IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5439 Views
  • 14 replies
Dear Community, Am setting up inter-connectivity  between three branches. The main branch branch 1 which has E1 connection to PSTN ,branch 2 and branch 3.Only branch 1 and branch 2 have a call manager running CUCME, with MPLS connecting branch 1 and ...
isaaco001 by Level 3
  • 627 Views
  • 4 replies
Resolved! SPIAD cisco 2901
 Hi all.  I need help with how configuring voice mail and AA in my cisco spiad. If some one have one manual or any configuration for that.  I can see other configuration about CME, and  I don´t know if the configuration for cisco spiad is the same...
We just installed a PDVDM-32 and a VIC2-4FXO card into a 3845 router (2).  The FXO ports in one of the 3845 routers is registered and works fine.  However, in the second 3845 router, the FXO ports show as unknown.  The "sh ccm" command shows that the...
dtom by Level 1
  • 198 Views
  • 2 replies
I have cisco CME 8.6 on 2921 router and with current configuration I have the following class codec which case my all phone calls use g711alaw voice class codec 1 codec preference 1 g711ulaw codec preference 2 g711alaw codec preference 3 g729r8 ...
Halsser by Level 1
  • 499 Views
  • 2 replies
