Call Transfer from B-ACD?
Hello, is it possible to configure B-ACD in a UC560 so that a caller has the option to transfer "out" to leave a VM in a GDM?
I see no options in CCA Basic ACD to choose anything but different prompts.
We'd like to be able to let the caller press a "digit" after so long in the queue to leave a voicemail if they can no longer stay on the call.
We are seeing abaondoned calls when the queue agents are all busy.
Please advise.  Thank you, Paul
7 Replies 7
Paolo, thank you for your response, but the link references earlier CUE's.
Also, I am looking specifically for a way to add a transfer a caller out of a Call Queue.
Regards, Paul
Hi Paul - can you provide IOS (show ver) and b-cd version (show call application voice summary) details.  Also, are you using drop-through mode?
Brian
The link that I have provided shows two  methods to transfer a call directy into VM without using a DN iwit CFA.
The first method does not use CUE at all.
The second, works with any version of CUE.
Rob Huffman
Hi Paul,
Have a read of this excellent thread, I don't believe the info has
changed over time, but you may want to post up the query over
in the UC500 section of the forums to verify
https://supportforums.cisco.com/message/3088670#3088670
Cheers!
Rob
"Why not help one another on the way" - Bob Marley
Brian, here is info you asked for: (edited)
We are using drop-through mode.
------------------ show version ------------------
Cisco IOS Software, UC500 Software (UC500-ADVIPSERVICESK9-M), Version 15.1(2)T4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Tue 12-Jul-11 22:01 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)XA3, RELEASE SOFTWARE (fc1)
UC560 uptime is 3 days, 14 hours, 41 minutes
System returned to ROM by error - a Software forced crash, PC 0x802D392C at 18:19:04 EDT Fri Sep 21 2012
System restarted at 18:23:25 EDT Fri Sep 21 2012
System image file is "flash:uc500-advipservicesk9-mz.151-2.T4"
Last reload type: Normal Reload
Cisco UC560-T1E1-K9 (MPC8378) processor (revision 0x100) with 497664K/26624K bytes of memory.
Processor board ID FGL1550114J
MPC8378 CPU Rev: Part Number 0x80C4, Revision ID 0x21
122 User Licenses
4 Gigabit Ethernet interfaces
48 Serial interfaces
2 terminal lines
2 Channelized T1/PRI ports
1 Virtual Private Network (VPN) Module
4 Voice FXO interfaces
4 Voice FXS interfaces
1 Voice MoH interface
1 cisco service engine(s)
256K bytes of non-volatile configuration memory.
250880K bytes of ATA CompactFlash (Read/Write)
Device#            PID                              SN
*0              UC560-T1E1-K9         FGLXXXXXXXX
UC560#show call application voice summary
SERVICES (standalone applications):
  name                      type            description
  ipsla-responder           Tcl Script      builtin:app_test_rcvr_script.tcl
  aaservice0                Tcl Script      flash:/bacdprompts/app-b-acd-aa-3.0.0.2.tcl
  aaservice1                Tcl Script      flash:/bacdprompts/app-b-acd-aa-3.0.0.2.tcl
  CALLIndSs_SErviCe         C Script        builtin:CallIndSs_Service.C
  RetrProxy                 C Script        builtin:RetrievalProxy_Service.C
  session                   Tcl Script      builtin:app_session_script.tcl
  clid_authen_npw           Tcl Script      builtin:app_clid_authen_npw_script.tcl
  app-b-acd-aa              Tcl Script      builtin:app_b_acd_aa_script.tcl
  clid_authen_collect       Tcl Script      builtin:app_clid_authen_collect_script.tcl
  app-b-acd                 Tcl Script      builtin:app_b_acd_script.tcl
  clid_col_npw_3            Tcl Script      builtin:app_clid_col_npw_3_script.tcl
  clid_authen               Tcl Script      builtin:app_clid_authen_script.tcl
  clid_col_npw_npw          Tcl Script      builtin:app_clid_col_npw_npw_script.tcl
  TOLLFRAUD_APP             C Script        builtin:TollFraud_Service.C
  clid_authen_col_npw       Tcl Script      builtin:app_clid_authen_col_npw_script.tcl
  ipsla-testcall            Tcl Script      builtin:app_test_place_script.tcl
  bacd                      Tcl Script      flash:/bacdprompts/app-b-acd-3.0.0.2.tcl
  AFW_THIRD_PARTY_CC        C Script        builtin::Third_Party_CC_Service.C
  CTAPP                     C Script        builtin:CallTreatment_Service.C
  fax_hop_on                Tcl Script      builtin:app_fax_hop_on_script.tcl
  dsapp                     C Script        builtin:DSESS_Service.C
  Default                   C Script        builtin:Session_Service.C
  DEFAULT.C.OLD             CCAPI           Obsolete system session application
  lib_off_app               CCAPI           Libretto Offramp
  CTIAPP                    CCAPI           CTI Application
  stcapp                    CCAPI           SCCP Call Control Application
  fax_on_vfc_onramp_app     CCAPI           Fax onramp for VFC
PACKAGES:
  chinese                   C Script        builtin:package_chinese.C
  ThirdPartyCC              C Script        builtin:Third_Party_CC.C
  deviceControl             C Script        builtin:Dev_ctrlSession.C
  vxmlmodule                C Script        builtin:VxmlModule.C
  tcl20base                 C Script        builtin:tcl20base_package.C
  destination               C Script        builtin:Destination.C
  vxmlbase                  C Script        builtin:vxmlbase_package.C
  callindss                 C Script        builtin:CallIndSs.C
  spanish                   C Script        builtin:package_spanish.C
  media                     C Script        builtin:package_media.C
  medianeg                  C Script        builtin:MediaNeg.C
  appcommon                 C Script        builtin:AppCommon.C
  callsetup                 C Script        builtin:CallSetup.C
  session_xwork             C Script        builtin:Session_XWork.C
  callsnr                   C Script        builtin:CallSnr.C
  consult                   C Script        builtin:Consult.C
  callfeature               C Script        builtin:CallFeature.C
  tclmodule                 C Script        builtin:TclModule.C
  CallXfor                  C Script        builtin:CallXfor.C
  tclcore                   C Script        builtin:tclcore_package.C
  digitcollect              C Script        builtin:DigitCollect.C
  english                   C Script        builtin:package_english.C
  httpios                   C Script        builtin:package_httpios.C
  mpconf                    C Script        builtin:MPConf.C
  preempt                   C Script        builtin:Preempt.C
  Retrieval                 C Script        builtin:Retrieval.C
  MRCPV2Module              C Script        builtin:MRCPV2Module.C
  consultresp               C Script        builtin:ConsultResp.C
UC560#
Thanks Paul - my understanding (though I havent tested this) is that this version of the tcl script will support the two queue exit params in drop through mode e.g.:
param queue-exit-option1  3
param queue-exit-extension1  5000
the second greeting will say something like "press 1 to be transferred to vmail" and  5000 is a dn with a cfwdall to the cue vmail, cue is then configured with a GDM.
If drop through isnt supported you could try the solution described in the great find by Rob; the call coming in on a drop through, but transfer a second aa to present the option for transfer.
hth
Brian
