02-04-2022 03:30 AM - edited 02-04-2022 03:38 AM
Hi Good People,
Please help me to find out what exactly is the problem with my VG E1 PRI, incoming calls never reach call control. Call Control Team (Avaya) says, they never receive any logs coming from my router. However, if I check the debug output, the translation rules are correct and the ISDN status is Active as expected. Here is the debug result I mean,
VOICE-ROUTER#
002097: .Feb 4 17:37:58.614 WIB: ISDN Se3/0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x004F
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Calling Party Number i = 0x2183, '02139500555'
Plan:ISDN, Type:National
Called Party Number i = 0x80, '031298053232'
Plan:Unknown, Type:Unknown
002098: .Feb 4 17:37:58.614 WIB: //-1/5AB5BD39802F/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=
----- ccCallInfo IE subfields -----
cisco-ani=02139500555
cisco-anitype=2
cisco-aniplan=1
cisco-anipi=0
cisco-anisi=3
dest=6761124
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=-1
cisco-rdnplan=-1
cisco-rdnpi=-1
cisco-rdnsi=-1
cisco-redirectreason=-1
002099: .Feb 4 17:37:58.618 WIB: //-1/5AB5BD39802F/CCAPI/cc_api_call_setup_ind_common:
Interface=0x67148F04, Call Info(
Calling Number=02139500555(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
Called Number=6761124(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
Incoming Dial-peer=0, Progress Indication=NULL(0), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
002100: .Feb 4 17:37:58.618 WIB: //46/5AB5BD39802F/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=02139500555(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
Called Number=6761124(TON=Unknown, NPI=Unknown))
002101: .Feb 4 17:37:58.618 WIB: //46/5AB5BD39802F/CCAPI/cc_process_call_setup_ind:
Event=0x66B74A58
002102: .Feb 4 17:37:58.618 WIB: //46/5AB5BD39802F/CCAPI/ccCallSetContext:
Context=0x67BE4D14
002103: .Feb 4 17:37:58.618 WIB: //46/5AB5BD39802F/CCAPI/cc_process_call_setup_ind:
>>>>CCAPI handed cid 46 with tag 0 to app "_ManagedAppProcess_Default"
002104: .Feb 4 17:37:58.618 WIB: //46/5AB5BD39802F/CCAPI/ccCallSetupAck:
Call Id=46
002105: .Feb 4 17:37:58.618 WIB: //46/5AB5BD39802F/CCAPI/cc_api_set_transfer_info:
Transfer Number=, Transfer Reason=0x0
002106: .Feb 4 17:37:58.618 WIB: //46/5AB5BD39802F/CCAPI/ccGenerateToneInfo:
Stop Tone On Digit=TRUE, Tone=Dial Tone,
Tone Direction=Network, Params=0x0, Call Id=46
002107: .Feb 4 17:37:58.618 WIB: //46/5AB5BD39802F/CCAPI/ccSetDigitTimeouts:
Initial Digit Timeout=-1000(ms), Inter Digit Timeout=-1000(ms)
002108: .Feb 4 17:37:58.618 WIB: //46/5AB5BD39802F/CCAPI/ccSetDigitTimeouts:
Call Entry(Inter Digit Timeout=10000(ms), Initial Digit Timeout=10000(ms))
002109: .Feb 4 17:37:58.618 WIB: //46/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
(callID=0x2E, digit_event=0x1, enable=TRUE, consume=FALSE)
002110: .Feb 4 17:37:58.618 WIB: //46/5AB5BD39802F/CCAPI/ccCallReportDigits:
Enabled=TRUE, Call Id=46
002111: .Feb 4 17:37:58.618 WIB: //46/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x67148F04, callID=0x2E, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
002112: .Feb 4 17:37:58.618 WIB: //46/5AB5BD39802F/CCAPI/cc_api_call_report_digits_done:
Enabled=TRUE, Disposition=0x0, Interface=0x67148F04, Call Id=46
002113: .Feb 4 17:37:58.618 WIB: //46/5AB5BD39802F/CCAPI/cc_api_call_report_digits_done:
Call Entry(Initial Digit Timeout=10000(ms), Inter Digit Timeout=10000(ms))
002114: .Feb 4 17:37:58.618 WIB: ISDN Se3/0/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x804F
002115: .Feb 4 17:37:58.618 WIB: ISDN Se3/0/0:15 Q931: TX -> CONNECT pd = 8 callref = 0x804F
