Display All External Phone Number Mask
ctalavat
How am I able to see every single external phone number mask on CUCM?
11 Replies 11
You would have to export all of the directory numbers for that and then open the CSV file in Excel.
Response Signature
How would I go about doing that?
In the Bulk Administration menu.
Response Signature
I see a lot of different options now under Bulk Administration menu.  I'm not familiar with these options.
I’m sure that with a minimum amount of effort on your end you can figure it out. You’ll not learn anything if you get it served up on a platter. If you get stuck please get back to the post and we’ll point you in the right direction
Response Signature
you can run the SQl command i shared from CLI and you get the Mask configured with extensions.
Response Signature
Try the below from cli
run sql select dnorpattern, d.description, e164mask, tkpatternusage from devicenumplanmap  inner join numplan on fknumplan=numplan.pkid  join device d on fkdevice = d.pkid
Response Signature
Can I do this on the GUI?
Ssh to CUCM IP, Login using  os admin password and run the command. Copy that to text and import to excel.
Response Signature
Go to Bulk Administration > Import/Export > Export, then select Phone.
Response Signature
Thanks for the guidance.
