DRS backup without subscriber.
tetsuo.kawakami
Hi, I would like to take the customer's cucm DRS backup data to restore it into my lab system.
The customer does not allow me to connect my PC running SFTP server to their network, due to security control.
But they say ok if I connect the PC to the publisher directry after removing the publisher from network and the subscribers.
Can I take the backup correctly without problems for the customer's phone system?
Also after backing the publisher to network?
Thank you for your advice.
Kawakami from Japan.
3 Accepted Solutions
Gordon Ross
Level 9
Level 9
You can't select to just backup one node. You backup the whole cluster. If you pull the master off the network and try to back it up, the backup will hang (or crash out) as it can't access the Subs.
GTG
Please rate all helpful posts.
Yes, that should work.
GTG
nikshah
Hi Kawakami,
BAT can help you if you dont want to take screen captures. Take a BAT export of phones , rp's tp's etc.
Niket
7 Replies 7
Gordon Ross
Level 9
Level 9
GTG
Ross-san,
Thank you for your quick answer. Then it seem to have to write it down into my notebook.
Any way I appreciate your cooperation.
tetsuo.kawakami
Ross-san,
May I beg your another advice?
Can I complete it without problem if I take screen captures for cucm adminisrations instead of DRS backup, connecting PC directly to the publisher removed out of network?
Kawakami
GTG
Ross-san,
Thank you for your quick answer again. I understood.
Best regards,
Kawakami
nikshah
Hi Kawakami,
Niket
Hi Niket-san, Thank you for the advice. The customer's cucm is 5.1. So I think I can run BAT for phone and user records and take screen captures for the other information. Anyway your supplementary advice would be appreciated.
Best regards,
Kawakami
