06-17-2016 09:31 AM - edited 03-17-2019 07:17 AM
Dear Community,
I have been able to connect two branches using dial-peers:
branch 1 to branch 2
dial-peer voice 4 voip
destination-pattern 3..
session protocol sipv2
session target ipv4:192.168.16.240
dtmf-relay rtp-nte
codec g711ulaw
no vad
branch 2 to branch 1
destination-pattern 1..
session target ipv4:192.168.33.248
dtmf-relay rtp-nte
codec g711ulaw
no vad
branch 1 has the following E1 dial-peer
dial-peer voice 7 pots
corlist outgoing outgoing-call
translation-profile outgoing cucmepstn
destination-pattern 2T
port 0/1/0:15
incoming calls from PSTN to branch 2 through E1 is working,how can i make outgoing calls to PSTN work through E1 from branch 2?
Thank you all!
Solved! Go to Solution.
06-17-2016 09:47 AM
Create another voip dial peer in branch 2 and set destination pattern 9.t (e.g. 9 access code) and point it to branch 1, the branch 1 create pots dial peer and set destination pattern 9.T and point to e1 pri.
Suresh
06-17-2016 09:47 AM
Suresh
06-18-2016 04:13 AM
Hi,once again you are right indeed.
06-19-2016 10:02 PM
How can i redirect a call from one busy dial-peer to another dial-peer with a different destination-pattern but free channels in CME.In the example below dial-peer 1 is an E1 with more channels but has higher call rates(expensive),however i want dial-peer 2 to be used first(cheaper call charges) and if busy because of just that one port the call should go to dial-peer 1 automatically.How can this be done in CME.
dial peer 1
dial-peer voice 5 pots
destination-pattern 907[0-2,9].......
port 0/1/0:15
dial-peer 2
dial-peer vioce 6 pots
destination-pattern 907[3,5].......
por 0/1/0
Thank you.