002116: .Feb 4 17:37:58.646 WIB: ISDN Se3/0/0:15 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x004F
002117: .Feb 4 17:38:08.618 WIB: //46/5AB5BD39802F/CCAPI/cc_handle_inter_digit_timer:
Generate inter-digit timeout CC_EV_CALL_DIGIT_END event
002118: .Feb 4 17:38:08.618 WIB: //46/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
(callID=0x2E, digit_event=0x0, enable=FALSE, consume=FALSE)
002119: .Feb 4 17:38:08.618 WIB: //46/5AB5BD39802F/CCAPI/ccCallReportDigits:
002120: .Feb 4 17:38:08.618 WIB: //46/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x67148F04, callID=0x2E, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
002121: .Feb 4 17:38:08.618 WIB: //46/5AB5BD39802F/CCAPI/cc_api_call_report_digits_done:
002122: .Feb 4 17:38:08.618 WIB: //46/5AB5BD39802F/CCAPI/cc_api_call_report_digits_done:
002123: .Feb 4 17:38:08.618 WIB: //46/5AB5BD39802F/CCAPI/ccCallDisconnect:
Cause Value=28, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
002124: .Feb 4 17:38:08.618 WIB: //46/5AB5BD39802F/CCAPI/ccCallDisconnect:
Cause Value=28, Call Entry(Responsed=TRUE, Cause Value=28)
002125: .Feb 4 17:38:08.618 WIB: //46/5AB5BD39802F/CCAPI/cc_api_get_transfer_info:
Transfer Number Is Null
002126: .Feb 4 17:38:08.618 WIB: //46/5AB5BD39802F/CCAPI/cc_api_call_disc_cause_update:
Cause Value=16
002127: .Feb 4 17:38:08.618 WIB: //46/5AB5BD39802F/CCAPI/cc_api_call_disc_cause_update:
Call Entry(Disconnect Cause=16)
002128: .Feb 4 17:38:34.078 WIB: ISDN Se3/0/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x004F
Cause i = 0x8090 - Normal call clearing
002129: .Feb 4 17:38:34.082 WIB: ISDN Se3/0/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x804F
002130: .Feb 4 17:38:34.110 WIB: ISDN Se3/0/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x004F
002131: .Feb 4 17:38:34.110 WIB: //46/5AB5BD39802F/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x67148F04, Tag=0x0, Call Id=46,
Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
002132: .Feb 4 17:38:34.110 WIB: //46/5AB5BD39802F/CCAPI/cc_api_call_disconnect_done:
Call Disconnect Event Sent
Please let me know if there is anything else you need to help me solve this problem.
Thanks in advance.
Mustain
Solved! Go to Solution.
02-08-2022 02:13 AM
Finally I can make an incoming call working with the configuration like this below.
dial-peer voice 100 pots
incoming called-number .
direct-inward-dial
port 3/0/0:15
dial-peer voice 400 voip
translation-profile outgoing CUCM
destination-pattern 1253336
voice-class codec 10
session target ipv4:192.168.40.17
dtmf-relay h245-alphanumeric
fax-relay ecm disable
fax rate 9600
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback cisco
ip qos dscp cs5 media
no vad
And here is the debug output for working call.
VOICE-ROUTER#
004428: .Feb 8 17:03:44.765 WIB: ISDN Se3/0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x0071
Sending Complete
Standard = CCITT
Calling Party Number i = 0x2183, '02125563000'
004429: .Feb 8 17:03:44.765 WIB: //-1/3C2C5D018051/CCAPI/cc_api_display_ie_subfields:
cisco-username=
cisco-ani=02125563000
cisco-anitype=2
cisco-aniplan=1
cisco-anipi=0
cisco-anisi=3
dest=1253336
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=-1
cisco-rdnplan=-1
cisco-rdnpi=-1
cisco-rdnsi=-1
004430: .Feb 8 17:03:44.765 WIB: //-1/3C2C5D018051/CCAPI/cc_api_call_setup_ind_common:
Calling Number=02125563000(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
Called Number=1253336(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
Incoming Dial-peer=100, Progress Indication=NULL(0), Calling IE Present=TRUE,
004431: .Feb 8 17:03:44.765 WIB: //-1/3C2C5D018051/CCAPI/ccCheckClipClir:
