Does CME 4.1 Supports 9971??? | I m Not able to register this Phone even though i download 9971 files to flash
Ibrahim Jamil
Level 6
Level 6
Hi Freinds
Does CME 4.1 Supports 9971 ?? I m Not able to register this Phone even though i download 9971 files to flash , any recomendation
thanks all
Ibrahim
5 Replies 5
Ratheesh Kumar
Hi there
Unfortunately Not !
9971 required a minimum of CME 8.6
Hope this helps
Cheers
Rath!
***Please rate helpful posts***
Hi Rath
thanks
R0g22
Why are you even running CME 4.1 ? That is EXTINCT and should not be used.
Hi Nipun
I m Learning CVoice bro , using GNS3 , seems only CME 4.1 works there , 8.6 do not support GNS3 router
thanks a lot
Ibrahim
Why not rent some rack time from INE ? That would be better. No use of practicing on an outdated system anyways since a lot has changed since the 4.X days. You should at least have CME 10.0 or higher.
