03-16-2018 08:33 AM - edited 03-17-2019 12:26 PM
Is there a Specific command I can run on a router to determine if the DSP is not working properly and maybe bad?
Router model: 2901
IOS ver: 15.4(3)M8
03-16-2018 08:43 AM
There are few test CLIs which you can use.
Check this link for an earlier discussion regarding the same,
HTH !
Rohan
03-16-2018 08:58 AM
I ran through what it said but i'm not sure. Here is the output: FYI we have a single PVDM3-16 in PVDM slot 0
"router"#test voice driver
Enter Voice NM slot number : 0
C29xx/C39xx Debugging Section;
1 - FPGA Registers Read/Write
2 - 5510 DSP test
3 - DSPRM test
5 - IOCTRL TDM Registers Read/Write
6 - IOCTRL HDLC Registers Read/Write
7 - IOCTRL TDM Memory Read/Write
8 - get conn store address
9 - TDM PLL Read/Wrire
10 - SP2600 DSP test
11 - Quit
Select option : 2
5510 DSP Testing Section:
1 - Reset ALL DSPs
2 - Reset 1 DSP
3 - Download DSPware
4 - CHPIR Enable/Disable
5 - Display c5510 ring
6 - Show HPI RAM
8 - Show Controller
9 - c5510 Keepalive Enable/Disable
10 - Download bootloader using indirect slave access
11 - Write HPI RAM
13 - DSP application download
14 - faked dsp crash
15 - Wait in Firmware Restart Indication
16 - Display DSP Keepalive Status
17 - QUIT
Select option : 16
DSP Keepalive Status Display:
DSP 1 is Alive, State: 4, Keepalive Sent: 1182626, Skip 0
DSP 2 Not Exist
DSP 3 Not Exist
DSP 4 Not Exist
DSP 5 Not Exist
DSP 6 Not Exist
DSP 7 Not Exist
DSP 8 Not Exist
DSP 9 Not Exist
DSP 10 Not Exist
DSP 11 Not Exist
DSP 12 Not Exist
03-16-2018 10:38 AM
03-16-2018 10:28 AM
Hi give "sh voice dsp group all" below is a Good thread to understand its outputs. The "state" will show the status of the DSP