In: Calling Number=02125563000(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed)
004432: .Feb 8 17:03:44.765 WIB: //-1/3C2C5D018051/CCAPI/ccCheckClipClir:
Out: Calling Number=02125563000(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed)
004433: .Feb 8 17:03:44.765 WIB: //87/3C2C5D018051/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=02125563000(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
Called Number=1253336(TON=Unknown, NPI=Unknown))
004434: .Feb 8 17:03:44.769 WIB: //87/3C2C5D018051/CCAPI/cc_process_call_setup_ind:
Event=0x66B74A58
004435: .Feb 8 17:03:44.769 WIB: //87/3C2C5D018051/CCAPI/ccCallSetContext:
Context=0x67BE5974
004436: .Feb 8 17:03:44.769 WIB: //87/3C2C5D018051/CCAPI/cc_process_call_setup_ind:
>>>>CCAPI handed cid 87 with tag 100 to app "_ManagedAppProcess_Default"
004437: .Feb 8 17:03:44.769 WIB: //87/3C2C5D018051/CCAPI/ccCallProceeding:
004438: .Feb 8 17:03:44.769 WIB: //87/3C2C5D018051/CCAPI/ccCallSetupRequest:
Destination=, Calling IE Present=TRUE, Mode=0,
Outgoing Dial-peer=400, Params=0x67BE6624, Progress Indication=NULL(0)
004439: .Feb 8 17:03:44.769 WIB: //87/3C2C5D018051/CCAPI/ccCheckClipClir:
004440: .Feb 8 17:03:44.769 WIB: //87/3C2C5D018051/CCAPI/ccCheckClipClir:
004441: .Feb 8 17:03:44.769 WIB: //87/3C2C5D018051/CCAPI/ccCallSetupRequest:
Destination Pattern=1253336, Called Number=1253336, Digit Strip=FALSE
004442: .Feb 8 17:03:44.769 WIB: //87/3C2C5D018051/CCAPI/ccCallSetupRequest:
Redirect Number=, Display Info=
Account Number=, Final Destination Flag=TRUE,
Guid=3C2C5D01-87FD-11EC-8051-0017952835E0, Outgoing Dial-peer=400
004443: .Feb 8 17:03:44.769 WIB: //87/3C2C5D018051/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-username=
cisco-anitype=2
cisco-aniplan=1
cisco-anipi=0
cisco-anisi=3
dest=1253336
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=-1
cisco-rdnplan=-1
cisco-rdnpi=-1
cisco-rdnsi=-1
004444: .Feb 8 17:03:44.769 WIB: //87/3C2C5D018051/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x6654386C, Interface Type=1, Destination=, Mode=0x0,
Call Params(Calling Number=02125563000(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
Called Number=1253336(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=400, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
004445: .Feb 8 17:03:44.769 WIB: //88/3C2C5D018051/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
004446: .Feb 8 17:03:44.769 WIB: //88/3C2C5D018051/CCAPI/ccCallSetContext:
Context=0x67BE65D4
004447: .Feb 8 17:03:44.769 WIB: //87/3C2C5D018051/CCAPI/ccSaveDialpeerTag:
004448: .Feb 8 17:03:44.769 WIB: ISDN Se3/0/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x8071
004449: .Feb 8 17:03:44.825 WIB: //88/3C2C5D018051/CCAPI/cc_api_set_called_ccm_detected:
CallInfo(called ccm detected=TRUE ccmVersion 3)
004450: .Feb 8 17:03:44.825 WIB: //88/3C2C5D018051/CCAPI/cc_api_call_proceeding:
Interface=0x6654386C, Progress Indication=NULL(0)
004451: .Feb 8 17:03:44.953 WIB: //88/3C2C5D018051/CCAPI/cc_api_set_called_ccm_detected:
004452: .Feb 8 17:03:44.953 WIB: //88/3C2C5D018051/CCAPI/cc_api_set_delay_xport:
CallInfo(delay xport=TRUE)
004453: .Feb 8 17:03:44.953 WIB: //88/3C2C5D018051/CCAPI/cc_api_call_alert:
Interface=0x6654386C, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
004454: .Feb 8 17:03:44.953 WIB: //88/3C2C5D018051/CCAPI/cc_api_call_alert:
Call Entry(Retry Count=0, Responsed=TRUE)
004455: .Feb 8 17:03:44.953 WIB: //88/3C2C5D018051/CCAPI/cc_api_set_called_ccm_detected:
004456: .Feb 8 17:03:44.953 WIB: //88/3C2C5D018051/CCAPI/cc_api_call_notify:
Data Bitmask=0x7, Interface=0x6654386C, Call Id=88
004457: .Feb 8 17:03:44.957 WIB: //87/3C2C5D018051/CCAPI/ccCallAlert:
