Disconnect cause=38
Helmi Muzammil
Hi All,
I hava some problem on my voip network. when I make calls to the router that PLAR to the call manager, i get an error "Disconnect cause=38" and call couldn't completely and there is a busy tone. i have tried to check and telnet port 1720 and there is no problem. what i have to do?
Really need your helps.
DPSRTR01#csim start 6388
*Jul 20 04:07:28.761: csim: called number = 6388, loop count = 1 ping count = 0
*Jul 20 04:07:28.761: csimSetupPeer peer type(2), destPat(6388), matched(4), target()
*Jul 20 04:07:28.761: //-1/xxxxxxxxxxxx/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=FALSE, Mode=0,
   Outgoing Dial-peer=3, Params=0x45629278, Progress Indication=NULL(0)
*Jul 20 04:07:28.761: //-1/xxxxxxxxxxxx/CCAPI/ccCheckClipClir:
   In: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Destination Pattern=6388, Called Number=6388, Digit Strip=FALSE
   Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=6388(TON=Unknown, NPI=Unknown),
   Redirect Number=, Display Info=
   Account Number=, Final Destination Flag=FALSE,
   Guid=41697C14-D157-11E1-80A2-9FBA2AB422CC, Outgoing Dial-peer=3
*Jul 20 04:07:28.761: //-1/xxxxxxxxxxxx/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=6388
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
*Jul 20 04:07:28.761: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x47267AE0, Interface Type=1, Destination=, Mode=0x0,
   Call Params(Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=6388(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=, FinalDestinationFlag=FALSE, Outgoing Dial-peer=3, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
*Jul 20 04:07:28.761: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Jul 20 04:07:28.761: :cc_get_feature_vsa malloc success
*Jul 20 04:07:28.761:  cc_get_feature_vsa count is 1
*Jul 20 04:07:28.761: :FEATURE_VSA attributes are: feature_name:0,feature_time:1188713008,feature_id:137
*Jul 20 04:07:28.761: //137/41697C1480A2/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
*Jul 20 04:07:28.761: //137/41697C1480A2/CCAPI/ccCallSetContext:
   Context=0x49817C14
*Jul 20 04:07:28.825: //137/41697C1480A2/CCAPI/cc_api_call_disconnected:
   Cause Value=38, Interface=0x47267AE0, Call Id=137
*Jul 20 04:07:28.829: //137/41697C1480A2/CCAPI/cc_api_call_disconnected:
   Call Entry(Responsed=TRUE, Cause Value=38, Retry Count=0)
*Jul 20 04:07:28.829: csim_do_test: cid(137), ev(12), disp(0)
*Jul 20 04:07:28.829: csimTraceSct: cid(137),st(0),oldst(0)
*Jul 20 04:07:28.829: csim err csimDisconnected recvd DISC cid(137)
*Jul 20 04:07:28.829: //137/41697C1480A2/CCAPI/ccCallDisconnect:
   Cause Value=38, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=38)
   Cause Value=38, Call Entry(Responsed=TRUE, Cause Value=38)
*Jul 20 04:07:28.829: //137/41697C1480A2/CCAPI/cc_api_get_transfer_info:
   Transfer Numbe
DPSRTR01#r Is Null
*Jul 20 04:07:28.829: voip_rtp_release_port: rtcp_socket=0x47BFBC38
*Jul 20 04:07:28.829: //137/41697C1480A2/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x47267AE0, Tag=0x0, Call Id=137,
   Call Entry(Disconnect Cause=38, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
*Jul 20 04:07:28.829: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Jul 20 04:07:28.829: :cc_free_feature_vsa freeing 46DA5228
*Jul 20 04:07:28.829:  vsacount in free is 0
*Jul 20 04:07:28.833: csim_do_test: cid(137), ev(13), disp(0)
*Jul 20 04:07:28.833: csimTraceSct: cid(137),st(2),oldst(0)
*Jul 20 04:07:29.333: csim: loop = 1, failed = 1
*Jul 20 04:07:29.333: csim: call attempted = 1, setup failed = 1, tone failed = 0
*Jul 20 04:07:29.333: //-1/xxxxxxxxxxxx/CCAPI/ccAppShutdownMode:
   ccAppShutdownMode: remove it from the queue
can you please add this command to your interface FastEthernet0/0.1
h323-gateway voip interface
Can you also confirm what IP is showing on cucm for the gateway?
Once you have added the command enbale the ff: debug
debug cch323 all
debug ip tcp transaction
Do a test call. Send the result of the logs here.
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
23 Replies 23
Ayodeji Okanlawon
That cause code means that your network is out of order. This is most likely a configuration issue. can you send a sh run. Can you also tell us what your call flow is like
Hi Aokanlawon,
Thanks for your Help,
my router configuration as attached.
my call flow is :
router site 1 - WAN - router HO - Call manager
i used H.323 gateway, from router site 1 can reach call manager.
version 12.4
hostname site1
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret 5 $1$EC73$qlak3XI97oUAB4HerO4uJ/
no aaa new-model
dot11 syslog
trunk group  PSTN_FXO_Trunk
voice-card 0
dspfarm
dsp services dspfarm
voice service voip
no supplementary-service h225-notify cid-update
h323
  no h225 timeout keepalive
voice class codec 1
codec preference 1 g729r8
codec preference 2 g729br8
codec preference 3 g711ulaw
voice class h323 1
h225 timeout tcp establish 3
voice translation-rule 1
rule 1 /^91/ /1/
rule 2 /^92/ /2/
rule 3 /^93/ /3/
rule 4 /^94/ /4/
rule 5 /^95/ /5/
rule 6 /^96/ /6/
rule 7 /^97/ /7/
rule 8 /^98/ /8/
rule 9 /^99/ /9/
rule 10 /^90/ /0/
voice translation-rule 3
rule 1 /^9\(.*\)/ /\1/
voice translation-profile PSTN
translate called 1
voice translation-profile PSTN3
translate called 3
crypto pki trustpoint TP-self-signed-3762798833
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3762798833
revocation-check none
rsakeypair TP-self-signed-3762798833
crypto pki certificate chain TP-self-signed-3762798833
certificate self-signed 01
  30820251 308201BA A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 33373632 37393838 3333301E 170D3130 30333233 30393038
  33355A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 37363237
  39383833 3330819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100E155 AD90C511 FCAD1267 2A0FECBB 122E7725 954485C6 5821072C 8C5D90D2
  FD3C2265 DBDD8D99 F5661F44 E3143844 7CA80BD8 E6EB2C45 98857F26 319990D0
  9E1097F7 5FC34BA4 8F41ABA2 24F83B45 A0DCE835 641A3615 579CAEE7 D3737166
  ED6FE147 55E9003F 1055D6C2 75E5BA41 DE85FC07 43F86A49 9AF3CDDE A9EBD9DB
  B8250203 010001A3 79307730 0F060355 1D130101 FF040530 030101FF 30240603
  551D1104 1D301B82 19445053 52545230 312E6162 61637573 2D696E64 2E636F2E
  6964301F 0603551D 23041830 16801445 DD3AA715 9AF897C9 A5111E78 0530BD87
  EE2F6430 1D060355 1D0E0416 041445DD 3AA7159A F897C9A5 111E7805 30BD87EE
  2F64300D 06092A86 4886F70D 01010405 00038181 00682D9E 8FAD7672 F3EE6090
  F52AFF07 23830BAC D8FAEF50 B9AD02FA 66B7184A EA70470A 4844A83C 00F54913
  EA24A877 8F3394FD 65619889 0AD7FFD8 CE3438BB 3F8E1C68 646CDF65 AD3526CB
  33642487 AD8EE698 6E436055 52145838 3FD3459D CB7B332F 9DD609FD F7E85177
