GUI/dom.js
tftp-server flash0:GUI/downarrow.gif
tftp-server flash0:GUI/ephone_admin.html
tftp-server flash0:GUI/logohome.gif
tftp-server flash0:GUI/normal_user.html
tftp-server flash0:GUI/normal_user.js
tftp-server flash0:GUI/Plus.gif
tftp-server flash0:GUI/sxiconad.gif
tftp-server flash0:GUI/Tab.gif
tftp-server flash0:GUI/telephony_service.html
tftp-server flash0:GUI/uparrow.gif
tftp-server flash0:GUI/xml-test.html
tftp-server flash0:GUI/xml.template
tftp-server flash0:music-on-hold.au
tftp-server flash0:ringtones/Analog1.raw alias Analog1.raw
tftp-server flash0:ringtones/Analog2.raw alias Analog2.raw
tftp-server flash0:ringtones/AreYouThere.raw alias AreYouThere.raw
tftp-server flash0:ringtones/AreYouThereF.raw alias AreYouThereF.raw
tftp-server flash0:ringtones/Bass.raw alias Bass.raw
tftp-server flash0:ringtones/CallBack.raw alias CallBack.raw
tftp-server flash0:ringtones/Chime.raw alias Chime.raw
tftp-server flash0:ringtones/Classic1.raw alias Classic1.raw
tftp-server flash0:ringtones/Classic2.raw alias Classic2.raw
tftp-server flash0:ringtones/DistinctiveRingList.xml alias DistinctiveRingList.xml
tftp-server flash0:ringtones/Drums1.raw alias Drums1.raw
tftp-server flash0:ringtones/FilmScore.raw alias FilmScore.raw
tftp-server flash0:ringtones/HarpSynth.raw alias HarpSynth.raw
tftp-server flash0:ringtones/Jamaica.raw alias Jamaica.raw
tftp-server flash0:ringtones/KotoEffect.raw alias KotoEffect.raw
tftp-server flash0:ringtones/MusicBox.raw alias MusicBox.raw
tftp-server flash0:ringtones/Piano1.raw alias Piano1.raw
tftp-server flash0:ringtones/Piano2.raw alias Piano2.raw
tftp-server flash0:ringtones/Pop.raw alias Pop.raw
tftp-server flash0:ringtones/Pulse1.raw alias Pulse1.raw
tftp-server flash0:ringtones/Ring1.raw alias Ring1.raw
tftp-server flash0:ringtones/Ring2.raw alias Ring2.raw
tftp-server flash0:ringtones/Ring3.raw alias Ring3.raw
tftp-server flash0:ringtones/Ring4.raw alias Ring4.raw
tftp-server flash0:ringtones/Ring6.raw alias Ring6.raw
tftp-server flash0:ringtones/Ring7.raw alias Ring7.raw
tftp-server flash0:ringtones/RingList.xml alias RingList.xml
tftp-server flash0:ringtones/Sax1.raw alias Sax1.raw
tftp-server flash0:ringtones/Sax2.raw alias Sax2.raw
tftp-server flash0:ringtones/Vibe.raw alias Vibe.raw
tftp-server flash0:ringtones/ClockShop.raw alias ClockShop.raw
tftp-server flash0:ringtones/Drums2.raw alias Drums2.raw
tftp-server flash0:ringtones/Ring5.raw alias Ring5.raw
tftp-server flash0:CME-locale-de_DE-German-8.8.2.4.tar
control-plane
voice-port 0/0/0:15
translation-profile incoming Eingehend
cptone DE
timeouts interdigit 4
bearer-cap Speech
voice-port 0/1/0
cptone DE
timeouts ringing infinity
caller-id enable
voice-port 0/1/1
cptone DE
caller-id enable
voice-port 0/1/2
cptone DE
caller-id enable
voice-port 0/1/3
cptone DE
caller-id enable
sccp local GigabitEthernet0/0.100
sccp ccm 172.16.1.1 identifier 1 version 7.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
registration timeout 3
keepalive timeout 3
connect interval 3
switchback method graceful
dial-peer cor custom
name AUSGESPERRT
name EINERLAUBT
dial-peer cor list Telefonnetz
member AUSGESPERRT
dial-peer voice 15 pots
corlist outgoing Telefonnetz
destination-pattern 0.T
direct-inward-dial
port 0/0/0:15
dial-peer voice 1000 pots
service stcapp
port 0/1/0
dial-peer voice 1001 pots
service stcapp
port 0/1/1
dial-peer voice 1002 pots
service stcapp
port 0/1/2
dial-peer voice 1003 pots
service stcapp
port 0/1/3
dial-peer voice 100 voip
mailbox-selection orig-called-num
dial-peer voice 1 pots
description Benutzer_direct
destination-pattern 8871..
