Does NIM-1CE1T1-PRI have a RJ-45 port or RJ-48 port ?
Takuro Moriyama
Dear Expert,
I'm confirming a NIM-1CE1T1-PRI's physical port.
Which port does NIM-1CE1T1-PRI have, RJ-45 or RJ-48 ?
Image are below:
[NIM-1CE1T1-PRI]=RJ45========[DSU]
OR
[NIM-1CE1T1-PRI]=RJ48========[DSU]
Please tell me more if you know about it.
Best regards,
takuro.
Suresh Hudda
You can connect either one of them depending on the situation and how they need to be used, both are supported as both have same modular connectors.
Suresh