  DE7C6B89 C494648D 1CECA7FC D2E3C0C0 6B7FFBF5 AB
      quit
archive
log config
  hidekeys
class-map match-any voice_data
match access-group name VoIP-Data
match protocol rtp audio
match  dscp ef
match  precedence 5
match ip dscp ef
match  dscp cs5
match ip precedence 5
class-map match-any voice_control
match ip dscp af31
match  dscp cs3
match access-group name VoIP-Control
match access-group name Telnet-Traffic
match protocol h323
match protocol rtcp
match protocol skinny
match protocol sip
match protocol mgcp
match ip precedence 3
match ip precedence 2
policy-map QoS_Inside
class voice_data
  set ip precedence 5
class voice_control
  set ip precedence 2
class class-default
  set ip precedence 0
policy-map QoS_Outside_MPLS
class voice_data
  priority percent 35
  set ip precedence 5
class voice_control
  bandwidth percent 20
  random-detect
  set ip precedence 2
class class-default
  bandwidth percent 40
  random-detect
  set ip precedence 0
class voice_control
  set ip dscp cs3
  bandwidth percent 15
  random-detect dscp-based
class voice_data
  set ip dscp ef
  bandwidth percent 50
   compress header ip rtp
  class class-default
  fair-queue
  random-detect
  set ip precedence 0
translation-rule 2
Rule 0 ^90.% 0
Rule 1 ^91.% 1
Rule 2 ^92.% 2
Rule 3 ^93.% 3
Rule 4 ^94.% 4
Rule 5 ^95.% 5
Rule 6 ^96.% 6
Rule 7 ^97.% 7
Rule 8 ^98.% 8
Rule 9 ^99.% 9
translation-rule 4
Rule 0 ^90 0
Rule 1 ^91 1
Rule 2 ^92 2
Rule 3 ^93 3
Rule 4 ^94 4
Rule 5 ^95 5
Rule 6 ^96 6
Rule 7 ^97 7
Rule 8 ^98 8
Rule 9 ^99 9
translation-rule 3
Rule 1 ^903611.% 1
Rule 2 ^903612.% 2
Rule 3 ^903613.% 3
Rule 4 ^903614.% 4
Rule 5 ^903615.% 5
Rule 6 ^903616.% 6
Rule 7 ^903617.% 7
Rule 8 ^903618.% 8
Rule 9 ^903619.% 9
interface Loopback0
ip address 1.2.3.254 255.255.255.252
description connection to JKTNMC
no ip address
duplex full
speed auto
service-policy input QoS_Inside
description VLAN_Data_Gateway
encapsulation dot1Q 1 native
ip address 1.2.0.1 255.255.248.0
ip nat inside
ip virtual-reassembly
h323-gateway voip bind srcaddr 10.54.0.1
interface FastEthernet0/0.15
description VLAN_Voice
encapsulation dot1Q 15
ip address 1.2.10.1 255.255.255.224
interface Service-Engine0/1
ip unnumbered Loopback0
service-module ip address 1.2.10.253 255.255.255.252
service-module ip default-gateway 10.54.10.254
interface FastEthernet0/1
ip address 4.5.6.7 255.255.255.0
ip nat outside
duplex auto
speed auto
interface Serial0/1/0
bandwidth 512
no ip address
encapsulation frame-relay
no fair-queue
clock rate 2000000
frame-relay traffic-shaping
frame-relay lmi-type ansi
interface Serial0/1/0.220 point-to-point
ip address 4.5.7.8 255.255.255.252
snmp trap link-status
no cdp enable
frame-relay interface-dlci 220
  class VOIPovFR
interface Serial0/1/0.230 point-to-point
ip address 4.5.9.2 255.255.255.252
no cdp enable
frame-relay interface-dlci 230
  class VOIPovFR
interface Serial0/1/1
no ip address
shutdown
clock rate 2000000
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.100.1
ip route 1.2.0.0 255.255.0.0 10.54.0.3
ip route 1.2.10.0 255.255.255.0 10.54.0.3
ip route 1.3.10.0 255.255.255.0 10.54.0.3
ip route 1.4.10.253 255.255.255.255 Service-Engine0/1
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip http path flash:
ip nat pool wan 192.168.100.100 192.168.100.100 prefix-length 24
ip nat inside source list 10 pool wan overload
ip access-list extended Telnet-Traffic
permit tcp any any eq telnet
permit tcp any eq telnet any
ip access-list extended VoIP-Control
remark H.323
permit tcp any any eq 1720
permit tcp any eq 1720 any
permit tcp any any range 11000 11999
remark MGCP
permit udp any any eq 2427
permit tcp any any eq 2428
remark Cisco Skinny
permit tcp any any range 2000 2002
remark UCCX_Chat
permit tcp any any eq 59000
permit tcp any eq 59000 any
permit tcp any any eq 59020
permit tcp any eq 59020 any
permit tcp any any eq 59021
permit tcp any eq 59021 any
ip access-list extended VoIP-Data
permit udp any any range 16384 32767
map-class frame-relay VOIPovFR
frame-relay cir 512000
frame-relay bc 5120
frame-relay be 0
frame-relay mincir 486400
frame-relay adaptive-shaping becn
service-policy output QoS_Outside_MPLS
access-list 10 permit 10.54.0.0 0.0.255.255
control-plane
voice-port 0/0/0
supervisory disconnect dualtone mid-call
cptone ID
timeouts interdigit 2
connection plar opx 6388
caller-id enable
voice-port 0/0/1
cptone ID
caller-id enable
voice-port 0/0/2
cptone ID
caller-id enable
voice-port 0/0/3
cptone ID
caller-id enable
voice-port 0/2/0
trunk-group PSTN_FXO_Trunk
cptone ID
caller-id enable
voice-port 0/2/1
cptone ID
caller-id enable
voice-port 0/2/2
cptone ID
caller-id enable
voice-port 0/2/3
cptone ID
caller-id enable
ccm-manager music-on-hold
sccp local FastEthernet0/0.15
sccp ccm 10.50.1.32 identifier 2
sccp ccm 10.50.1.31 identifier 1
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate ccm 2 priority 2
associate profile 1 register CFB04FE7f2DA280
associate profile 2 register MTP04FE7F2DA280
keepalive retries 5
switchover method immediate
switchback method immediate
switchback interval 15
dspfarm profile 2 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 3
associate application SCCP
dspfarm profile 1 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 1
dial-peer voice 1 voip
description DID to JKTCMP
preference 1
destination-pattern [1-8]...
progress_ind setup enable 3
progress_ind progress enable 8
voice-class codec 1
voice-class h323 1
session target ipv4:10.50.1.31
dtmf-relay h245-alphanumeric
ip qos dscp cs3 signaling
no vad
dial-peer voice 2 voip
preference 1
voice-class codec 1
voice-class h323 1
session target ipv4:10.50.1.32
no vad
dial-peer voice 3 voip
description Connection to UCCX
preference 1
destination-pattern 6388
voice-class h323 1
dtmf-relay h245-signal
ip qos dscp cs5 media
no vad
dial-peer voice 100 pots
trunkgroup PSTN_FXO_Trunk
description Outgoing Call to PSTN via FXO
preference 1
destination-pattern 9.T
translate-outgoing called 2
no digit-strip
dial-peer voice 10 voip
description ** cue pilot number **
preference 10
voice-class h323 1
session protocol sipv2
session target ipv4:10.54.10.253
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 4 voip
preference 2
voice-class h323 1
no vad
dial-peer voice 101 pots
description SiteToLocalDPS
destination-pattern 90361T
translate-outgoing called 3
no digit-strip
call-manager-fallback
secondary-dialtone 9
max-conferences 8 gain -6
transfer-system full-consult
ip source-address 10.54.0.1 port 2000
max-ephones 42
max-dn 144
alias 1 0 to 1100 preference 1
translate called 2
call-forward busy 1100
call-forward noan 1100 timeout 30
multicast moh 239.1.1.1 port 16388 route 10.54.0.1
Your call to 6388 matches dial-peer 3.
