Dual wireless headset solution?
ajrussell
Is anyone aware of a wireless headset solution that can be reliably used for training purposes?  Currently, we use Plantronics CS55's, but they do not support dual usage on a 7962 (or any Cisco phone for that matter).  The purpose is for training, so that a dual user's can listen and talk on a conversation.  We have a solution for wireless headsets, but this group was recently migrated from a PBX system (where these headsets worked in a dual scenario) and they are demanding it now that they have been migrated to VoIP.  I'm looking to purchase an alternative headset, if it is available.
Thanks!
ajrussell
Correction, we have a solution for wired headsets split and used in a training environment.  I'm looking for a like solution using wireless headsets.
Rob Huffman
Hi AJ,
Check out this special part specifically for Training with CS55's
http://www.headsets.com/headset/Headsets.com-Wireless-Y-Adapter/
Cheers!
Rob
I agree with Rob.
We use the OfficeRunner headset by Sennheiser and the Wireless Y adapter that Rob posted a link for.
It makes it really easy to get 2 wireless headsets on the phone for training people.
My office uses....
http://www.headsets.com/headset/officerunner-wireless-headset-system-from-sennheiser-basic-bundle/
with
Good Luck!
This is an inexpensive solution to solve your problem.
www.aiheadsets.com/464.html
