Doubt about Caller ID
wilsonsant
Level 6
Level 6
Hi Guys,
My Customer have the solution with CUCM 10.5.2 and 06 sites running SIP protocol. The Customer changed the protocol, previouly were H.323 and now it running SIP with change range Phone number. In any sites the Caller ID that is appearing is the old number. The Carrier informed that forward the number that my network send for They. My question is: Where I see in the gateway what number is send for the Carrier.
Wilson
13 Replies 13
debug ccsip messages  will show you the signaling exchange between CUCM and your router, and your router and the carrier.
You mention that you have changed phone numbers with the change in carrier. Did you reconfigure the External Phone Number Mask on the Phone-Dn for your users? (And/Or transformation patterns if you are doing Globalized Call Routing?)
Hi Marren,
Thanks a lot for Your contact. Unfortunatelly my profile not allow run debug.
About External Phone Number Mask are blank for all extensions.
About transformation patterns if you are doing Globalized Call Routing. The answer is yes
Thank You,
Wilson
OK. Since you are doing Globalized Call Routing, have the transformation patterns used by the SIP Trunk been adjusted to reflect the new DIDs with the new carrier?
These would be the Calling Party Transformation patterns indicated in the Outbound Call Routing section of your SIP Trunk. On the trunk, look at Outbound Cal Routing > Calling Party Transformation CSS. Backtrack and figure out which set of transformation patterns are in that CSS. Are they set to the new DNs?
And, yes, please also post the config of your router. It may be that the router is doing the old-numbering digit manipulation.
Jaca
You might be able to use debug isdn q931
Add a debug condition to limit the output if you use it
Something like:
voicegate# term mon
voicegate# debug condition called 7895551212
voicegate# debug isdn q931
after the capture:
voicegate# term no mon
voicegate# u all
The called number can be your cell phone.
You can also look at RTMT logs and CDR from CM, but instant information will come from the debug.
The debug ccsip messages will work even better if you don't have a trunk to the PSTN.
Here is a Cisco Command Reference guide for SIP debug conditions and output filtering:
http://docwiki.cisco.com/wiki/Cisco_IOS_Voice_Troubleshooting_and_Monitoring_--_SIP_Debug_Output_Filtering_Support
Hi Jaca,
Thanks a lot for Your contact. Unfortunatelly my profile don´t have permission to run debug.
About RTMT what logs that I set will show this?
Very usual the link that You send. Thank You
Wilson
Once you have RTMT up and running go to:
Voice/Video || Session Trace Log View || Real Time Data
Add the number called and the date and time.
I see from your other posts you have no CLID set within CM. You may have a translation within the gateway sending outbound, but with no running configuration I'm just guessing.
Hi Jaca,
About RTMT that You mentioned: Voice/Video || Session Trace Log View || Real Time Data, it show the calling number - originate number, but, the when called receive that the calling number show is different.
About translation between CUCM and Gateway, in the CUCM there are not this translation. As I see in the gateway?
Wilson
Post the configuration of the gateway that holds the trunk in question please.
R0g22
Post your router config. Do a DNA on CUCM for an outbound number so that we can see what is the CLID being extended. That way we can tie it to any potential translations on the GW that might be taking affect since you cannot take a debug.
Hi Nipun,
Thanks a lot for Your contact. Follow the gateway config
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2018.04.20 16:11:34 =~=~=~=~=~=~=~=~=~=~=~=
sh run
Building configuration...
Current configuration : 14688 bytes
! Last configuration change at 19:00:54 GMT Thu Apr 19 2018 by us_bdavidson
version 15.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
hostname XPTO_BR500_VGW
boot-start-marker
boot system flash c2951-universalk9-mz.SPA.154-3.M5.bin
boot-end-marker
! card type command needed for slot/vwic-slot 0/1
logging queue-limit 10000
logging buffered 10000000
logging rate-limit 10000
enable secret 5 $1$0/Aw$7X8JB2hhHEqmtI/UcdUNW.
