DSP out of resources
khaled-fahmy
i have an issue with dsp it affects my outbound calls to pstn  and my internal calls though h323 trunk to avaya system it gives randomly fast busy tone i used rtmt it gives that there is out of resources i can't catch the issue when i debug i get disconnect cause 47
sccp local GigabitEthernet0/0
sccp ccm 192.168.6.31 identifier 1 version 7.0 --gateway
sccp ccm 192.168.6.21 identifier 3 version 6.0 -- sub (where call manager service is active)
sccp ccm 192.168.6.20 identifier 2 version 6.0 --- publisher(call manager service not active)
sccp
sccp ccm group 2
associate ccm 2 priority 1
associate ccm 3 priority 2
associate profile 2 register xcoder2
sccp ccm group 1
associate ccm 1 priority 1
associate profile 1 register gwcoder
dspfarm profile 1 transcode
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
output of sh sccp :
SCCP Admin State: UP
Gateway Local Interface: GigabitEthernet0/0
IPv4 Address: 192.168.6.31
Port Number: 2000
IP Precedence: 5
User Masked Codec list: None
Call Manager: 192.168.6.20, Port Number: 2000
Priority: N/A, Version: 6.0, Identifier: 2
Trustpoint: N/A
Call Manager: 192.168.6.21, Port Number: 2000
Priority: N/A, Version: 6.0, Identifier: 3
Trustpoint: N/A
Call Manager: 192.168.6.31, Port Number: 2000
Priority: N/A, Version: 7.0, Identifier: 1
Trustpoint: N/A
Transcoding Oper State: ACTIVE - Cause Code: NONE
Active Call Manager: 192.168.6.21, Port Number: 2000
TCP Link Status: CONNECTED, Profile Identifier: 2
Reported Max Streams: 20, Reported Max OOS Streams: 0
Supported Codec: g729r8, Maximum Packetization Period: 60
Supported Codec: g711ulaw, Maximum Packetization Period: 30
Supported Codec: g711alaw, Maximum Packetization Period: 30
Supported Codec: g729ar8, Maximum Packetization Period: 60
Supported Codec: g729abr8, Maximum Packetization Period: 60
Supported Codec: rfc2833 dtmf, Maximum Packetization Period: 30
Supported Codec: rfc2833 pass-thru, Maximum Packetization Period: 30
Supported Codec: inband-dtmf to rfc2833 conversion, Maximum Packetization Period: 30
Active Call Manager: 192.168.6.31, Port Number: 2000
TCP Link Status: CONNECTED, Profile Identifier: 1
Supported Codec: g729br8, Maximum Packetization Period: 60
SLOT DSP VERSION STATUS CHNL USE TYPE RSC_ID BRIDGE_ID PKTS_TXED PKTS_RXED
1 9 28.3.14 UP N/A FREE xcode 1 - - -
1 10 28.3.14 UP N/A FREE xcode 1 - - -
1 11 28.3.14 UP N/A FREE xcode 2 - - -
1 11 28.3.14 UP N/A FREE xcode 1 - - -
1 12 28.3.14 UP N/A FREE xcode 2 - - -
1 13 28.3.14 UP N/A FREE xcode 2 - - -
Total number of DSPFARM DSP channel(s) 20
11 Replies 11
gmgarrian
Level 4
Level 4
Is that the full SCCP config?  I'm not seeing a "maximum sessions" line on your transcoder.
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
codec g729r8
codec g729br8
maximum sessions 10
associate application SCCP
R0g22
Have you checked the Regions/codecs b/w your source and destination ? Is there a need for a transcoder ? Do you have any logs that we can look at ?
1-regions adjusted to use G711 but on cucm i cant specify whether ulaw or Alaw i do that on gateway
2- transcoder needed yes as am terminating E1s on gateway and needed for h323 trunk between avaya & cisco
3- please specify more what logs commands so i can get it
1. It's fine. Both use 64 kbps. 2. Why do you need a transcoder since you have E1's and h.323 b/w Avaya/Cisco ? DTMF mismatch/re-packetization/codec mismatches ? 3. I am still not sure how did you deduced that your issue is related to transcoders.
 I agree with Nipun Singh Raghav, how are you sure the issue is related to transcoders?
If CUCM is generating the "out of resource" message it could be because it needs a transcoder, or an MTP, MOH, etc.
check the image attached that why am saying its transcoder issue
Others are helping with the transcoder issue, but your comment about not being able to select a-law over u-law in CUCM caught my eye. What version of CUCM are you using? If you have 9.0 or later, Cisco introduced the Audio Codec Preference Lists feature, which allows you to alter the codec selection list in CUCM. Specifically, it will allow you to tell CUCM to prefer a-law over u-law which may solve your problem with the transcoder since you won't need one.
Here is a link to the 9.1 CUCM Admin Guide which addresses this feature. The information is relevant to all versions after 9 as well:
CUCM Admin Guide 9.1 - Audio Codec Preference list
i use CUCM 6.1
Vaijanath Sonvane
Please see blow post as it has some useful information related to your problem:
https://supportforums.cisco.com/t5/ip-telephony/cucm-10-5-integration-with-avaya-cm6-via-h323-intermittent-call/td-p/2979243
Also, try using SIP Trunk between CUCM and Voice Gateway and H323 between Voice Gateway and PSTN/Avaya.
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
My Avaya version only support H323
