Directory service in CUCM
Khurram Tariq
hello all
i need your help in configuring directory service in CUCM, i wanna look directory of extensions in IP phone, please suggest me ways how to fo it as i am using cucm 9.1 and 7945 phones.
thanks
10 Replies 10
Jaime Valencia
Just configure your users, or sync from a directory, that's it, the built-in corporate directory will show them
java
if this helps, please rate
how in CUCM? i have configured extension on the device not using end user profiles also i need when someone oress down button of phone it should see whole directory how to do that please explain?
Add end users, that's all there is to it. either manually, or via LDAP sync.
java
where to add end users manually??
how?
If you're an end user, I'd recommend you to engage your system admin for this task.
java
valencia i am an administrator, you are not clerifying ur suggestions please explain briefly please
In CUCM go to User Management --> End Users menu and add the user there if you chose to do it one by one. Best practice is to integrate to corporate LDAP and pull users from other. If you do not want to do that and want to import many users you can do this via BAT user import.
Chris
ok in end user do i need to assign user his own phone ??
and one question more if i want to add some numbers other than internal extensions for the attendant consle operator than how can i add ??
Only thing that needs to be set for Corporate Directory to work is the Telephone Number field.
... user management -> end user
java