aaa new-model
aaa authentication login default group tacacs+ local
aaa authentication enable default group tacacs+ enable
aaa authentication ppp default local
aaa authorization config-commands
aaa authorization exec default group tacacs+ local if-authenticated
aaa authorization commands 15 default group tacacs+ none
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 15 default stop-only group tacacs+
aaa session-id common
clock timezone GMT -3 0
no ip source-route
no ip bootp server
no ip domain lookup
ip domain name XPTO.com
ip cef
no ipv6 cef
trunk group PSTN
 hunt-scheme round-robin both up
 translation-profile incoming PSTN-IN
 translation-profile outgoing PSTN-OUT
cts logging verbose
voice-card 0
 dspfarm
 dsp services dspfarm
voice call send-alert
voice rtp send-recv
voice service pots
 fax rate disable
voice service voip
 ip address trusted list
  ipv4 192.168.104.2
  ipv4 192.168.104.1
  ipv4 10.64.0.8
 mode border-element
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 fax protocol t38 nse force version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711ulaw
 modem passthrough nse codec g711ulaw
 sip
  session transport tcp
  min-se 2400 session-expires 2400
  registrar server expires max 600 min 60
  asserted-id pai
  midcall-signaling passthru
  g729 annexb-all
  sip-profiles 1
voice class codec 1
 codec preference 1 g711ulaw
 codec preference 2 g711alaw
 codec preference 3 g729r8
voice class sip-profiles 1
 request ANY sdp-header Audio-Attribute modify "a=inactive" "a=sendrecv"
 request REINVITE sdp-header Audio-Attribute modify "a=sendonly" "a=sendrecv"
 request ANY sdp-header Audio-Attribute modify "a=sendonly" "a=sendrecv"
voice class e164-pattern-map 1
 description CARRIER  - BR500 DID Ranges
  e164 +337338344704
  e164 +6622723095..
  e164 +6622424285[0-4].
  e164 +6622681697[4-9].
voice class e164-pattern-map 2
 description CARRIER - BRA DID Ranges
  e164 723095..
  e164 681697[4-9].
  e164 85[0-4].
  e164 95..
  e164 97[4-9].
voice register global
 mode srst
 timeouts interdigit 5
 system message WAN Outage - Fallback Mode
 max-pool 250
voice register pool  1
 translation-profile incoming SRST-IN
 id network 10.0.0.0 mask 233.0.0.0
 dtmf-relay rtp-nte sip-notify
 voice-class codec 1
 no vad
voice translation-rule 10
 rule 1 /^\([2-5].......\)$/ /+6622\1/
 rule 2 /^\([79][6-9].......\)$/ /+6622\1/
 rule 3 /^\([1-9][1-9][2-9].......\)$/ /+33\1/
 rule 4 /^\([1-37-9][1-9][79]........\)$/ /+33\1/
 rule 5 /^\00\(.*\)$/ /+\1/
 rule 6 /^\(.*\)$/ /+\1/
voice translation-rule 20
 rule 1 /^\(97..\)$/ /+66226816\1/
 rule 2 /^\(8...\)$/ /+66224242\1/
 rule 3 /^\(68169...\)$/ /+6622\1/
 rule 4 /^\(95..\)$/ /+66227230\1/
 rule 5 /^\(723095..\)$/ /+6622\1/
voice translation-rule 30
 rule 2 /.*/ /8500/
 rule 3 /^\+.*/ /8500/
voice translation-rule 40
 rule 2 /^0\([2-9].......\)$/ /\1/
 rule 3 /^0\([79]........\)$/ /\1/
 rule 4 /^0\(19.\)$/ /\1/
 rule 5 /^0\(181\)$/ /\1/
 rule 6 /^0\(911\)$/ /\1/
 rule 7 /^0\(112\)$/ /\1/
 rule 8 /^00\([1-9][1-9][2-9].......\)$/ /076\1/
 rule 9 /^00\([1-9][1-9][2-9]........\)$/ /076\1/
 rule 10 /^00\([4-6][1-9]9[6-9].......\)$/ /076\1/
 rule 11 /^00\([1-37-9][1-9][79]........\)$/ /076\1/
 rule 12 /^00\([38]00.......\)$/ /0\1/
 rule 13 /^000\([1-9].*\)$/ /0076\1/
 rule 14 /^0\(.*\)$/ /\1/
voice translation-rule 50
 rule 1 /^\(97[4-9].\)$/ /+66226816\1/
 rule 2 /^\(329.\)$/ /+33335284\1/
 rule 3 /^\(8[78]..\)$/ /+33338526\1/
 rule 4 /^0$/ /+662268169740/
voice translation-rule 60
