Duplicate Call Legs To A Single Number
tomy.nurhadi
Hi Anyone,
Have you ever met this problem before? It's an output from 2951 router running 15.1(2)T3 IOS. It's suppose to be just a few pstn calls, but what we have was (complete output attached):
sh call active voice compact
There are 563 call records, displaying to console may impact the performance
of the gateway it is suggested that output be redirected to flash or disk.
Do you still want to continue display to console?  [yes/no]y
<callID>  A/O FAX T<sec> Codec       type        Peer Address       IP R<ip>:<udp>
Total call-legs: 563
     30204 ANS     T0     g729r8 pre- VOIP        P62393162          0.0.0.0:0
     30276 ANS     T0     g729r8 pre- VOIP        P62393162          0.0.0.0:0
     30278 ANS     T0     g729r8 pre- VOIP        P62393162          0.0.0.0:0
     30356 ANS     T0     g729r8 pre- VOIP        P62393162          0.0.0.0:0
     30366 ANS     T0     g729r8 pre- VOIP        P62393162          0.0.0.0:0
     30380 ANS     T0     g729r8 pre- VOIP        P62393162          0.0.0.0:0
     30412 ANS     T0     g729r8 pre- VOIP        P62393162          0.0.0.0:0
     30584 ANS     T0     g729r8 pre- VOIP        P62393162          0.0.0.0:0
     30590 ANS     T0     g729r8 pre- VOIP        P62393162          0.0.0.0:0
     30594 ANS     T0     g729r8 pre- VOIP        P62393162          0.0.0.0:0
     30596 ANS     T0     g729r8 pre- VOIP        P62393162          0.0.0.0:0
     30648 ANS     T0     g729r8 pre- VOIP        P62393162          0.0.0.0:0
     30678 ANS     T0     g729r8 pre- VOIP        P62393162          0.0.0.0:0
     30706 ANS     T0     g729r8 pre- VOIP        P62393162          0.0.0.0:0
     30716 ANS     T0     g729r8 pre- VOIP        P62393162          0.0.0.0:0
     30774 ANS     T0     g729r8 pre- VOIP        P62393162          0.0.0.0:0
     30794 ANS     T0     g729r8 pre- VOIP        P62393162          0.0.0.0:0
     30812 ANS     T0     g729r8 pre- VOIP        P62393162          0.0.0.0:0
     30816 ANS     T0     g729r8 pre- VOIP        P62393162          0.0.0.0:0
     30836 ANS     T0     g729r8 pre- VOIP        P62393162          0.0.0.0:0
     30944 ANS     T0     g729r8 pre- VOIP        P62393162          0.0.0.0:0
     31058 ANS     T0     g729r8 pre- VOIP        P62393162          0.0.0.0:0
     31098 ANS     T0     g729r8 pre- VOIP        P62393162          0.0.0.0:0
     31130 ANS     T0     g729r8 pre- VOIP        P62393162          0.0.0.0:0
     31150 ANS     T0     g729r8 pre- VOIP        P62393162          0.0.0.0:0
     31243 ANS     T0     g729r8 pre- VOIP        P62393162          0.0.0.0:0
     31333 ANS     T0     g729r8 pre- VOIP        P62393162          0.0.0.0:0
     31443 ANS     T0     g729r8 pre- VOIP        P62393162          0.0.0.0:0
     31535 ANS     T0     g729r8 pre- VOIP        P62393162          0.0.0.0:0
Duplicate call legs to a single number. Appreciate if anyone can share his experience about the same issue.
Tomy
0 Replies 0
