Bookmark
Subscribe
468
Display on Ip phone duplicated
rynard.coetzee
Problem i have is that i have a CUCM 6.1 with a SIP trunk to a 3rd Party Telco ,the calls work fine across the trunk but when i force the trunk to use MTP the following happens on the display of the phone ,it will display To 0823333333
        (0823333333)
So it displays a duplicate of the number in brackets.
If i turn off the MTP it does not duplicate the number anymore ,but there seems to be an issue with the progress messages ,as the phone display will show "connected" when the far end is still only ringing. Is there any way around this ?
0 Replies 0
