06-23-2015 12:38 PM - edited 03-17-2019 03:26 AM
Hello
I have an E1 and I would like to know how I can see how many digits its sending?
Thanks all.
06-23-2015 12:43 PM
Is it E-1 PRI or E-1 R2?
Could you please share the config?
06-23-2015 03:17 PM
Its a E-1 PRI
06-23-2015 03:43 PM
Just turn on debug isdn q931, it should show you the basic calling and called party info its sending to Telco switch.
If you need more details about the call use the debug voip ccapi inout as suggested by Marcelo.
-Terry
Please rate all helpful posts
06-23-2015 06:25 PM
Thanks Terry, as usual great answer (+5).
The debug isdn q931 will give you the detailed information about Calling and Called Number as well the Type and Plans for the calling/called party.
06-24-2015 07:26 PM
Thanks for the rating wilson.
06-23-2015 02:26 PM
you can use the debug voip ccapi inout and look for the dest info inside the IE subfields.
For more info, check the link: Troubleshooting and Debugging VoIP Call Basics
Note: Wilson Samuel asked an important question ... the info about what kind of E1 you are using is always important.
Hope this helps.
06-23-2015 03:23 PM
Hello Marcelo
Do you mean this
*Mar 15 22:07:20.327: cc_api_call_digit
(vdbPtr=0x81B09EFC, callID=0x58, digit=5?
06-23-2015 04:54 PM
yes, the cc_api_call_digit shows the digit by digit that the VTSP passes to CCAPI.
If you look for the callID parameter (in your example 0x58), then you will be able to find all the digits that you collect.
Hope this helps.