Here is dp 3 config. It says connection to UCCX. Are u sending the call direct;y to UCCX? I dont think you can do that. You need to send it to cucm first. If you are sending the call to cucm, is this your cucm ip (10.50.1.31)?
Have you configured this gateway as a h323 gateway on cucm?
preference 1
voice-class h323 1
no vad
Hi Aonkanlawon,
That's correct that 10.50.1.31 is CCM manager IP. also i have configured h323 gateway on call manager too.
Any Idea?
Thanks.
I want to assume that your h323 gateway is not properly configured. I do not see in your configuration where you have enabled h323 bind commands for h323 signalling on any of your interface.
You need to configure an interface especially the one with the ip address you have configured on your cucm as the h323 interface
Please add the ff: to your config..
interface
h323-gateway voip bind srcaddr X.X.X.X ( where x.x.x.x is the ip adress of the interface..this must match to the ip you are using in cucm)
Cause code 38 = Network Out Of Order.
Look at your H323 binding on interface fas 0/0.1
Your config is :-
ip nat inside
To me this is wrong.
You are sending packets as H323 source Ip address 10.54.0.1
but your interface is 1.2.0.1
These need to be the same Ip address.
If you change the H323 address binding to 1.2.0.1 you will
need to change the ip address on the gateway page in CUCM to
be 1.2.0.1 along with your Call manager fall back references
in both the CUCM and the IOS config.
You could try changing the int face address to 10.54.0.1
but you would need to know what else this would affect
Another alternative would be to define 10.54.0.1 as a loopback interface
and bind the H323 there and also make sure you can route to and from the address
throughout your VOIP network.
interface loopback 100
description  *** H323 Gateway Binding ***
ip address 10.54.0.1 255.255.255.255.255
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
Hi Aonkanlawon and acampbell,
sorry that i made a mistake in writing IP on interface fastethernet 0/0.1, the correct IP is 10.54.0.1 on my router configuration. i also can reach call manager by 10.54.0.1 and port 1720 is open.
need your advice,
Helmi
debug cch323 all
Hi Aonkanlawon,
Thanks for your support,
i've added the "h323-gateway voip interface" on my interface FastEthernet 0/0.1, but still coudn't reach call manager.
also i've debugged cch323 all and ip tcp transaction, i need your help to investigate it. i see that port 1720 is blocked (bold), is it true?
*Jul 23 07:51:13.463: csim: called number = 6388, loop count = 1 ping count = 0
*Jul 23 07:51:13.463: csimSetupPeer peer type(2), destPat(6388), matched(4), target()
*Jul 23 07:51:13.463: //-1/xxxxxxxxxxxx/CCAPI/ccCallSetupRequest:
*Jul 23 07:51:13.463: //-1/xxxxxxxxxxxx/CCAPI/ccCheckClipClir:
   Guid=026593FF-D3D2-11E1-8153-9FBA2AB422CC, Outgoing Dial-peer=3
*Jul 23 07:51:13.463: //-1/xxxxxxxxxxxx/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=6388
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
*Jul 23 07:51:13.463: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
*Jul 23 07:51:13.467: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Jul 23 07:51:13.467: :cc_get_feature_vsa malloc success
*Jul 23 07:51:13.467:  cc_get_feature_vsa count is 1
*Jul 23 07:51:13.467: :FEATURE_VSA attributes are: feature_name:0,feature_time:1188712792,feature_id:227
*Jul 23 07:51:13.467: //-1/xxxxxxxxxxxx/H323/cch323_post_call_setup_request: callID=227
*Jul 23 07:51:13.467: //-1/xxxxxxxxxxxx/H323/cch323_post_call_setup_request: incoming_call=0 incoming_media=0
*Jul 23 07:51:13.467: //227/026593FF8153/CCAPI/ccIFCallSetupRequestPrivate:
*Jul 23 07:51:13.467: //227/026593FF8153/CCAPI/ccCallSetContext:
   Context
DPSRTR01#=0x49817F5C
*Jul 23 07:51:13.467: //-1/xxxxxxxxxxxx/H323/cch323_get_new_ccb: ccb (0x46490624) is in use
*Jul 23 07:51:13.467: //227/026593FF8153/H323/cch323_call_setup: gw_id=1
*Jul 23 07:51:13.467: //227/026593FF8153/H323/cch323_call_setup: Inserted ccb
*Jul 23 07:51:13.467: //-1/xxxxxxxxxxxx/H323/cch323_create_call_info_type_container:
cch323_create_call_info_type_container: creating callInfoType container for callID = 227
*Jul 23 07:51:13.467: //-1/xxxxxxxxxxxx/H323/cch323_get_dp_pref_mask:
cch323_get_dp_pref_mask:IPIPGW(227):setting mask for 729ar8 also as 729is configured
cch323_get_dp_pref_mask:IPIPGW(227):setting mask for 729abr8 also as729b is configured
*Jul 23 07:51:13.467: //227/026593FF8153/H323/cch323_get_caps_chn_info: No peer leg setup params
*Jul 23 07:51:13.467: //227/026593FF8153/H323/cch323_get_peer_info: Entry
*Jul 23 07:51:13.467: //227/026593FF8153/H323/cch323_get_peer_info: Have peer
*Jul 23 07:51:13.467: //227/026593FF8153/H323/cch323_get_peer_info: faxrate[41] proto[3] bitmask[10082] t38_inhibit[0] global_fax[0] t38fax[0]
*Jul 23 07:51:13.467: //227/026593FF8153/H323/cch323_set_pref_codec_list: First preferred codec(bytes)=16(20)
*Jul 23 07:51:13.467: //227/026593FF8153/H323/cch323_get_peer_info: Preferred codec set to G729IETF with Bytes = 20
*Jul 23 07:51:13.467: //227/026593FF8153/H323/cch323_get_peer_info: Flow Mode set to FLOW_THROUGH
*Jul 23 07:51:13.471: //227/026593FF8153/H323/cch323_get_peer_info: peer: 47CCC450, peer->voice_peer_tag: 3, ccb: 46490624
*Jul 23 07:51:13.471: //227/026593FF8153/H323/cch323_set_h323_parms_from_dp: ccb h245addr bits = system[0x0007]
*Jul 23 07:51:13.471: //227/026593FF8153/H323/cch323_set_h323_parms_from_dp: ccb ccm bits = system[0x0028]
