E1 incoming call to CUCM phone number using voice translation
nicanor00
I have CUCM 12 and ISR4000 with E1 card
I configured the incoming E1 call to be forwarded to cucm phone number 2001 and it work
voice-port 0/1/0:15
description E1 incomin going to CUCM
connection plar 2001
dial-peer voice 25 voip
description SIP-Outgoing From-GW-to-CUCM
destination-pattern .
session protocol sipv2
session target ipv4:10.10.1.12
dtmf-relay rtp-nte sip-kpml
codec g711ulaw
no vad
But Now I need to send some specific incoming call to a specifc internal CUCM number but it doesnt work
see below my configuration
voice-port 0/1/0:15
translation-profile incoming Aller
dial-peer voice 20 pots
description Incoming E1 PRI dial-peer
incoming called-number .
direct-inward-dial
port 0/1/0:15
codec g711ulaw
no vad
dial-peer voice 9 pots
direct-inward-dial
port 0/1/0:15
voice translation-rule 1
rule 1 /923685960/ /2002/
rule 2 /923685961/ /2005/
rule 3 /923685962/ /2005/
rule 4 /923685963/ /2005/
rule 5 /923685964/ /2001/
voice translation-profile Aller
translate called 1
It doesnt work
Please kindly help
Please see this document for details on voice translation rules.
Response Signature
b.winter
Have you checked the debugs, if your translations are even taking place?
What have you troubleshooted until now?
Have a look at the following debugs, or post them if you can't read them on your own:
debug voice ccapi ind 1
debug voice ccapi ind 2
debug voice ccapi ind 74
debug isdn q931
debug voice translation
The public network operator send 30 line with 30 number in the E1
I dont know the number of each of these 30 line
As i dont know the associated number on each 30 E1 channel, Is it possible to send incoming call from E1 to CUCM using the E1 line channel (1, 2 , 3 ... 30)
E1 voice gateway channel 1 to CUCM ip phone internal number 2000
E1 voice gateway channel 2 to CUCM ip phone internal number 2005
E1 voice gateway channel 3 to CUCM ip phone internal number 2006
voice-port 0/1/0:1
connection plar 2000
voice-port 0/1/0:2
connection plar 2005
voice-port 0/1/0:3
connection plar 2006
This command is the approriate to do it ?
Please advise and help
Each channel on an E1 connection does not have an individual number. With this your suggested configuration is not applicable.
If you don’t have the information about what numbers you have assigned on your circuit I would recommend you to reach out to your service provider and ask the for this information.
Response Signature
