09-28-2012 08:47 AM - edited 03-16-2019 01:26 PM
Hi folks....
I am trying to setup a home lab where i have a PSTN router which provides E1 connectivity to two other routers (preparing for CCIE). I have no experience in setup up an E1 connection from the PSTN side hence facing issues.... i have checked some initial configuration (INE lab), which i am using as configuration model for my lab setup and D-channel is setup using serial x/x/x:15.
I am trying to do the same but i dont get that interface enabled. Below is my configuration.... Please suggest what i can do.... to setup this lab....
version 12.4
hostname PSTN-WAN
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
clock timezone EST -5
clock summer-time EDT recurring
network-clock-participate wic 0
network-clock-participate wic 1
network-clock-participate wic 2
dot11 syslog
ip source-route
ip cef
no ip domain lookup
no ipv6 cef
frame-relay switching
isdn switch-type primary-ni
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol cisco
sip
voice class codec 1
codec preference 1 g729r8
codec preference 2 g711ulaw
voice translation-rule 1
rule 1 /^911$/ /\0/ type any unknown plan any unknown
rule 2 /^212\(3942123\)$/ /\1/ type any subscriber plan any isdn
rule 3 /^6178632683$/ /\0/ type any national plan any isdn
rule 4 /^32141891$/ /34\0/ type any international plan any isdn
rule 5 /^6745738932$/ /91\0/ type any international plan any isdn
rule 6 /^9004522138$/ /\0/ type any national plan any isdn
voice translation-rule 2
! deleting the translations to shortent the config file
voice translation-profile block-call-into-BR1
translate called 617
!. deleteing the translations profile to shorten the configuration
voice-card 0
archive
log config
hidekeys
controller E1 0/0/0
clock source internal
channel-group 0 timeslots 1-31
description ** SERIAL DATA CONNECTION TO BR1-RTR **
controller E1 0/0/1
description ** SERIAL DATA CONNECTION TO BR2-RTR **
controller E1 0/1/0
description ** SERIAL DATA CONNECTION TO HQ-RTR **
controller E1 0/1/1
channel-group 0 timeslots 1-3,16
description ** E1 VOICE CONNECTION TO BR1-RTR **
controller E1 0/2/0
description ** E1 VOICE CONNECTION TO BR2-RTR **
controller E1 0/2/1
description ** E1 VOICE CONNECTION TO HQ-RTR **
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:0
description ** E1 DATA CONNECTION TO BR1-RTR **
no ip address
encapsulation frame-relay IETF
frame-relay lmi-type ansi
frame-relay intf-type dce
frame-relay route 101 interface Serial0/1/0:0 201
interface Serial0/0/1:0
description ** E1 DATA CONNECTION TO BR2-RTR **
no ip address
frame-relay route 102 interface Serial0/1/0:0 202
description ** E1 DATA CONNECTION TO HQ-RTR **
no ip address
frame-relay route 201 interface Serial0/0/0:0 101
frame-relay route 202 interface Serial0/0/1:0 102
interface Serial0/1/1:0
no ip address
interface Serial0/2/0:0
no ip address
interface Serial0/2/1:0
no ip address
router ospf 1
router-id 10.10.100.2
log-adjacency-changes
network 10.0.0.0 0.255.255.255 area 0
ip forward-protocol nd
ip http server
no ip http secure-server
control-plane
dial-peer voice 100 pots
incoming called-number .
direct-inward-dial
num-exp 916745738932 6745738932
num-exp 1900452.... 900452....
gateway
timer receive-rtp 1200
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
login
scheduler allocate 20000 1000
end
Solved! Go to Solution.
09-28-2012 09:13 AM
If you want to use your E1 interfaces for voice calls then you need to configure them with pri-group, not channel group.
eg...
controller E1 0/0/0
pri-group timeslots 1-31
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn incoming-voice voice
The next thing is if you want to configure one end of the E1 as clock source because I see that you have set the clock to internal, then you need to make that end the network side..using the isdn protocl emulate network command...
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
09-28-2012 09:13 AM
eg...
controller E1 0/0/0
no ip address
encapsulation hdlc
09-28-2012 09:50 AM
yup found the mistake.... guess copy paste is a killer! Thanks aokanlawon
