E1/T1 Information
opnineopnine
Hello
I have an E1 and I would like to know how I can see how many digits its sending?
Thanks all.
8 Replies 8
Wilson Samuel
Level 7
Level 7
Is it E-1 PRI or E-1 R2?
Could you please share the config?
Its a E-1 PRI
thanks
Just turn on debug isdn q931, it should show you the basic calling and called party info its sending to Telco switch.
If you need more details about the call use the debug voip ccapi inout as suggested by Marcelo.
-Terry
Please rate all helpful posts
Thanks Terry, as usual great answer (+5).
The debug isdn q931 will give you the detailed information about Calling and Called Number as well the Type and Plans for the calling/called party.
Thanks for the rating wilson.
 you can use the debug voip ccapi inout and look for the dest info inside the IE subfields.
 For more info, check the link: Troubleshooting and Debugging VoIP Call Basics
Note: Wilson Samuel asked an important question ... the info about what kind of E1 you are using is always important.
Hope this helps.
Hello Marcelo
Do you mean this parte
*Mar 15 22:07:20.327: cc_api_call_digit
(vdbPtr=0x81B09EFC, callID=0x58, digit=5?
 yes, the cc_api_call_digit shows the digit by digit that the VTSP passes to CCAPI.
If you look for the callID parameter (in your example 0x58), then you will be able to find all the digits that you collect.
Hope this helps.