*Jul 23 07:51:13.471: //227/026593FF8153/H323/cch323_update_setup_callinfo: called_oct3 = 0x0, calling_oct3 = 0x0, calling_oct3a = 0x0
*Jul 23 07:51:13.471: //227/026593FF8153/H323/cch323_set_h323_control_options_outgoing: h245 sm mode = 271
*Jul 23 07:51:13.471: //227/026593FF8153/H323/cch323_set_h323_control_options_outgoing: h323_ctl=0x20
*Jul 23 07:51:13.471: //227/026593FF8153/H323/cch323_call_setup: No account/pin number available
*Jul 23 07:51:13.471: //227/026593FF8153/H323/cch323_store_call_info: Call_setup Playout Mode: 1,Init 60, Min 40, Max 250, Fax 300
*Jul 23 07:51:13.471: //227/026593FF8153/H323/cch323_call_setup_normal: Entry
*Jul 23 07:51:13.471: TCB49554014 created
*Jul 23 07:51:13.471: TCB49554014 setting property TCP_PID (8) 46E86194
*Jul 23 07:51:13.471: TCB49554014 setting property TCP_NO_DELAY (1) 46E86198
*Jul 23 07:51:13.471: TCB49554014 setting property TCP_TOS (11) 46E861E4
*Jul 23 07:51:13.471: TCB49554014 setting property TCP_NONBLOCKING_WRITE (10) 46E86228
*Jul 23 07:51:13.471: TCB49554014 setting property TCP_NONBLOCKING_READ (14) 46E86228
*Jul 23 07:51:13.471: TCB49554014 setting property TCP keepalive timeout (17) 46E86228
*Jul 23 07:51:13.471: TCB49554014 setting property TCP_VRFTABLEID (20) 497B23CC
*Jul 23 07:51:13.471: TCB49554014 setting property TCP_NO_DELAY (1) 46E861E4
*Jul 23 07:51:13.471: TCB49554014 setting property TCP_ALWAYSPUSH (15) 46E861E4
*Jul 23 07:51:13.471: TCP: Random local port generated 38757, network 1
*Jul 23 07:51:13.471: TCB49554014 bound to 10.54.0.1.38757
*Jul 23 07:51:13.471: Reserved port 38757 in Transport Port Agent for TCP IP type 1
*Jul 23 07:51:13.471: TCP: sending SYN, seq 1337104238, ack 0
*Jul 23 07:51:13.471: TCP0: Connection to 10.50.1.31:1720, advertising MSS 536
*Jul 23 07:51:13.475: TCP0: state was CLOSED -> SYNSENT [38757 -> 10.50.1.31(1720)]
*Jul 23 07:51:13.475: //227/026593FF8153/H323/cch323_store_call_info: Call_setup Playout Mode: 1,Init 60, Min 40, Max 250, Fax 300
*Jul 23 07:51:13.527: TCP0: state was SYNSENT -> ESTAB [38757 -> 10.50.1.31(1720)]
*Jul 23 07:51:13.527: TCP: tcb 49554014 connection to 10.50.1.31:1720, peer MSS 1460, MSS is 536
*Jul 23 07:51:13.527: //-1/xxxxxxxxxxxx/H323/cch323_ct_main: SOCK 2 Event 0x1
*Jul 23 07:51:13.527: //-1/xxxxxxxxxxxx/H323/cch323_iev_queue_service: Dispatch 0xB internal event to H225 SM
*Jul 23 07:51:13.527: //227/026593FF8153/H323/run_h225_sm: Received event H225_EV_SETUP while at state H225_IDLE
*Jul 23 07:51:13.527: //227/026593FF8153/H323/check_qos_and_send_setup: Setup ccb 0x46490624
*Jul 23 07:51:13.527: //227/026593FF8153/H323/cch323_rotary_validate: No peer_ccb available
*Jul 23 07:51:13.527: //-1/xxxxxxxxxxxx/H323/cch323_iev_queue_service: Dispatch 0xE internal event to H225 SM
*Jul 23 07:51:13.531: //227/026593FF8153/H323/run_h225_sm: Received event H225_EV_FS_SETUP while at state H225_IDLE
*Jul 23 07:51:13.531: //227/026593FF8153/H323/idle_fsSetup_hdlr: Setup ccb 0x46490624
*Jul 23 07:51:13.531: //227/026593FF8153/H323/idle_fsSetup_hdlr: send_fastStart_setup called
*Jul 23 07:51:13.531: //227/026593FF8153/H323/send_fastStart_setup: Entry
*Jul 23 07:51:13.531: //227/026593FF8153/H323/cch323_build_local_encoded_fastStartOLCs: state_mc_mode=0x10F on outbound leg
*Jul 23 07:51:13.531: //227/026593FF8153/H323/cch323_build_local_encoded_fastStartOLCs: srcAddress = 0xA360001, h245_lport = 0, flow mode = 1, minimum_qos=0
*Jul 23 07:51:13.531: //227/026593FF8153/H323/h245_set_local_audio_mask: Near-end Pref Codecs = G729IETF
*Jul 23 07:51:13.531: //227/026593FF8153/H323/cch323_generic_open_logical_channel: current codec = 16:20:20
*Jul 23 07:51:13.531: //227/026593FF8153/H323/cch323_generic_open_logical_channel: Codec is G729IETF
*Jul 23 07:51:13.531: //227/026593FF8153/H323/cch323_generic_open_logical_channel: Filling in qosCapability field to 0
*Jul 23 07:51:13.531: //227/026593FF8153/H323/generic_send_setup: Entry
generic_send_setup: is_overlap = 0, info_complete = 0
*Jul 23 07:51:13.531: //227/026593FF8153/H323/generic_send_setup: ====== PI = 0
*Jul 23 07:51:13.531: //227/026593FF8153/H323/generic_send_setup: Send infoXCap=128, infoXRate=16, rateMult=0, xMode=128, info_layer1_prot=163
*Jul 23 07:51:13.531: //227/026593FF8153/H323/generic_send_setup: src address = 10.54.0.1; dest address = 10.50.1.31
*Jul 23 07:51:13.531: //227/026593FF8153/H323/cch323_h225_set_new_state: Changing from H225_IDLE state to H225_REQ_FS_SETUP state
*Jul 23 07:51:13.531: //-1/xxxxxxxxxxxx/H323/cch323_iev_queue_service: Dispatch 0x0 internal event to H245 IWF SM
*Jul 23 07:51:13.535: //227/026593FF8153/H323/run_h245_iwf_sm: received IWF_EV_FASTSTART while at state IWF_IDLE
*Jul 23 07:51:13.535: //-1/xxxxxxxxxxxx/H323/cch323_ct_main: SOCK 2 Event 0x1
*Jul 23 07:51:13.555: TCP0: FIN processed
*Jul 23 07:51:13.555: TCP0: state was ESTAB -> CLOSEWAIT [38757 -> 10.50.1.31(1720)]
*Jul 23 07:51:13.555: //-1/xxxxxxxxxxxx/H323/cch323_ct_main: SOCK 2 Event 0x1
*Jul 23 07:51:13.555: //-1/xxxxxxxxxxxx/H323/h323_set_cc_cause_for_spi_err:
Categorized cause:38, category:186
*Jul 23 07:51:13.555: //-1/xxxxxxxxxxxx/H323/h323_set_release_source_for_peer: ownCallId[227], src[6]
*Jul 23 07:51:13.555: TCP0: state was CLOSEWAIT -> LASTACK [38757 -> 10.50.1.31(1720)]
*Jul 23 07:51:13.555: TCP0: sending FIN
*Jul 23 07:51:13.555: //-1/xxxxxxxxxxxx/H323/h323_gw_clean_send_blocked_watch: fd 2
*Jul 23 07:51:13.555: //-1/xxxxxxxxxxxx/H323/cch323_cleanup_xport: hashDestroy for TcpFDTbl