004458: .Feb 8 17:03:44.957 WIB: //87/3C2C5D018051/CCAPI/ccCallAlert:
Call Entry(Responsed=TRUE, AlertSent=TRUE)
004459: .Feb 8 17:03:44.957 WIB: //87/3C2C5D018051/CCAPI/ccGenerateToneInfo:
Stop Tone On Digit=FALSE, Tone=Ring Back,
Tone Direction=Network, Params=0x0, Call Id=87
004460: .Feb 8 17:03:44.957 WIB: ISDN Se3/0/0:15 Q931: TX -> ALERTING pd = 8 callref = 0x8071
004461: .Feb 8 17:03:44.957 WIB: //88/3C2C5D018051/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
CallInfo(ssCTreRoutingNotSupported=FALSE)
004462: .Feb 8 17:03:44.957 WIB: //88/3C2C5D018051/CCAPI/cc_api_get_ccm_detected:
CallInfo(ccm detected=TRUE)
004463: .Feb 8 17:03:44.957 WIB: //87/3C2C5D018051/CCAPI/ccCallNotify:
Data Bitmask=0x7, Call Id=87
VOICE-ROUTER#
004464: .Feb 8 17:04:04.090 WIB: //88/3C2C5D018051/CCAPI/cc_api_call_connected:
Interface=0x6654386C, Data Bitmask=0x3, Progress Indication=NULL(0),
Connection Handle=0
004465: .Feb 8 17:04:04.090 WIB: //88/3C2C5D018051/CCAPI/cc_api_call_connected:
Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
004466: .Feb 8 17:04:04.090 WIB: //88/3C2C5D018051/CCAPI/cc_api_set_called_ccm_detected:
004467: .Feb 8 17:04:04.090 WIB: //88/3C2C5D018051/CCAPI/cc_api_call_notify:
004468: .Feb 8 17:04:04.090 WIB: //87/3C2C5D018051/CCAPI/ccGenerateToneInfo:
Stop Tone On Digit=FALSE, Tone=Null,
004469: .Feb 8 17:04:04.090 WIB: //87/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
(confID=0x66FE3D38, callID1=0x57, callID2=0x58, tag=0x0)
004470: .Feb 8 17:04:04.090 WIB: //87/3C2C5D018051/CCAPI/ccConferenceCreate:
Conference Id=0x66FE3D38, Call Id1=87, Call Id2=88, Tag=0x0
004471: .Feb 8 17:04:04.090 WIB: //87/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Conference Id=0x5, Source Interface=0x67148F04, Source Call Id=87,
Destination Call Id=88, Disposition=0x0, Tag=0xFFFFFFFF
004472: .Feb 8 17:04:04.090 WIB: //88/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
004473: .Feb 8 17:04:04.090 WIB: cc_api_get_xcode_stream : 4181
004474: .Feb 8 17:04:04.090 WIB: //88/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Conference Id=0x5, Source Interface=0x6654386C, Source Call Id=88,
Destination Call Id=87, Disposition=0x0, Tag=0x0
004475: .Feb 8 17:04:04.090 WIB: //87/3C2C5D018051/CCAPI/cc_generic_bridge_done:
004476: .Feb 8 17:04:04.090 WIB: //87/3C2C5D018051/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x5, Destination Call Id=88)
004477: .Feb 8 17:04:04.090 WIB: //88/3C2C5D018051/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x5, Destination Call Id=87)
004478: .Feb 8 17:04:04.090 WIB: //87/3C2C5D018051/CCAPI/cc_api_caps_ind:
Destination Interface=0x6654386C, Destination Call Id=88, Source Call Id=87,
Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
Modem=0x0, Codec Bytes=20, Signal Type=3)
004479: .Feb 8 17:04:04.090 WIB: //87/3C2C5D018051/CCAPI/cc_api_caps_ind:
Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Playout Max=250(ms), Fax Nom=300(ms))
004480: .Feb 8 17:04:04.090 WIB: //87/3C2C5D018051/CCAPI/cc_process_notify_bridge_done:
Conference Id=0x5, Call Id1=87, Call Id2=88
004481: .Feb 8 17:04:04.090 WIB: //88/3C2C5D018051/CCAPI/cc_api_caps_ind:
Destination Interface=0x67148F04, Destination Call Id=87, Source Call Id=88,
Caps(Codec=0x1, Fax Rate=0x20, Vad=0x1,
Modem=0x0, Codec Bytes=160, Signal Type=2)
004482: .Feb 8 17:04:04.090 WIB: //88/3C2C5D018051/CCAPI/cc_api_caps_ind:
004483: .Feb 8 17:04:04.090 WIB: //88/3C2C5D018051/CCAPI/cc_api_caps_ack:
Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_9600(0x20), Vad=OFF(0x1),
Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=9391)
004484: .Feb 8 17:04:04.090 WIB: //87/3C2C5D018051/CCAPI/cc_api_caps_ack:
004485: .Feb 8 17:04:04.090 WIB: //88/3C2C5D018051/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
004486: .Feb 8 17:04:04.090 WIB: //88/3C2C5D018051/CCAPI/cc_api_get_ccm_detected:
004487: .Feb 8 17:04:04.090 WIB: //87/3C2C5D018051/CCAPI/ccCallNotify:
004488: .Feb 8 17:04:04.094 WIB: //87/3C2C5D018051/CCAPI/cc_api_voice_mode_event:
Call Id=87
004489: .Feb 8 17:04:04.094 WIB: //87/3C2C5D018051/CCAPI/cc_api_voice_mode_event:
Call Entry(Context=0x67BE5974)
004490: .Feb 8 17:04:04.094 WIB: //87/3C2C5D018051/CCAPI/ccCallConnect:
Progress Indication=NULL(0), Data Bitmask=0x3
004491: .Feb 8 17:04:04.094 WIB: //87/3C2C5D018051/CCAPI/ccCallConnect:
Call Entry(Connected=TRUE, Responsed=TRUE)
004492: .Feb 8 17:04:04.094 WIB: ISDN Se3/0/0:15 Q931: TX -> CONNECT pd = 8 callref = 0x8071
004493: .Feb 8 17:04:04.110 WIB: ISDN Se3/0/0:15 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x0071
VOICE-ROUTER#
VOICE-ROUTER#
VOICE-ROUTER#
004494: .Feb 8 17:04:36.790 WIB: //88/3C2C5D018051/CCAPI/cc_api_call_disconnected:
Cause Value=16, Interface=0x6654386C, Call Id=88
004495: .Feb 8 17:04:36.790 WIB: //88/3C2C5D018051/CCAPI/cc_api_call_disconnected:
Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
004496: .Feb 8 17:04:36.790 WIB: //88/3C2C5D018051/CCAPI/cc_api_get_transfer_info:
004497: .Feb 8 17:04:36.790 WIB: //87/3C2C5D018051/CCAPI/ccConferenceDestroy:
Conference Id=0x5, Tag=0x0
004498: .Feb 8 17:04:36.790 WIB: //87/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Destination Call Id=88, Disposition=0x0, Tag=0x0
004499: .Feb 8 17:04:36.790 WIB: //88/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
004500: .Feb 8 17:04:36.790 WIB: //87/3C2C5D018051/CCAPI/cc_generic_bridge_done:
004501: .Feb 8 17:04:36.790 WIB: //87/3C2C5D018051/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
004502: .Feb 8 17:04:36.790 WIB: //87/3C2C5D018051/CCAPI/ccCallDisconnect:
Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
004503: .Feb 8 17:04:36.790 WIB: //87/3C2C5D018051/CCAPI/cc_api_get_transfer_info:
004504: .Feb 8 17:04:36.790 WIB: //88/3C2C5D018051/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
004505: .Feb 8 17:04:36.790 WIB: //88/3C2C5D018051/CCAPI/ccCallDisconnect:
004506: .Feb 8 17:04:36.790 WIB: //88/3C2C5D018051/CCAPI/cc_api_get_transfer_info:
004507: .Feb 8 17:04:36.794 WIB: //88/3C2C5D018051/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x6654386C, Tag=0x0, Call Id=88,
004508: .Feb 8 17:04:36.794 WIB: //88/3C2C5D018051/CCAPI/cc_api_call_disconnect_done:
004509: .Feb 8 17:04:36.794 WIB: ISDN Se3/0/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x8071
004510: .Feb 8 17:04:36.830 WIB: ISDN Se3/0/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x007
I'm so happy now, hehehe
02-08-2022 03:31 AM
The reason for why DP 300 is never matched is because it is an incomplete configuration as I outlined in my prior reply. I can't help you if you don't read and act on the advice given.
02-04-2022 05:50 AM
Trying to make sense of your configuration and it's not really clear to me which dial peers you should be matching. Of course this may be me failing to understand your configuration.
In your debug I see a reference to dial peer 0 which is not normally what you want, and can cause some issues like codec mismatch. For this specific call, which inbound and outbound dial peers are you expecting to be matched, and have you confirmed that they do in fact match.
I suggest checking dial peer match first, if not already done (debug voip dialpeer inout).
If that's correct then have a look at the H323 traffic to/from the Avaya.
02-07-2022 07:55 PM
Thank you @TONY SMITH for your explanation.
