E1 Cross Cable on VWIC2-2MFT-T1/E1
johnlloyd_13
Level 9
Level 9
hi all,
i'm going to integrate a PABX to a 2911 router and i was asked to crimp an E1 cross cable.
i don't have any cable tester and was wondering if i could use the 2 ports on the VWIC2-2MFT-T1/E1 on a spare 2811 and then just issue some show commands.
is this possible or i would need 2x separate routers with VWIC cards on it.
Aman Soi
I think you can do it and run show controllers E1 command to check whether E1 is UP or not.
for cross cable , use pins on RJ45
1 -- 4
2 -- 5
4 -- 1
5 -- 2
regds,
aman
hi aman,
thanks! let me try get a spare router and VWIC to test it out.
i'm quite a noob in this thing.
do you know any link, config template and show commands to be used?