*Jul 23 07:51:13.555: //-1/xxxxxxxxxxxx/H323/cch323_iev_queue_service: Dispatch 0x2D internal event to H225 SM
*Jul 23 07:51:13.555: //227/026593FF8153/H323/run_h225_sm: Received event H225_EV_CONN_LOST while at state H225_REQ_FS_SETUP
*Jul 23 07:51:13.555: //227/026593FF8153/H323/cch323_traverse_enum_contact_list: State = 2
*Jul 23 07:51:13.555: //227/026593FF8153/CCAPI/cc_api_call_disconnected:
   Cause Value=38, Interface=0x47267AE0, Call Id=227
*Jul 23 07:51:13.559: csim_do_test: cid(227), ev(12), disp(0)
*Jul 23 07:51:13.559: csimTraceSct: cid(227),st(0),oldst(0)
*Jul 23 07:51:13.559: csim err csimDisconnected recvd DISC cid(227)
*Jul 23 07:51:13.559: //227/026593FF8153/CCAPI/ccCallDisconnect:
*Jul 23 07:51:13.559: //227/026593FF8153/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
*Jul 23 07:51:13.559: //227/026593FF8153/H323/cch323_do_call_disconnect: gw_id=1, discCause=38
*Jul 23 07:51:13.559: //-1/xxxxxxxxxxxx/H323/cch323_iev_queue_service: Dispatch 0x9 internal event to H225 SM
*Jul 23 07:51:13.559: //227/026593FF8153/H323/run_h225_sm: Received event H225_EV_RELEASE while at state H225_REQ_FS_SETUP
*Jul 23 07:51:13.559: //227/026593FF8153/H323/cch323_h225_set_new_state: Changing from H225_REQ_FS_SETUP state to H225_IDLE state
*Jul 23 07:51:13.559: //227/026593FF8153/H323/cch323_call_generic_cleanup: Disconnected flag 1
*Jul 23 07:51:13.559: voip_rtp_release_port: rtcp_socket=0x47BFBC38
*Jul 23 07:51:13.559: //227/026593FF8153/H323/cch323_store_call_history_entry: Call Active Playout Mode: 1,Init 60, Min 40, Max 250, Fax 300
*Jul 23 07:51:13.559: //227/026593FF8153/H323/cch323_store_call_history_entry: Call History Playout Mode: 1,Init 60, Min 40, Max 250, Fax 300
*Jul 23 07:51:13.559: //227/026593FF8153/H323/run_h245_iwf_sm: received IWF_EV_H245_DISCONN while at state IWF_IDLE
*Jul 23 07:51:13.559: //227/026593FF8153/H323/defaultHdlr: DEFAULT: Received IWF_EV_H245_DISCONN in state IWF_IDLE
*Jul 23 07:51:13.559: //227/026593FF8153/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x47267AE0, Tag=0x0, Call Id=227,
*Jul 23 07:51:13.563: //227/026593FF8153/CCAPI/cc_api_call_disconnect_done:
*Jul 23 07:51:13.563: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Jul 23 07:51:13.563: :cc_free_feature_vsa freeing 46DA5150
*Jul 23 07:51:13.563:  vsacount in free is 0
*Jul 23 07:51:13.563: //-1/xxxxxxxxxxxx/H323/cch323_call_generic_cleanup: Freeing ccb (0x46490624)
*Jul 23 07:51:13.563: csim_do_test: cid(227), ev(13), disp(0)
*Jul 23 07:51:13.563: csimTraceSct: cid(227),st(2),oldst(0)
*Jul 23 07:51:13.623: TCP0: RST received, Closing connection
*Jul 23 07:51:13.623: TCP0: state was LASTACK -> CLOSED [38757 -> 10.50.1.31(1720)]
*Jul 23 07:51:13.623: Released port 38757 in Transport Port Agent for TCP IP type 1 delay 240000
*Jul 23 07:51:13.623: TCB 0x49554014 destroyed
*Jul 23 07:51:14.063: csim: loop = 1, failed = 1
*Jul 23 07:51:14.063: csim: call attempted = 1, setup failed = 1, tone failed = 0
*Jul 23 07:51:14.063: //-1/xxxxxxxxxxxx/CCAPI/ccAppShutdownMode:
*Jul 23 07:51:14.895: //-1/xxxxxxxxxxxx/H323/cch323_process_carrier_update: Registered = 0, Event = 1, Reason = 2
*Jul 23 07:51:19.051: TCP514: SNDWND timeout timer expired
*Jul 23 07:51:19.051: 10.54.0.1:23 <---> 10.54.0.3:52802   congestion window changes
*Jul 23 07:51:19.051: cwnd from 11790 to 536, ssthresh from 65535 to 1072
*Jul 23 07:51:19.051: TCP514: probe #1 - timeout is 606 ms, seq 2443417070
*Jul 23 07:51:19.147: TCB4957941C setting property TCP_TOS (11) 47CCB0C0
*Jul 23 07:51:19.659: TCP514: SNDWND timeout timer expired
*Jul 23 07:51:19.659: TCP514: probe #2 - timeout is 1212 ms, seq 2443417070
*Jul 23 07:51:20.271: TCB48074AB0 setting property TCP_TOS (11) 47CCB0C0
*Jul 23 07:51:20.871: TCP514: SNDWND timeout timer expired
*Jul 23 07:51:20.871: TCP514: probe #3 - timeout is 2424 ms, seq 2443417070
*Jul 23 07:51:23.295: TCP514: SNDWND timeout timer expired
*Jul 23 07:51:23.295: TCP514: probe #4 - timeout is 4848 ms, seq 2443417070
*Jul 23 07:51:28.143: TCP514: SNDWND timeout timer expired
*Jul 23 07:51:28.143: TCP514: probe #5 - timeout is 9696 ms, seq 2443417070
*Jul 23 07:51:37.839: TCP514: SNDWND timeout timer expired
*Jul 23 07:51:37.839: TCP514: probe #6 - timeout is 9696 ms, seq 2443417070
*Jul 23 07:51:39.895: //-1/xxxxxxxxxxxx/H323/cch323_process_carrier_update: Registered = 0, Event = 1, Reason = 2
*Jul 23 07:51:41.423: TCP514: probed window opened, resetting RTT
*Jul 23 07:51:41.423: TCP514: timeout #1 - timeout is 606 ms, seq 2443417070
*Jul 23 07:51:49.147: TCB4957941C setting property TCP_TOS (11) 47CCB0C0
*Jul 23 07:51:49.375: TCP0: ACK timeout timer expired
*Jul 23 07:51:50.271: TCB48074AB0 setting property TCP_TOS (11) 47CCB0C0
*Jul 23 07:51:50.503: TCP0: ACK timeout timer expired
*Jul 23 07:52:04.895: //-1/xxxxxxxxxxxx/H323/cch323_process_carrier_update: Registered = 0, Event = 1, Reason = 2
*Jul 23 07:52:19.147: TCB4957941C setting property TCP_TOS (11) 47CCB0C0
*Jul 23 07:52:19.371: TCP0: ACK timeout timer expired
*Jul 23 07:52:20.271: TCB48074AB0 setting property TCP_TOS (11) 47CCB0C0
*Jul 23 07:52:20.499: TCP0: ACK timeout timer expired
Can you tell me what the state of the gateway is on cucm? is it "unknown unknow" or  is it "unknown 10.54.0.1"
Can you also use the test below to check that port 1720 is opened between the cucm and the gateway
ciscogw#telnet 10.50.1.31 1720
you should see something like this if the port is opened
Trying 10.50.1.31 1720 ... Open
[Connection to 10.50.1.31 closed by foreign host]
ciscogw#
From the trace..
