ELM (9.x) support for later versions
Clifford McGlamry
I've looked around for this, and can't locate documentation.  So, two questions:
1. If a customer has an older license manager (in this case ELM 9.1), can it support UC clusters that are later versions (such as 10.x and 11.x)?
2. Where does one find the documentation on what the license manager servers (PLM and ELM) are compatible with?  I checked the release notes and the user guide, but found nothing in either place, and no other documentation available under the license manager documents.
TIA,
Cliff
Jaime Valencia
Read here, at the bottom of the page.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/plm/11_0_1/releasenotes/CPLM_BK_PFC9D799_00_plm-rn-1101/introduction_1101.html
java
if this helps, please rate
Jaime Valencia
java
HA!  I had expected you might know the answer Jaime!
I honestly would never have thought to look for it in the version 11 documentation.  I was trying to find version 9 documentation, and the license manager stuff only goes back to version 10!
Thank you!
