03-05-2014 05:44 AM - edited 03-16-2019 10:01 PM
Is this possible? I am currently browsing through the guides and figured i'd drop this here as well.
Thanks.
03-05-2014 05:48 AM
Sure, you can simply either delete the mailbox, or you can change the after-greeting action.
Chris
03-05-2014 05:54 AM
The user just does not want them in ther inbox. I found the following article.
Step 3?
03-05-2014 06:04 AM
Well, you did not explain if you are using Single Inbox feature or SMTP store and forward, in either case disabling it is easy, with the first one remove UM service on the user, with the second disable the SMTP forwarding.
Chris
