ā05-12-2013 11:26 PM - edited ā03-16-2019 05:17 PM
Hi All
while login to the Disaster Recovery System login page it take time ... after that when clicking on the backup nothing is happening
i have tried on all the browser .
CUCM VERSION :8.6.2.23077-1
regards
raja
ā05-12-2013 11:51 PM
1) Where is installed the CUCM?(VM?)
2) Did you restart Tomcat?
Please rate all useful posts
Chrysostomos
""Thinking is the hardest work there is , which is probably the reason why so few engage in it""
ā05-12-2013 11:55 PM
Hi Chrysostomos
It is install on MCS-7816-I4-IPC1 server
did the tomcat restart but still no luck
regards
raja
ā05-13-2013 12:00 AM
Hi Raja,
Are u trying to take backup on network or through tape?
Can u try through OS administartion using command
utils disaster_recovery backup network featurelist path servername username
regds,
aman
ā05-13-2013 12:08 AM
Hi Aman
I was try through the network only
how to do backup from os admin in cli
servername is the pub or the sftp server name
and username is for the oub or sftp
please advise
regards
raja
ā05-13-2013 12:14 AM
Hi Raja,
Please try below steps:
Parameters
ā¢ featurelist specifies the list of features to back up, separated by commas.
ā¢ path represents the location of the backup files on the remote server.
ā¢ servername represents the IP address or host name of the server where you stored the backup files.
ā¢ username represents the username that is needed to log in to the remote server.
Secondly, was this working setup or u upgraded from 7.x to 8.x?
Can u share output of command show memory size and show memory count from publisher?
regds,
aman
ā05-13-2013 12:20 AM
Hi Aman
The setup was working till the version 8.6.2.20000-2 For some problem with call flow issue we have to upgrade to the version 8.6.2.23077-1 after that the issue has started .
Total size of memory: 4.0 GB
Total number of memory modules: 2
ā05-13-2013 01:02 AM
Hi Raja,
Can u try taking backup from OS Administration page and let us know?
regds,
aman
ā05-13-2013 02:42 AM
HI Aman
Plz let me know how to take from OS administration page
Raja
ā05-13-2013 03:54 AM
Hi Raja,
You need tgo follow the steps:
a. login in OS Adminsitration page of Publisher using Putty.
b. On PC, run SFTP software like FREEFTPD in background.
Run the command
Parameters
regds,
aman
ā05-13-2013 10:24 PM
HI Aman
CLI backup is working
What we need to do it for GUI issue
Please let me know .
Thank you for your support .
raja
ā05-13-2013 10:34 PM
Hi Raja,
Thanks for update.
Can u please let me know whether the DRS page stops in between while loading or is slow but appears fully?
Any message which comes.
regds,
aman
ā05-13-2013 10:48 PM
Hi Aman
The DSR page will beshowing loading and will be refresh to the same page .
Raja
ā05-13-2013 11:15 PM
Hi Raja,
Can u run utils dignose test command and get the logs for tomcat file file get activelog tomcat/logs/* ?
regds,
aman