 rule 11 /^\+6622\([2-9].......\)/ /0\1/
 rule 12 /^\+6622\([79]........\)/ /0\1/
 rule 13 /^\+33\([1-9][1-9][2-9].......\)/ /00\1/
 rule 14 /^\+33\([1-37-9][1-9][79]........\)/ /00\1/
 rule 15 /^\+\([1-9].*\)/ /000\1/
voice translation-profile NOPLUS-IN
 translate called 60
voice translation-profile PSTN-IN
 translate calling 10
 translate called 20
voice translation-profile PSTN-OUT
 translate calling 30
 translate called 40
voice translation-profile SRST-IN
 translate called 50
license udi pid CISCO2951/K9 sn FJC2020A0PU
license accept end user agreement
license boot module c2951 technology-package uck9
hw-module pvdm 0/0
hw-module sm 1
username cbnetsvc password 7 08707D6F334B12040A
redundancy
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 description UPLINK TO DMZ-SW
 ip address 10.46.30.5 233.233.233.0
 duplex auto
 speed auto
interface GigabitEthernet0/1
 description UPLINK TO SIP SERVICE
 ip address 10.74.3.250 233.233.233.252
 duplex auto
 speed auto
interface GigabitEthernet0/2
 no ip address
 shutdown
 duplex auto
 speed auto
interface GigabitEthernet0/0/0
 no ip address
 shutdown
 duplex auto
 speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 10.46.30.1
ip route 176.16.0.102 233.233.233.233 10.24.3.249
ip route 10.24.3.249 233.233.233.233 GigabitEthernet0/1
ip tacacs source-interface GigabitEthernet0/0
ip ssh time-out 60
ip ssh version 2
ip access-list standard SNMP_SERVERS
 permit 176.17.240.170
 permit 176.15.18.16
 permit 176.17.104.5
 permit 176.15.18.17
 permit 176.15.18.15
 permit 176.17.241.197
 permit 176.17.223.27
 permit 176.17.226.14
 permit 176.17.240.8
 permit 176.17.240.76
 permit 176.17.241.68
 permit 176.17.241.67
 permit 176.17.198.80 0.0.0.15
 deny   any log
ip access-list extended BOX
 permit ip any 45.58.64.0 0.0.15.233
 permit ip 45.58.64.0 0.0.15.233 any
ip access-list extended DROPBOX
 permit ip any 72.21.80.0 0.0.15.233
 permit ip 72.21.80.0 0.0.15.233 any
ip access-list extended PCAP_ACL
 permit ip any any
ip access-list extended WIRELESS-DATA
 permit udp any any eq 5247
 permit udp any eq 5247 any
logging trap notifications
logging source-interface GigabitEthernet0/0
logging host 176.17.206.60
logging host 176.17.105.85
nls resp-timeout 1
cpd cr-id 1
snmp-server community h0tsauce RO SNMP_SERVERS
snmp-server community gr33n RO SNMP_SERVERS
snmp-server community ch1ll1 RW SNMP_SERVERS
snmp-server ifindex persist
snmp-server location XPTO, Brazil
snmp-server system-shutdown
snmp-server enable traps tty
snmp-server enable traps syslog
tacacs-server host 176.17.198.120
tacacs-server host 176.15.18.13
tacacs-server directed-request
tacacs-server key 7 111D1A061E1406
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
sccp local GigabitEthernet0/0
sccp ccm 192.168.104.1 identifier 2 version 7.0
sccp ccm 192.168.104.2 identifier 1 version 7.0
sccp
sccp ccm group 1
 bind interface GigabitEthernet0/0
 associate ccm 1 priority 1
 associate ccm 2 priority 2
 associate profile 1 register BRA_BR500_CFB
 associate profile 2 register BRA_BR500_XCODE
 associate profile 3 register BR500_711U_MTP
 associate profile 4 register BR500_711A_MTP
 associate profile 5 register BR500_729R8_MTP
 keepalive retries 5
 switchover method immediate
 switchback method immediate
 switchback interval 15
dspfarm profile 2 transcode
 codec g729abr8
 codec g729ar8
 codec g711alaw
 codec g711ulaw
 codec g729r8
 codec g729br8
 maximum sessions 26
 associate application SCCP
dspfarm profile 1 conference
