Displaying numbers pressed on screen
Live2 Bicycle
Level 3
Level 3
After a call is connected if you press any of the number keys the numbers do not display.  Is there a setting in call manager to turn this on?  I have gone through the admin and system guide and have not found a reference to this.
Thanks in advance.
2 Accepted Solutions
Jaime Valencia
Unfortunately that's not something you can configure. Once the call is connected the DTMFs are sent but they won't show up in the LCD screen after the DN you dialed.
If you feel this should be a feature, get in touch with your AM and ask him about submitting a PER on this.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Aaron Harrison
I had this request once; there was no way to do it then, and I'm not aware of anything changing since...
You see the dialed/connected number, not the DTMF you send afterwards...
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Jaime Valencia
java
java
Aaron Harrison
Aaron
