DSP for services & voice calls
raja Saravanan
Dear Friends,
What is the difference between DSP for voice calls & services ?
When I buy a VWIC card does it have DSP's on it, how do I configure it for voice calls and services ?
Does the command voice-card refer to the DSP's on the VWIC card ?
how do I configure DSP's on mother board?
Does DSP's used for voice calls ( not services ) register with call manager ?
Please advise...
Cheers,
Shaggy
Chris Deren
Check out this post for explnation of dspfarm services vs. dspfarm
https://supportforums.cisco.com/thread/274844
voice-card refers to a module on a router, voice-card 0 means the motherboard and applies to both dspfarm and dspfarm services
Config examples on the above thread as well as many, many other trheads and cisco docs, just search for dspfarm
No, the circuit/port may register if MGCP is used.
HTH,
Chris
Chris Deren
HTH,
Chris