direct-inward-dial
port 0/0/0:15
dial-peer voice 2 pots
description Zentrale
destination-pattern 8870
direct-inward-dial
port 0/0/0:15
dial-peer voice 3 pots
description FAX-SERVER
destination-pattern 8878...
direct-inward-dial
dial-peer voice 4 pots
description FAX-Zentrale
destination-pattern 88777
direct-inward-dial
port 0/1/1
dial-peer voice 5 pots
description FAX-Vorzimmer
destination-pattern 88761
direct-inward-dial
port 0/1/2
dial-peer voice 2050 voip
description ** cue voicemail pilot number **
destination-pattern 399
b2bua
session protocol sipv2
session target ipv4:192.168.2.2
incoming called-number 399
voice-class sip outbound-proxy ipv4:192.168.2.2
dtmf-relay sip-notify
codec g711ulaw
no vad
num-exp ..
num-exp ...
sip-ua
gatekeeper
shutdown
telephony-service
conference hardware
no auto-reg-ephone
max-ephones 60
max-dn 400
ip source-address 172.16.1.1 port 2000
caller-id block code *#
calling-number initiator
service phone webAccess 0
service dnis overlay
service dnis dir-lookup
service dss
system message yyy xxx
url services http://192.168.2.2/voiceview/common/login.do
url authentication http://172.16.1.1/CCMCIP/authenticate.asp
cnf-file location flash:
cnf-file perphone
user-locale DE
network-locale DE
load 7915-24 B015-1-0-4
load 7942 term42.default
load 7962 term62.default
time-zone 28
time-format 24
date-format dd-mm-yy
keepalive 15 auxiliary 4
voicemail 399
max-conferences 8 gain -6
call-forward pattern 0.T
call-forward pattern .T
call-forward system redirecting-expanded
moh flash0:/music-on-hold.au
multicast moh 239.10.16.16 port 2000
web admin system name admin secret 5 $1$cbqU$Z1MXhDTcUDkyCjjg5am0I.
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern 8...T blind
transfer-pattern 0.T
transfer-pattern 6... blind
secondary-dialtone 9
directory last-name-first
directory entry 1 0112 name Feuerwehr
fac standard
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-template  1
ephone-dn  1  octo-line
number 100 secondary xxxx
label Zentrale
description 100
name Zentrale
banner exec  C
Wilkommen auf dem Telefonsystem der yyy xxx
line con 0
logging synchronous
login local
line aux 0
line 131
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
privilege level 15
login local
transport input ssh
line vty 5 15
access-class 23 in
privilege level 15
login local
transport input telnet ssh
scheduler allocate 20000 1000
end
2 Accepted Solutions
Ayodeji Okanlawon
I do not see your ephone configuration in this posted config of yours. Do you have the "type" command under your ephones
e.g
ephone 1
type 7962
Please do create cnf once you have made the change
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
6 Replies 6
brmeade
Level 4
Level 4
Hw An This Documents Not new for me i have Used this Documents
Directory url is http://Ita:cisco@172.16.1.1/localdirectory in the XML Files
When i remove the credentials the phone open authsite With username and pw for (lds-service)
So the target is Not reachable  dns ?
No because the System use the ip address ......
Phones : 7962,7942
Ayodeji Okanlawon
e.g
ephone 1
type 7962
Yes All ephone have types configuert
And i use create cnf many times and delete onetime all XML Files and recreate them
50 Ephones
3   7962
47 7942
example:
ephone 1
mac-address xxxx.xxxx.xxxx
type 7962
Ok Problem solevd !
How ?
Answer IOS Update.
Problem: C2921-CME-SRST-Bundele/K9
               IOS: 15.1 T
               CME Version 8.1 .....
               Hey 2900 ISR G2 Router should have the last IOS but .......
               I used CME 9.0 Filset so the directory is not set correct....
               Update to 15.2 X Problem solved.
                Homer would say Doooooooooooooooooooooooooooooo!
