Doubt about token in CUCM 8.6
wilsonsant
Level 6
Level 6
Hi Guys,
My Customer have a solution with CUCM 7.1.3 and is planning to do upgrade to version 8.6. The doubt is: Is it possible use the same token that He already use in the version 7.1.3 or is it necessary bought new token to apply in the CUCM version 8.6?
Wilson
Joseph Martini
You can use the same tokens as many times as you want, and the same tokens work with CUCM versions 4.3+ so they will work with 7.1.3 and 8.6.
Hi Joe,
Is there any documenation informing about this?
Wilson
There isn't, but then again there is no documentation saying you cannot either, it's a common thing we see in TAC and do in the lab all the time.
