Disable Voicemail to Email for One User Unity
    Is this possible? I am currently browsing through the guides and figured i'd drop this here as well.
Thanks.
Chris Deren
Sure, you can simply either delete the mailbox, or you can change the after-greeting action.
Chris
The user just does not want them in ther inbox. I found the following article.
http://ciscotalk.wordpress.com/2011/11/22/delivering-voicemail-to-email-as-attachments-with-cisco-unity-connection-8-5/
Step 3?
Well, you did not explain if you are using Single Inbox feature or SMTP store and forward, in either case disabling it is easy, with the first one remove UM service on the user, with the second disable the SMTP forwarding.
Chris