We can see that the gateway is sending a synscronisation packet "sending SYN",
we cal also see that cucm is not sending an ACK to the sent packet "ack 0"
Afterwards the gateway closed the connection "state was CLOSED -> SYNSENT [38757 -> 10.50.1.31(1720)]"
Hi Aonkanlawon
the state gateway on CUCM  is "unknown 10.54.0.1" . also i have tried to telnet port 1720 on my call manager and the result is below.
DPSRTR01#telnet 10.50.1.31 1720
Trying 10.50.1.31, 1720 ... Open
DPSRTR01#
does it matter if this voice traffic through the tunelling by mikrotik router?
Try and restart the cucm service and then do a test call again. Please send "debug ip tcp transaction"
Hi Aonkanlawon,
I have tried to restart call manager server and the router site, but the problem is still not resolved. the debug results as same as above.
any idea?
cheers
Hi Aonkanlawon,
This is the debug results.
DPSRTR01#
*Jul 24 04:03:17.007: TCB45B532D8 created
*Jul 24 04:03:17.007: TCB45B532D8 setting property TCP_PID (8) 46787614
*Jul 24 04:03:17.007: TCB45B532D8 setting property TCP_NO_DELAY (1) 46787618
*Jul 24 04:03:17.007: TCB45B532D8 setting property TCP_TOS (11) 46787664
*Jul 24 04:03:17.007: TCB45B532D8 setting property TCP_NONBLOCKING_WRITE (10) 467876A8
*Jul 24 04:03:17.007: TCB45B532D8 setting property TCP_NONBLOCKING_READ (14) 467876A8
*Jul 24 04:03:17.007: TCB45B532D8 setting property TCP keepalive timeout (17) 467876A8
*Jul 24 04:03:17.007: TCB45B532D8 setting property TCP_VRFTABLEID (20) 4910014C
*Jul 24 04:03:17.007: TCB45B532D8 setting property TCP_NO_DELAY (1) 46787664
*Jul 24 04:03:17.007: TCB45B532D8 setting property TCP_ALWAYSPUSH (15) 46787664
*Jul 24 04:03:17.007: TCP: Random local port generated 11132, network 1
*Jul 24 04:03:17.007: TCB45B532D8 bound to 10.54.10.1.11132
*Jul 24 04:03:17.007: Reserved port 11132 in Transport Port Agent for TCP IP type 1
*Jul 24 04:03:17.007: TCP: sending SYN, seq 1679258265, ack 0
*Jul 24 04:03:17.007: TCP0: Connection to 10.50.1.32:1720, advertising MSS 536
*Jul 24 04:03:17.007: TCP0: state was CLOSED -> SYNSENT [11132 -> 10.50.1.32(1720)]
*Jul 24 04:03:17.039: TCP0: state was SYNSENT -> ESTAB [11132 -> 10.50.1.32(1720)]
*Jul 24 04:03:17.039: TCP: tcb 45B532D8 connection to 10.50.1.32:1720, peer MSS 1460, MSS is 536
*Jul 24 04:03:17.275: TCP0: ACK timeout timer expired
*Jul 24 04:03:17.303: TCB45B53834 created
*Jul 24 04:03:17.303: TCB45B53834 setting property TCP_PID (8) 4678732C
*Jul 24 04:03:17.303: TCB45B53834 setting property TCP_NO_DELAY (1) 46787330
*Jul 24 04:03:17.303: TCB45B53834 setting property TCP_TOS (11) 4678737C
*Jul 24 04:03:17.303: TCB45B53834 setting property TCP_NONBLOCKING_WRITE (10) 467873C0
*Jul 24 04:03:17.303: TCB45B53834 setting property TCP_NONBLOCKING_READ (14) 467873C0
*Jul 24 04:03:17.303: TCB45B53834 setting property TCP_VRFTABLEID (20) 4910045C
*Jul 24 04:03:17.303: TCB45B53834 setting property TCP_NO_DELAY (1) 4678737C
*Jul 24 04:03:17.303: TCB45B53834 setting property TCP_ALWAYSPUSH (15) 4678737C
*Jul 24 04:03:17.303: TCP: Random local port generated 17962, network 1
*Jul 24 04:03:17.303: TCB45B53834 bound to 10.54.10.1.17962
*Jul 24 04:03:17.303: Reserved port 17962 in Transport Port Agent for TCP IP type 1
*Jul 24 04:03:17.303: TCP: sending SYN, seq 999338211, ack 0
*Jul 24 04:03:17.303: TCP0: Connection to 10.50.1.32:39143, advertising MSS 536
*Jul 24 04:03:17.307: TCP0: state was CLOSED -> SYNSENT [17962 -> 10.50.1.32(39143)]
*Jul 24 04:03:17.331: TCP0: state was SYNSENT -> ESTAB [17962 -> 10.50.1.32(39143)]
*Jul 24 04:03:17.331: TCP: tcb 45B53834 connection to 10.50.1.32:39143, peer MSS 1460, MSS is 536
*Jul 24 04:03:17.379: TCB45BB036C setting property TCP_TOS (11) 47530680
*Jul 24 04:03:17.499: TCP0: ACK timeout timer expired
*Jul 24 04:03:17.663: TCP0: bad seg from 10.50.1.32 -- outside window: port 17962 seq 4022160242 ack 999338357 rcvnxt 4022160266 rcvwnd 4001 len 24
*Jul 24 04:03:18.687: TCP0: Data repacketized, seq 999338357, sent 54 byte
*Jul 24 04:03:18.687: 10.54.10.1:17962 <---> 10.50.1.32:39143   congestion window changes
*Jul 24 04:03:18.687: cwnd from 681 to 536, ssthresh from 65535 to 1072
*Jul 24 04:03:18.687: TCP0: timeout #1 - timeout is 2566 ms, seq 999338357
*Jul 24 04:03:18.687: TCP: (17962) -> 10.50.1.32(39143)
*Jul 24 04:03:21.255: TCP0: timeout #2 - timeout is 5132 ms, seq 999338357
*Jul 24 04:03:21.255: TCP: (17962) -> 10.50.1.32(39143)
*Jul 24 04:03:21.403: TCP0: state was ESTAB -> FINWAIT1 [11132 -> 10.50.1.32(1720)]
*Jul 24 04:03:21.407: TCP0: sending FIN
*Jul 24 04:03:21.407: TCP0: state was ESTAB -> FINWAIT1 [17962 -> 10.50.1.32(39143)]
*Jul 24 04:03:21.435: TCP0: bad seg from 10.50.1.32 -- Application closed: port 17962 seq 4022160266 ack 999338357 rcvnxt 4022160266 rcvwnd 4001 len 9
*Jul 24 04:03:21.435: TCP: sending RST, seq 999338357, ack 0
*Jul 24 04:03:21.435: Released port 17962 in Transport Port Agent for TCP IP type 1 delay 240000
*Jul 24 04:03:21.435: TCP0: state was FINWAIT1 -> CLOSED [17962 -> 10.50.1.32(39143)]
