Doubts about FXO and FXS ports
ciscolover
Hi all,
I'm learning about IP telephony and I have some doubts.
I think that when you connect to an analog fax, phone or modem you need to configure a FXS port. When you connect to a PBX systen or PSTN you use too this tipe of configuration... I talk about analog conections.
My doubt is:
If you connect using a digital port to the pstn you need to specifi too if its a FXS connection or FXO connection? Or FXS and FXO are used only to analog ports?
Thanks all ¡¡¡
8 Replies 8
Adrian Saavedra
Level 7
Level 7
FXO and FXS are analog ports. You use FXO for PSTN and FXS for analog phones, fax and modem.
PRI are digital circuits for PSTN and you use T1/E1 cards.
Hope to help, please remember to rate the post if it does.
Rgds,
Adrian.
Hi Extra,
FXS and FXO are Analog Port. If your Carrier installed a Digital line you will need a T1, E1 or BRI card.
Please remember to rate useful posts clicking on the stars below.
Favor calificar todos las respuestas útiles dando click en las estrellas de mas abajo.
___________________________________________
LinkedIn Profile: do.linkedin.com/in/leosalcie
__________________________________________________
Thanks for your reply,
If FXS and FXO are an Analog ports what is the meaning of the following command?¿
ds0-group 1 timeslots 1-24 type fxo-loop-start
You type fxo-loop-start, or fxs etc..
Hi Extra,
These are the difference:
An FXS device receives a call by . . .
1) Detecting the line has been seized (the attached telephone–FXO device–has gone off hook)
2) Receiving Dual-Tone Multi-Frequency (DTMF) digits indicating how the call should be routed.
Line Power FXS devices supply approximately 50 volts DC power to the line. During an
emergency, FXO devices can use FXS line voltage for power in order to remain operable in the event of a local electrical power failure.
An FXO device initiates a call by . . .
1) Going off-hook to seize the telephone line.
2) Dialing the Dual-Tone Multi-Frequency (DTMF) digits, which identify the destination to be called.
An FXO device receives a call by . . .
1) Detecting the ring voltage supplied by the FXS device (VoIP Gateway, PBX, etc.).
2) Going off-hook to answer the call.
You use that command when configuring T1 CAS trunks. Unlike ISDN, T1 CAS circuits use in-band signaling (information is carried along with voice in each channel).
Signaling on CAS circuits are the same as analog, passed over T1 circuits by emulating the methods (loop-start, ground-start, and E&M).
- Adrian.
Ok,
FXO and FXS ports are for analog conections. In some cases you need to determine the tipe of signaling method on a digital circuit and this signaling method can be FXO xxxx or FXS xxxxx.
Is this correct? Thanks all.
FXO and FXS are for analog connection but they are not use for digital circuit (T1, E1, BRI). For analog circuit you need to select what kind of signaling use, for most cases for a FXO Line you will need to use FXS signaling and for FXS line you will need to use FXO signaling
Rob Huffman
Hi there,
I just thought I would add this to the good info from both Adrian and Leo (+5 each). I can't find
the Cisco doc that had this info anymore.......
Analog Telephony Protocols
Analog  telephony signaling, the original signaling protocol, provides the  method for connecting or disconnecting calls on analog trunks. By using  direct current (DC) over two-wire or four-wire circuits to signal  on-hook and off-hook conditions, each analog trunk connects analog  endpoints or devices such as a PBX or analog phone.
To  provide connections to legacy analog central offices and PBXs, Cisco  CallManager uses analog signaling protocols over analog trunks that  connect voice gateways to analog endpoints and devices . Cisco  CallManager supports these types of analog trunk interfaces:
Foreign Exchange Office (FXO) Analog trunks that connect a gateway to a central office (CO) or private branch exchange (PBX).
Foreign  Exchange Station (FXS) Analog trunks that connect a gateway to plain  old telephone service (POTS) device such as analog phones, fax machines,  and legacy voice-mail systems.
FXS and FXO Interfaces
An  FXS interface connects the router or access server to end-user  equipment such as telephones, fax machines, or modems. The FXS interface  supplies ring, voltage, and dial tone to the station and includes an  RJ-11 connector for basic telephone equipment, keysets, and PBXs.
An  FXO interface is used for trunk, or tie line, connections to a PSTN CO  or to a PBX that does not support E&M signaling (when local  telecommunications authority permits). This interface is of value for  off-premise station applications. A standard RJ-11 modular telephone  cable connects the FXO voice interface card to the PSTN or PBX through a  telephone wall outlet.
FXO  and FXS interfaces indicate on-hook or off-hook status and the seizure  of telephone lines by one of two access signaling methods: loop start or  ground start. The type of access signaling is determined by the type of  service from the CO; standard home telephone lines use loop start, but  business telephones can order ground start lines instead.
Loop-start  is the more common of the access signaling techniques. When a handset  is picked up (the telephone goes off-hook), this action closes the  circuit that draws current from the telephone company CO and indicates a  change in status, which signals the CO to provide dial tone. An  incoming call is signaled from the CO to the handset by sending a signal  in a standard on/off pattern, which causes the telephone to ring.
Loop-start  has two disadvantages, however, that usually are not a problem on  residential telephones but that become significant with the higher call  volume experienced on business telephones. Loop-start signaling has no  means of preventing two sides from seizing the same line simultaneously,  a condition known as glare. Also, loop start signaling does not provide  switch-side disconnect supervision for FXO calls. The telephony switch  (the connection in the PSTN, another PBX, or key system) expects the  router's FXO interface, which looks like a telephone to the switch, to  hang up the calls it receives through its FXO port. However, this  function is not built into the router for received calls; it only  operates for calls originating from the FXO port.
Another  access signaling method used by FXO and FXS interfaces to indicate  on-hook or off-hook status to the CO is ground start signaling. It works  by using ground and current detectors that allow the network to  indicate off-hook or seizure of an incoming call independent of the  ringing signal and allow for positive recognition of connects and  disconnects.
Cheers!
Rob
"go easy...step lightly...stay free "
- The Clash
