Unity connection 8.x supported hardware
masroor-ali
I have unity connection 8.x to install on the below hardwares, there is no option comes for unity connection during the installation, nor I have found this hardware in "unity connention 8.x supported hardware list", please advise.
Hardwares:
UCS-C240 M3
UCS-C220 M3
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/supported_platforms/8xcucspl.html
Masroor Ali
Jaime Valencia
What OVA are you using???
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
ronpatel
Level 8
Level 8
UCS 240 and 220 both suports CUC. Please download proper OVA and try to install the CUC again.
http://docwiki.cisco.com/wiki/Unified_Communications_Virtualization_Supported_Applications
Ronak Patel
Rate all helpful post by clicking stars below the answer.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Nirmal Joshi
Level 4
Level 4
Hi Mansoor,
I not sure what you mean by no option comes for Unity connection during installation. Please elaborate.
You need to use bootable media for Unity connection.
As far as supported servers for unity is concerned yes both the servers are supported for Unity Connection 8.5 or above, obvously virtualized.
UC application on UCS has a set of guide lines on what is supported and what is not, you need to go through the link below to see what server fits your requirement based on the number of users in your network.
http://docwiki.cisco.com/wiki/Unified_Communications_in_a_Virtualized_Environment
BR,
Nirmal
Pls rate helpful posts.
Hi  Ali,
UCXN 8.X is supported on UCS C 220M3 and C240M3.Can us share the snapshot when u say u do not get option of Unity?
Messaging and Presence Applications
Application
UC on UCS Specs-based
Third-party Server Specs-based
UC on UCS
Tested Reference Configurations (TRCs)
Intel Xeon 56xx/75xx @ 2.53+ GHz
Intel Xeon E7-28xx
E7-48xx
E7-88xx @ 2.4+ GHz
Intel
Xeon
E5-26xx
E5-46xx @ 2.53+ GHz
B440 M2 TRC#1
B230 M2 TRC #1
B200 M3 TRC #1
B200 M2 TRC #1
B200 M2 TRC #2
B200 M1 TRC #1
B200 M1 TRC #2
C260 M2 TRC #1
C240 M3 TRC #1
C220 M3 TRC #1
C220 M3 TRC #2 (BE6K only)
C210 M2 TRC #1
C210 M2 TRC #2
C210 M2 TRC #3
C210 M1 TRC #1
C210 M1 TRC #2
C210 M1 TRC #3
C210 M1 TRC #4
C200 M2 TRC #1
Unity Connection8.0(2+)
8.5(x)
8.6(x)
9.0(x)
8.0(2+)
8.5(x)
8.6(x)
9.0(x)
8.0(2+)
8.5(x)
8.6(x)
9.0(x)
8.0(2+)
8.5(x)
8.6(x)
9.0(x)
8.0(2+)
8.5(x)
8.6(x)
9.0(x)
8.0(2+)
8.5(x)
8.6(x)
9.0(x)
8.0(2+)
8.5(x)
8.6(x)
9.0(x)
8.0(3+)
8.5(x)
8.6(x)
9.0(x)
8.0(2+)
8.5(x)
8.6(x)
9.0(x)
8.0(3+)
8.5(x)
8.6(x)
9.0(x)
8.0(2+)
8.5(x)
8.6(x)
9.0(x)
8.0(2+)
8.5(x)
8.6(x)
9.0(x)
8.0(2+)
8.5(x)
8.6(x)
9.0(x)
Check here for supported versions8.0(2+)
8.5(x)
8.6(x)
9.0(x)
8.0(2+)
8.5(x)
8.6(x)
9.0(x)
8.0(3+)
8.5(x)
8.6(x)
9.0(x)
8.0(2+)
8.5(x)
8.6(x)
9.0(x)
8.0(2+)
8.5(x)
8.6(x)
9.0(x)
8.0(2+)
8.5(x)
8.6(x)
9.0(x)
8.0(3+)
8.5(x)
8.6(x)
9.0(x)
8.0(2+)
8.5(x)
8.6(x)
9.0(x)
Unity7.0(2) and later7.0(2) and later7.0(2) and later7.0(2) and later7.0(2) and later7.0(2) and later7.0(2) and later7.0(2) and later7.0(2) and later7.0(2) and later7.0(2) and later7.0(2) and later7.0(2) and laterNot supported7.0(2) and later7.0(2) and later7.0(2) and later7.0(2) and later7.0(2) and later7.0(2) and later7.0(2) and laterNot supported
Unified Presence (1)8.6(x)8.6(4+)8.6(4+)8.6(4+)8.6(4+)8.6(4+)8.5(x)
8.6(x)
8.5(x)
8.6(x)
8.0(2+)
8.5(x)
8.6(x)
8.5(x)
8.6(x)
8.6(x)
8.5(x)
8.6(x)
8.5(x)
8.6(x)
8.0(2+)
8.5(x)
8.6(x)
8.0(2+)
8.5(x)
8.6(x)
8.0(2+)
8.5(x)
8.6(x)
8.5(x)
8.6(x)
8.5(x)
8.6(x)
regds,
aman
