01-10-2015 09:44 AM - edited 03-17-2019 01:32 AM
Here's the scenario, and I apologize if my terminology is wrong.
Incoming Call from PSTN via ISDN/PRI -> Translation from 4466 to ephone-hunt sequential at 1001 -> ext 1 -> ext2 -> ext3 -> ext4-> AA at 8010 -> viop dial-peer to SBC -> SBC to O365 UM service -> AA picks up -> User dials 2, nothing happens
If I translate directly from 4466 -> 8010, works perfectly. Stumped here.
I have attached the relevant bits of config (hopefully properly sanitized). ISR is a 2921 running 154-2.T1.
01-15-2015 01:44 PM
I have now noted it is not just the AA, it is any call to the SBC/VM that does not get DTMF relay. It is only when transferred through a phone. I set the front desk (4466) ext 2001 to receive night bell and set call-forward night to AA pilot and it worked perfectly.
01-28-2015 04:17 PM
I cant believe no one has any ideas. Did I post this in the wrong group?
This weekend I setup another config almost identical to this one with no issue. Same commands, same SBC, only 2 differences were a 2911 instead of 2921 and it's a different Telco.
02-05-2015 12:37 PM
This is solved. The issue with the Telco. They were sending me out of band DTMF, when changed to in band, the issue was resolved.