*Jul 24 04:03:21.435: TCB 0x45B53834 destroyed
*Jul 24 04:03:21.435: TCP0: state was FINWAIT1 -> FINWAIT2 [11132 -> 10.50.1.32(1720)]
*Jul 24 04:03:21.439: TCP0: FIN processed
*Jul 24 04:03:21.439: TCP0: state was FINWAIT2 -> TIMEWAIT [11132 -> 10.50.1.32(1720)]
*Jul 24 04:03:21.439: TCP: sending RST, seq 999338357, ack 0
*Jul 24 04:03:21.439: TCP: sent RST to 10.50.1.32:39143 from 10.54.10.1:17962
*Jul 24 04:03:21.639: TCP0: ACK timeout timer expired
*Jul 24 04:03:21.923: TCB45BB4060 created
*Jul 24 04:03:21.923: TCB45BB4060 setting property TCP_PID (8) 46787614
*Jul 24 04:03:21.923: TCB45BB4060 setting property TCP_NO_DELAY (1) 46787618
*Jul 24 04:03:21.923: TCB45BB4060 setting property TCP_TOS (11) 46787664
*Jul 24 04:03:21.923: TCB45BB4060 setting property TCP_NONBLOCKING_WRITE (10) 467876A8
*Jul 24 04:03:21.923: TCB45BB4060 setting property TCP_NONBLOCKING_READ (14) 467876A8
*Jul 24 04:03:21.923: TCB45BB4060 setting property TCP keepalive timeout (17) 467876A8
*Jul 24 04:03:21.923: TCB45BB4060 setting property TCP_VRFTABLEID (20) 491003EC
*Jul 24 04:03:21.923: TCB45BB4060 setting property TCP_NO_DELAY (1) 46787664
*Jul 24 04:03:21.923: TCB45BB4060 setting property TCP_ALWAYSPUSH (15) 46787664
*Jul 24 04:03:21.923: TCP: Random local port generated 65403, network 1
*Jul 24 04:03:21.923: TCB45BB4060 bound to 10.54.10.1.65403
*Jul 24 04:03:21.923: Reserved port 65403 in Transport Port Agent for TCP IP type 1
*Jul 24 04:03:21.927: TCP: sending SYN, seq 2882556076, ack 0
*Jul 24 04:03:21.927: TCP0: Connection to 10.50.1.31:1720, advertising MSS 536
*Jul 24 04:03:21.927: TCP0: state was CLOSED -> SYNSENT [65403 -> 10.50.1.31(1720)]
*Jul 24 04:03:21.955: TCP0: state was SYNSENT -> ESTAB [65403 -> 10.50.1.31(1720)]
*Jul 24 04:03:21.955: TCP: tcb 45BB4060 connection to 10.50.1.31:1720, peer MSS 1460, MSS is 536
*Jul 24 04:03:22.195: TCP0: ACK timeout timer expired
*Jul 24 04:03:22.223: TCB45BB2DA4 created
*Jul 24 04:03:22.223: TCB45BB2DA4 setting property TCP_PID (8) 4678732C
*Jul 24 04:03:22.223: TCB45BB2DA4 setting property TCP_NO_DELAY (1) 46787330
*Jul 24 04:03:22.223: TCB45BB2DA4 setting property TCP_TOS (11) 4678737C
*Jul 24 04:03:22.223: TCB45BB2DA4 setting property TCP_NONBLOCKING_WRITE (10) 467873C0
*Jul 24 04:03:22.223: TCB45BB2DA4 setting property TCP_NONBLOCKING_READ (14) 467873C0
*Jul 24 04:03:22.223: TCB45BB2DA4 setting property TCP_VRFTABLEID (20) 491001BC
*Jul 24 04:03:22.223: TCB45BB2DA4 setting property TCP_NO_DELAY (1) 4678737C
*Jul 24 04:03:22.223: TCB45BB2DA4 setting property TCP_ALWAYSPUSH (15) 4678737C
*Jul 24 04:03:22.223: TCP: Random local port generated 35568, network 1
*Jul 24 04:03:22.223: TCB45BB2DA4 bound to 10.54.10.1.35568
*Jul 24 04:03:22.223: Reserved port 35568 in Transport Port Agent for TCP IP type 1
*Jul 24 04:03:22.223: TCP: sending SYN, seq 174541042, ack 0
*Jul 24 04:03:22.223: TCP0: Connection to 10.50.1.31:58106, advertising MSS 536
*Jul 24 04:03:22.227: TCP0: state was CLOSED -> SYNSENT [35568 -> 10.50.1.31(58106)]
*Jul 24 04:03:22.255: TCP0: state was SYNSENT -> ESTAB [35568 -> 10.50.1.31(58106)]
*Jul 24 04:03:22.255: TCP: tcb 45BB2DA4 connection to 10.50.1.31:58106, peer MSS 1460, MSS is 536
*Jul 24 04:03:22.419: TCP0: ACK timeout timer expired
*Jul 24 04:03:22.587: TCP0: bad seg from 10.50.1.31 -- outside window: port 35568 seq 4168051269 ack 174541222 rcvnxt 4168051293 rcvwnd 4001 len 24
*Jul 24 04:03:22.663: TCB45BB036C setting property TCP_TOS (11) 47531020
*Jul 24 04:03:22.891: TCP0: ACK timeout timer expired
*Jul 24 04:03:23.607: TCP0: Data repacketized, seq 174541222, sent 54 byte
*Jul 24 04:03:23.607: 10.54.10.1:35568 <---> 10.50.1.31:58106   congestion window changes
*Jul 24 04:03:23.607: cwnd from 715 to 536, ssthresh from 65535 to 1072
*Jul 24 04:03:23.607: TCP0: timeout #1 - timeout is 2566 ms, seq 174541222
*Jul 24 04:03:23.607: TCP: (35568) -> 10.50.1.31(58106)
*Jul 24 04:03:24.099: 10.54.0.1:22 <---> 10.50.5.204:49371   congestion window changes
*Jul 24 04:03:24.099: cwnd from 44421 to 536, ssthresh from 65535 to 8160
*Jul 24 04:03:24.099: TCP515: timeout #1 - timeout is 606 ms, seq 2097625990
*Jul 24 04:03:24.955: TCB45C748A0 setting property TCP_TOS (11) 47531020
*Jul 24 04:03:25.183: TCP0: ACK timeout timer expired
*Jul 24 04:03:26.175: TCP0: timeout #2 - timeout is 5132 ms, seq 174541222
*Jul 24 04:03:26.175: TCP: (35568) -> 10.50.1.31(58106)
*Jul 24 04:03:26.323: TCP0: state was ESTAB -> FINWAIT1 [65403 -> 10.50.1.31(1720)]
*Jul 24 04:03:26.327: TCP0: sending FIN
*Jul 24 04:03:26.327: TCP0: state was ESTAB -> FINWAIT1 [35568 -> 10.50.1.31(58106)]
*Jul 24 04:03:26.331: TCB45B53834 created
*Jul 24 04:03:26.331: TCB45B53834 setting property TCP_PID (8) 46787614
*Jul 24 04:03:26.331: TCB45B53834 setting property TCP_NO_DELAY (1) 46787618
*Jul 24 04:03:26.331: TCB45B53834 setting property TCP_TOS (11) 46787664
*Jul 24 04:03:26.331: TCB45B53834 setting property TCP_NONBLOCKING_WRITE (10) 467876A8
*Jul 24 04:03:26.331: TCB45B53834 setting property TCP_NONBLOCKING_READ (14) 467876A8
