Doubt about MCS 78XX Hardware
wilsonsant
Level 6
Level 6
Hi Guys,
I have the following doubt: I need to do upgrade version 4.1 to 5.1 to be using in the laboratory. I have the 03 machines
MCS-7815-I1
MCS-7825-H2
MCS-7815-I2
The link: http://www.cisco.com/en/US/partner/prod/collateral/voicesw/ps6788/vcallcon/ps556/prod_end-of-life_notice0900aecd807329a8.html
show the MCS-7825SE.
My question is: It´s possible using any hardware informed to do the upgrade 4.1 to 5.1? I know the signficate I = IBM  H= HP, and SE?
Wilson Santana
2 Accepted Solutions
Rob Huffman
Hi Wilson,
The 7825H2 should work
This is the "master" list for Server support, which does show support for your box in CUCM 5.1(x);
Supported Cisco Unified Communications Manager Releases by Server
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/ps5748/ps378/prod_brochure0900aecd8062a4f9.html
Hope this helps!
Rob
Cudos to Rob, as usual.  High five (points, that is).  The SE designation that you asked about is an old server platform which was basically a custom MCS configuration geared towards small customers (less than 100 users, typically).  I don't recall if SE was the obvious designation of "Special Edition" or if it was short for "Small Business Edition" - not equivalent to today's CUCM BE but just simply being hardware geared towards small deployments like I noted above.
Of all the versions of CUCM that have come out, 5x was the first and likely the worst so I am curious as to what's driving you to want to test CUCM 5x in your lab.  If it's a matter of "this is what my hardware can support" then that would be one thing especially if it's just a lab.  However, I would not consider that version of code as an upgrade path for a production system running 4x.
Hailey
Please rate helpful posts!
Rob Huffman
Hi Wilson,
Hope this helps!
Rob
Hailey