 codec g729br8
 codec g729r8
 codec g729abr8
 codec g729ar8
 codec g711alaw
 codec g711ulaw
 maximum sessions 28
dspfarm profile 3 mtp
 codec g711ulaw
 maximum sessions software 100
dspfarm profile 4 mtp
 codec g711alaw
dspfarm profile 5 mtp
 codec g729r8
dial-peer voice 150 voip
 preference 1
 session protocol sipv2
 session target ipv4:192.168.104.2
 destination e164-pattern-map 1
 voice-class codec 1
 dtmf-relay rtp-nte
 fax rate 14400
 fax protocol pass-through g711ulaw
 no vad
dial-peer voice 250 voip
 preference 2
 session target ipv4:192.168.104.1
 voice-class codec 1
 dtmf-relay rtp-nte
 fax rate 14400
 no vad
dial-peer voice 9911 voip
 description Outbound calls to PSTN
 preference 1
 destination-pattern 0911$
 session target ipv4:176.16.0.102
 incoming called e164-pattern-map 2
 voice-class codec 1
 voice-class sip dtmf-relay force rtp-nte
 dtmf-relay rtp-nte
 no vad
dial-peer voice 100 pots
 tone ringback alert-no-PI
 description Inbound calls from PSTN
 incoming called-number .
 direct-inward-dial
dial-peer voice 9112 voip
 preference 1
 destination-pattern 0112$
 voice-class codec 1
 dtmf-relay rtp-nte
 no vad
dial-peer voice 9192 voip
 preference 1
 destination-pattern 019.$
 voice-class codec 1
 dtmf-relay rtp-nte
 no vad
dial-peer voice 9181 voip
 preference 1
 destination-pattern 0181$
 voice-class codec 1
 dtmf-relay rtp-nte
 no vad
dial-peer voice 1000 voip
 description Outbound calls from UCM
 translation-profile incoming NOPLUS-IN
 incoming calling e164-pattern-map 1
 voice-class codec 1
 dtmf-relay rtp-nte
 no vad
dial-peer voice 110 voip
 destination-pattern 0T
 session transport udp
 voice-class codec 1
 voice-class sip early-offer forced
 voice-class sip profiles 1
 voice-class sip profiles 1 inbound
 voice-class sip bind control source-interface GigabitEthernet0/1
 voice-class sip bind media source-interface GigabitEthernet0/1
 dtmf-relay rtp-nte
 no vad
dial-peer voice 1001 voip
 description Inbound calls from CARRIER
 voice-class codec 1
 dtmf-relay rtp-nte
 no vad
sip-ua
 retry invite 2
 timers trying 300
 g729-annexb override
gatekeeper
 shutdown
call-manager-fallback
 max-conferences 16 gain -6
 transfer-system full-consult
 ip source-address 10.96.30.5 port 2000
 max-ephones 75
 max-dn 150 dual-line
 system message primary WAN Outage - Fallback Mode
XPTO_BR500_VGW#
XPTO_BR500_VGW#
XPTO_BR500_VGW#
You have translation profiles on your dial peers.
You may want to do a show voice call stat to see what your in/out dial peers are and check them against these dial peers:
Which all have your xlate profile outgoing hitting rule 30 and 40
From your config and without knowing your dialed number this would be a good starting point:
trunk group PSTN
translate called 40
rule 2 /.*/ /8500/
On these dial peers:
You can also test your translation rule like such,
test voice translation rule 40 7408881212
and you'll get something back like:
pbx-router#test voice translation-rule 40 7408881212
Matched with rule 12
Original number: 2694003        Translated number: 0117408881212
Original number type: none      Translated number type: none
Original number plan: none      Translated number plan: none
Here's Cisco documentation on testing voice translation rules:
https://www.cisco.com/c/en/us/support/docs/voice/call-routing-dial-plans/61083-voice-transla-rules.html
Hi Jaca,
Sorry by long delay in answer. Unfortunatelly my profile don´t privilegius to run the command: test voice-translation-rule x
Wilson