I don't know why dial-peer 0 shows up, because I never configured that DP on my router. Meanwhile, I'm debugging dial-peer VoIP
VOICE-ROUTER#
002591: .Feb 8 10:46:22.005 WIB: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=02125563000, Called Number=1253336, Voice-Interface=0x67148F04,
Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
Peer Info Type=DIALPEER_INFO_SPEECH
002592: .Feb 8 10:46:22.005 WIB: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Result=NO_MATCH(-1) After All Match Rules Attempt
002593: .Feb 8 10:46:22.005 WIB: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=02125563000, Called Number=1253336, Voice-Interface=0x0,
Peer Info Type=DIALPEER_INFO_FAX
002594: .Feb 8 10:46:22.005 WIB: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
002595: .Feb 8 10:46:22.005 WIB: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
002596: .Feb 8 10:46:22.005 WIB: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
002597: .Feb 8 10:46:22.005 WIB: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
002598: .Feb 8 10:46:22.005 WIB: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
VOICE-ROUTER#
002599: .Feb 8 10:46:37.765 WIB: //-1/8D6E0CE581BE/DPM/dpAssociateIncomingPeerCore:
Calling Number=, Called Number=, Voice-Interface=0x0,
Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
002600: .Feb 8 10:46:37.765 WIB: //-1/8D6E0CE581BE/DPM/dpAssociateIncomingPeerCore:
002601: .Feb 8 10:46:40.577 WIB: //-1/8F1B221481BF/DPM/dpAssociateIncomingPeerCore:
002602: .Feb 8 10:46:40.577 WIB: //-1/8F1B221481BF/DPM/dpAssociateIncomingPeerCore:
VOICE-ROUTER#
002603: .Feb 8 10:46:48.485 WIB: //-1/93D1D04681C0/DPM/dpAssociateIncomingPeerCore:
002604: .Feb 8 10:46:48.485 WIB: //-1/93D1D04681C0/DPM/dpAssociateIncomingPeerCore:
VOICE-ROUTER#
I hope the incoming call will hit this rule,
voice-port 3/0/0:15
translation-profile incoming AVAYA_CM8
input gain 3
output attenuation -6
cptone ID
02-07-2022 10:54 PM - edited 02-07-2022 11:56 PM
Dial peer 0 is a non configurable configuration element that always exists in configuration, even if it does not show in running configuration.
About this,
voice-port 3/0/0:15
input gain 3
cptone ID
That is not a rule, it’s a port configuration. You’ll need to have a dial peer configured for explicitly matching the calls inbound from the Avaya system.
Could you please share your running configuration and explain what dial peers that you expect to be used and in what direction, inbound or outbound?
Could you also please share the output from debug voip ccapi inout for the call to the Avaya system, with an outline of who makes the call and to what number and an explanation, as detailed as you can, for what the intended call flow is?
02-08-2022 12:59 AM
Thank you for the answer, I make the other dial-peer now, and now we can't see the dial-peer 0 anymore.
dial-peer voice 300 pots
port 3/0/0:15
forward-digits all
direct-inward-dial
port 3/0/0:15
session protocol sipv2
dtmf-relay sip-notify h245-alphanumeric
no vad
and here is the debug output, the call still not working. Still confuse what wrong whit this
VOICE-ROUTER#
004388: .Feb 8 15:52:42.523 WIB: ISDN Se3/0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x006B
Sending Complete
Standard = CCITT
004389: .Feb 8 15:52:42.523 WIB: //-1/4FADD59E804B/CCAPI/cc_api_display_ie_subfields:
cisco-username=
cisco-anitype=2
cisco-aniplan=1
cisco-anipi=0
cisco-anisi=3
dest=1253336
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=-1
cisco-rdnplan=-1
cisco-rdnpi=-1
cisco-rdnsi=-1
004390: .Feb 8 15:52:42.523 WIB: //-1/4FADD59E804B/CCAPI/cc_api_call_setup_ind_common:
004391: .Feb 8 15:52:42.523 WIB: //-1/4FADD59E804B/CCAPI/ccCheckClipClir:
004392: .Feb 8 15:52:42.523 WIB: //-1/4FADD59E804B/CCAPI/ccCheckClipClir:
004393: .Feb 8 15:52:42.523 WIB: //75/4FADD59E804B/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
004394: .Feb 8 15:52:42.527 WIB: //75/4FADD59E804B/CCAPI/cc_process_call_setup_ind:
Event=0x66B74A58
004395: .Feb 8 15:52:42.527 WIB: //75/4FADD59E804B/CCAPI/ccCallSetContext:
Context=0x67BEBC74
004396: .Feb 8 15:52:42.527 WIB: //75/4FADD59E804B/CCAPI/cc_process_call_setup_ind:
>>>>CCAPI handed cid 75 with tag 100 to app "_ManagedAppProcess_Default"
004397: .Feb 8 15:52:42.527 WIB: //75/4FADD59E804B/CCAPI/ccCallProceeding:
004398: .Feb 8 15:52:42.527 WIB: //75/4FADD59E804B/CCAPI/ccCallSetupRequest:
Outgoing Dial-peer=400, Params=0x67BEC924, Progress Indication=NULL(0)
004399: .Feb 8 15:52:42.527 WIB: //75/4FADD59E804B/CCAPI/ccCheckClipClir:
004400: .Feb 8 15:52:42.527 WIB: //75/4FADD59E804B/CCAPI/ccCheckClipClir:
004401: .Feb 8 15:52:42.527 WIB: //75/4FADD59E804B/CCAPI/ccCallSetupRequest:
004402: .Feb 8 15:52:42.527 WIB: //75/4FADD59E804B/CCAPI/ccCallSetupRequest:
Guid=4FADD59E-87F3-11EC-804B-0017952835E0, Outgoing Dial-peer=400
004403: .Feb 8 15:52:42.527 WIB: //75/4FADD59E804B/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-username=
cisco-anitype=2
cisco-aniplan=1
cisco-anipi=0
cisco-anisi=3
dest=1253336
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=-1
cisco-rdnplan=-1
cisco-rdnpi=-1
cisco-rdnsi=-1
004404: .Feb 8 15:52:42.527 WIB: //75/4FADD59E804B/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x665798F0, Interface Type=3, Destination=, Mode=0x0,
004405: .Feb 8 15:52:42.527 WIB: //76/4FADD59E804B/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
004406: .Feb 8 15:52:42.527 WIB: //76/4FADD59E804B/CCAPI/ccCallSetContext:
Context=0x67BEC8D4
004407: .Feb 8 15:52:42.527 WIB: //75/4FADD59E804B/CCAPI/ccSaveDialpeerTag:
004408: .Feb 8 15:52:42.527 WIB: //76/4FADD59E804B/CCAPI/cc_api_call_proceeding:
Interface=0x665798F0, Progress Indication=NULL(0)
004409: .Feb 8 15:52:42.531 WIB: ISDN Se3/0/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x806B
004410: .Feb 8 15:53:12.628 WIB: ISDN Se3/0/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x006B
004411: .Feb 8 15:53:12.628 WIB: ISDN Se3/0/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x806B
Cause i = 0x80E0 - Mandatory information element missing
004412: .Feb 8 15:53:12.628 WIB: //75/4FADD59E804B/CCAPI/cc_api_call_disconnected:
Cause Value=31, Interface=0x67148F04, Call Id=75
004413: .Feb 8 15:53:12.628 WIB: //75/4FADD59E804B/CCAPI/cc_api_call_disconnected:
Call Entry(Responsed=FALSE, Cause Value=31, Retry Count=0)
004414: .Feb 8 15:53:12.628 WIB
02-08-2022 01:30 AM - edited 02-08-2022 03:38 AM
This configuration is incomplete or wrong.
dial-peer voice 300 pots port 3/0/0:15 forward-digits all
Missing a destination pattern. Without this the dial peer can not be used in the outbound direction.
Add this to DP 300 to make it complete.
destination-pattern <number to match> dial-peer voice 100 pots incoming called-number . direct-inward-dial port 3/0/0:15
Should not have a port as it is an inbound dial peer and that is used on outbound dial peers.
Issue this command under DP100 to remove the port.
no port 3/0/0:15
Your call is now hitting DP 100 inbound and then DP 400 outbound. AFAIKT this is the DP towards CM, so you'd do not want that to match the calls that are intended to go to the Avaya system. Have you looked at the document that I shared previously? It should explain how you should configure dial peers to work in each direction.
