Edit IP address on 7911
ramboza2006
When i navigate to network settings->ip address there's no edit button displayed. When i press " * * # " The "EDIT" button appears, but it's grayed (disabled). How to enable it? Thank you.
paolo bevilacqua
Set DHCP off in the same menu. You should then be able to configure IP address.
Please rate post if it helps!
ramboza2006
Sorry, found the solution myself. You should disable dhcp from the same menu before the edit button becomes enabled.
wdmutasim
In may case the 7911 getting wrong vlan , I navigated to Admin VLan and press **# and it allowed me to enter vlan
