DX650 phone & CME?
jyoopro4ia
Does CME currently support DX650?  I searched for some info and the only thing I was able to find was a documentation that only mentions certain functionality will not work when DX650 is configured under CME -
Cisco Desktop Collaboration Experience and Cisco Unified Communications Manager Express interaction
When the Cisco Desktop Collaboration Experience works with the Cisco Unified Communications Manager Express (Unified CME), the phones must go into CME mode.
When a user invokes the conference feature, the tag allows the phone to use either a local or network hardware conference bridge.
The Cisco Desktop Collaboration Experience DX600 series phones do not support the following actions in Unified CME mode:
Transfer
Supported only in the connected call transfer scenario.
Conference
Join
Supported using the Conference button.
Hold
Supported using the Hold button.
Barge
Not supported.
Direct Transfer
Not supported.
Select
Not supported.
The users cannot create conference and transfer calls across different lines.
http://www.cisco.com/en/US/docs/voice_ip_comm/cdce/dx600/admin/10_0_1/english/DX60_BK_C989350E_00_cisco-desktop-collaboration-experience-dx600_chapter_011.html
It doesn't look like latest CME 10.0 supports this model.  Can anyone confirm?  Thanks!
2 Accepted Solutions
Jaime Valencia
None of the documents show CME as a requirement or option
Minimum system requirements
The minimum system requirements for running Cisco Desktop Collaboration Experience DX650 are listed below.
  • Cisco Unified Communications Manager
    • minimum: Release 7.1(5) or higher
    • minimum: Release 8.5(1) or higher
    • recommended: Release 8.6(2) or higher
    • recommended: Release 9.1(1) or higher
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cdce/dx600/rel_notes/10_0_2/DX65_BK_C3F322F2_00_cisco-desktop-collaboration-experience-dx650.html
Provisioning and management
• Cisco Unified Communications Manager 8.6.2
• Backward compatibility with Cisco Unified Communications Manager 7.1.5 and 8.5.1 (no support for Android package [APK] provisioning in 7.1.5)
http://www.cisco.com/en/US/partner/prod/collateral/voicesw/ps6788/phones/ps12956/ps12959/data_sheet_c78-726888_ps12956_Products_Data_Sheet.html
And as you mention, it doesn't show up in the CME 10.X compatibility info, I would assume it's not supported, probably that documentation which mentions CME is for future use.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Jorge Armijo
Level 4
Level 4
Here's the CME feature history, and there is no metion of support for DX650:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeroad.html
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
Jaime Valencia
java
java
Jorge Armijo
Level 4
Level 4
Jorge Armijo