02-08-2022 01:52 AM
the dial-peer 300 pots never hit by the call, so I create a new DP to make the call translate to the extension of the IP Phone.
dial-peer voice 300 pots port 3/0/0:15 forward-digits all dial-peer voice 100 pots
description INBOUND-PSTN incoming called-number . direct-inward-dial
destination-pattern 1253336 >> Extension of my IP Phone
no vad
As the debug output says, to my understanding the call wall hits DP 100 and transfers the call to CUCM with DP 400, correct me if I'm wrong. Sorry, I'm very new to this technology,
02-08-2022 02:13 AM
direct-inward-dial
port 3/0/0:15
fax rate 9600
no vad
VOICE-ROUTER#
Sending Complete
Standard = CCITT
cisco-username=
cisco-anitype=2
cisco-aniplan=1
cisco-anipi=0
cisco-anisi=3
dest=1253336
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=-1
cisco-rdnplan=-1
cisco-rdnpi=-1
cisco-rdnsi=-1
Set Up Event Sent;
Event=0x66B74A58
Context=0x67BE5974
ccCallSetupRequest:
cisco-username=
cisco-anitype=2
cisco-aniplan=1
cisco-anipi=0
cisco-anisi=3
dest=1253336
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=-1
cisco-rdnplan=-1
cisco-rdnpi=-1
cisco-rdnsi=-1
Context=0x67BE65D4
VOICE-ROUTER#
Connection Handle=0
Call Id=87
VOICE-ROUTER#
VOICE-ROUTER#
VOICE-ROUTER#
02-08-2022 03:33 AM
As long as you're happy I'm happy. However the call does not live up to what you asked about in your original post. AFAIKT This call goes to a phone in CM, not to your Avaya system and that is what you asked about initially.
02-08-2022 07:58 PM
I'm using CUCM only for testing purposes, to make sure the signaling is working properly as I can't verify anything on Avaya's side due to Avaya's maintenance by another team. After that, I redirected the DP to Avaya and now incoming calls are working fine.
02-08-2022 03:31 AM
02-08-2022 03:37 AM
You are right, but I chose to remove the DP 300 and use the DP 100. I really appreciate your time @Roger Kallberg @ because you and @TONY SMITH @ I were able to find a way to solve my problem, thank you very much.
02-08-2022 01:35 AM - edited 02-08-2022 01:36 AM
Here is the breakdown of your debug.
004390: .Feb 8 15:52:42.523 WIB: //-1/4FADD59E804B/CCAPI/cc_api_call_setup_ind_common: Interface=0x67148F04, Call Info( Calling Number=02125563000(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed), Called Number=1253336(TON=Unknown, NPI=Unknown), Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Incoming Dial-peer=100, Progress Indication=NULL(0), Calling IE Present=TRUE, Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1 004398: .Feb 8 15:52:42.527 WIB: //75/4FADD59E804B/CCAPI/ccCallSetupRequest: Destination=, Calling IE Present=TRUE, Mode=0, Outgoing Dial-peer=400, Params=0x67BEC924, Progress Indication=NULL(0) 004402: .Feb 8 15:52:42.527 WIB: //75/4FADD59E804B/CCAPI/ccCallSetupRequest: Calling Number=02125563000(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed), Called Number=1253336(TON=Unknown, NPI=Unknown), Redirect Number=, Display Info= Account Number=, Final Destination Flag=TRUE, Guid=4FADD59E-87F3-11EC-804B-0017952835E0, Outgoing Dial-peer=400 004407: .Feb 8 15:52:42.527 WIB: //75/4FADD59E804B/CCAPI/ccSaveDialpeerTag: Outgoing Dial-peer=400 004412: .Feb 8 15:53:12.628 WIB: //75/4FADD59E804B/CCAPI/cc_api_call_disconnected: Cause Value=31, Interface=0x67148F04, Call Id=75
That cause value equals Normal, unspecified.
02-08-2022 01:08 AM
These debugs seem to be from different calls, which doesn't help clarity. Your first debug for example ...
002099: .Feb 4 17:37:58.618 WIB: //-1/5AB5BD39802F/CCAPI/cc_api_call_setup_ind_common: Interface=0x67148F04, Call Info( Calling Number=02139500555(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed), Called Number=6761124(TON=Unknown, NPI=Unknown),
Second debug ...
002591: .Feb 8 10:46:22.005 WIB: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore: Calling Number=02125563000, Called Number=1253336, Voice-Interface=0x67148F04, Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
So on the outbound leg it appears your first should have matched DP 60. The second call would only match the gatekeeper controlled DP 50, there's no way for us to tell if that is actually in service.
I suspect there may be a lot of obsolete configuration in this gateway. For troubleshooting purposes could you shut down every dial peer except those that you hope will be handling these calls? Quite a few are already shut down.
If some of the other DPs need to remain in service, then can you define their purposes, then we can advise whether they need a tweak or two if they're interfering.
02-08-2022 01:45 AM
I make a new DP translate the calls to the CUCM because I can't verify anything in Avaya. I delete the existing DP and then create new DP