*Jul 24 04:03:26.331: TCB45B53834 setting property TCP keepalive timeout (17) 467876A8
*Jul 24 04:03:26.331: TCB45B53834 setting property TCP_VRFTABLEID (20) 491005AC
*Jul 24 04:03:26.331: TCB45B53834 setting property TCP_NO_DELAY (1) 46787664
*Jul 24 04:03:26.331: TCB45B53834 setting property TCP_ALWAYSPUSH (15) 46787664
*Jul 24 04:03:26.331: TCP: Random local port generated 35871, network 1
*Jul 24 04:03:26.331: TCB45B53834 bound to 10.54.10.1.35871
*Jul 24 04:03:26.331: Reserved port 35871 in Transport Port Agent for TCP IP type 1
*Jul 24 04:03:26.331: TCP: sending SYN, seq 44634204, ack 0
*Jul 24 04:03:26.331: TCP0: Connection to 10.50.1.32:1720, advertising MSS 536
*Jul 24 04:03:26.335: TCP0: state was CLOSED -> SYNSENT [35871 -> 10.50.1.32(1720)]
*Jul 24 04:03:26.347: TCP0: bad seg from 10.50.1.31 -- Application closed: port 35568 seq 4168051293 ack 174541222 rcvnxt 4168051293 rcvwnd 4001 len 9
*Jul 24 04:03:26.351: TCP: sending RST, seq 174541222, ack 0
*Jul 24 04:03:26.351: Released port 35568 in Transport Port Agent for TCP IP type 1 delay 240000
*Jul 24 04:03:26.351: TCP0: state was FINWAIT1 -> CLOSED [35568 -> 10.50.1.31(58106)]
*Jul 24 04:03:26.351: TCB 0x45BB2DA4 destroyed
*Jul 24 04:03:26.351: TCP0: state was FINWAIT1 -> FINWAIT2 [65403 -> 10.50.1.31(1720)]
*Jul 24 04:03:26.351: TCP0: FIN processed
*Jul 24 04:03:26.351: TCP0: state was FINWAIT2 -> TIMEWAIT [65403 -> 10.50.1.31(1720)]
*Jul 24 04:03:26.351: TCP: sent RST to 10.50.1.31:58106 from 10.54.10.1:35568
*Jul 24 04:03:26.355: TCP0: state was SYNSENT -> ESTAB [35871 -> 10.50.1.32(1720)]
*Jul 24 04:03:26.359: TCP: tcb 45B53834 connection to 10.50.1.32:1720, peer MSS 1460, MSS is 536
*Jul 24 04:03:26.591: TCP0: ACK timeout timer expired
*Jul 24 04:03:26.619: TCB49406564 created
*Jul 24 04:03:26.619: TCB49406564 setting property TCP_PID (8) 4678732C
*Jul 24 04:03:26.619: TCB49406564 setting property TCP_NO_DELAY (1) 46787330
*Jul 24 04:03:26.619: TCB49406564 setting property TCP_TOS (11) 4678737C
*Jul 24 04:03:26.619: TCB49406564 setting property TCP_NONBLOCKING_WRITE (10) 467873C0
*Jul 24 04:03:26.619: TCB49406564 setting property TCP_NONBLOCKING_READ (14) 467873C0
*Jul 24 04:03:26.619: TCB49406564 setting property TCP_VRFTABLEID (20) 491004CC
*Jul 24 04:03:26.619: TCB49406564 setting property TCP_NO_DELAY (1) 4678737C
*Jul 24 04:03:26.619: TCB49406564 setting property TCP_ALWAYSPUSH (15) 4678737C
*Jul 24 04:03:26.619: TCP: Random local port generated 19387, network 1
*Jul 24 04:03:26.619: TCB49406564 bound to 10.54.10.1.19387
*Jul 24 04:03:26.619: Reserved port 19387 in Transport Port Agent for TCP IP type 1
*Jul 24 04:03:26.619: TCP: sending SYN, seq 1295648503, ack 0
*Jul 24 04:03:26.619: TCP0: Connection to 10.50.1.32:39152, advertising MSS 536
*Jul 24 04:03:26.619: TCP0: state was CLOSED -> SYNSENT [19387 -> 10.50.1.32(39152)]
*Jul 24 04:03:26.643: TCP0: state was SYNSENT -> ESTAB [19387 -> 10.50.1.32(39152)]
*Jul 24 04:03:26.643: TCP: tcb 49406564 connection to 10.50.1.32:39152, peer MSS 1460, MSS is 536
*Jul 24 04:03:26.815: TCP0: ACK timeout timer expired
*Jul 24 04:03:28.111: TCP0: Data repacketized, seq 1295648677, sent 30 byte
*Jul 24 04:03:28.111: 10.54.10.1:19387 <---> 10.50.1.32:39152   congestion window changes
*Jul 24 04:03:28.111: cwnd from 709 to 536, ssthresh from 65535 to 1072
*Jul 24 04:03:28.111: TCP0: timeout #1 - timeout is 2810 ms, seq 1295648677
*Jul 24 04:03:28.111: TCP: (19387) -> 10.50.1.32(39152)
*Jul 24 04:03:30.703: TCP0: state was ESTAB -> FINWAIT1 [35871 -> 10.50.1.32(1720)]
*Jul 24 04:03:30.707: TCP0: sending FIN
*Jul 24 04:03:30.707: TCP0: state was ESTAB -> FINWAIT1 [19387 -> 10.50.1.32(39152)]
*Jul 24 04:03:30.743: TCP0: state was FINWAIT1 -> FINWAIT2 [35871 -> 10.50.1.32(1720)]
*Jul 24 04:03:30.743: TCP0: FIN processed
*Jul 24 04:03:30.743: TCP0: state was FINWAIT2 -> TIMEWAIT [35871 -> 10.50.1.32(1720)]
*Jul 24 04:03:30.923: TCP0: Data repacketized, seq 1295648677, sent 39 byte
*Jul 24 04:03:30.923: 10.54.10.1:19387 <---> 10.50.1.32:39152   congestion window changes
*Jul 24 04:03:30.923: cwnd from 542 to 536, ssthresh from 1072 to 1072
*Jul 24 04:03:30.923: TCP0: timeout #2 - timeout is 5620 ms, seq 1295648677
*Jul 24 04:03:30.923: TCP: (19387) -> 10.50.1.32(39152)
*Jul 24 04:03:33.867: TCP0: bad seg from 10.50.1.32 -- Application closed: port 19387 seq 4032397819 ack 1295648683 rcvnxt 4032397819 rcvwnd 4025 len 24
*Jul 24 04:03:33.867: TCP: sending RST, seq 1295648683, ack 0
*Jul 24 04:03:33.867: Released port 19387 in Transport Port Agent for TCP IP type 1 delay 240000
*Jul 24 04:03:33.867: TCP0: state was FINWAIT1 -> CLOSED [19387 -> 10.50.1.32(39152)]
*Jul 24 04:03:33.867: TCB 0x49406564 destroyed
*Jul 24 04:03:52.663: TCB45BB036C setting property TCP_TOS (11) 47531020
*Jul 24 04:03:52.891: TCP0: ACK timeout timer expired
*Jul 24 04:03:54.327: TCP515: keepalive timeout (0/4)
*Jul 24 04:03:54.955: TCB45C748A0 setting property TCP_TOS (11) 47531020
*Jul 24 04:03:55.191: TCP0: ACK timeout timer expired
