Editing 8961 softkey.
LewisWang
Hi All,
I just got my hands on 8961. Unlike the 79 series, i am having some difficulties trying to edit the soft keys from the call manager. Any experts out there that could lend a hand? The user manual mentioned only about editing the phone templete and did not mention the softkey.
10 Replies 10
LewisWang
mod please delete this post.
There are 'almost' no mods here, posts are deleted only for serious reasons.
Even if you posted in error there is no problem at all.
Thanks for the heads up.
Still I need a solution to my question..
That is covered in the phone administration guide.
Configuring Feature Control Policies
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cuipph/9971_9951_8961/8_5/english/admin_guide/9971usr.html#wp1084005
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Hi javalenc,
I'm getting this from the hyperlink.
Forbidden File or Application
The file or application you are  trying to access may require additional entitlement or you are trying to  access a file with an invalid name. Additional entitlement levels are  granted based on a users relationship with Cisco on a per-application  basis.
I had tried this though,
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/9971_9951_8961/7_1_3/english/admin/guide/9971usr.html
it does not explain how to modify the softkey.
I tried both links and they work fine, it must be something on your end or with your browser.
Search CCO for 8961 + Administration guide, then once you find it,  go to the "Configuring Features, Templates, Services,  and Users" chapter.
You can limit the appearance of some telephony features on the  Cisco Unified IP Phone 8961, 9951, and 9971 by enabling or disabling  these features in the feature control policy configuration. When you  disable a feature in the feature control policy configuration for a  phone, you restrict the user's access to the feature and the softkeys  associated with the feature does not display on the phone.
To create a Feature Control Policy, follow these steps:
Procedure
Step 1 From Cisco Unified Communications  Manager Administration, choose Device > Device  Settings > Feature Control Policy.
The Find and List Feature Control Policy window displays.
java
If this helps, please rate
java
yenlung
Pls use the button button template to configure the features.
You could configure 4 features on the 4 feature button. 1 for dn.
HI yenlung,
I am referring the softkey, not the feature button. What I am asking is the possibility to modify softkey like the 79 series.
Hi Lewis,
The Cisco Unified IP Phone 8961, 9951, and 9971 does not use softkey templates in Cisco Unified Communications Manager administration.
Thanks!
Hi Lewis,
There is hard button on the lower right corner of the phone with an arrow pointing to a man (symbol). That hard button is a button which can be used for transfering calls.
Thanks!
