EM profile not loading on phones even after EM login is successful in CUCM 10.5.2-11900-3
Cisco Guardian
When the users logs into the phone using userid and pin. It says that the login is successful but the profile doesn't appear on the phone.
Below is the log output from CUCM
2016-05-14 03:39:06,588 DEBUG [http-bio-443-exec-36] CMDatabase   - Userid being passed to the query is 576764
2016-05-14 03:39:06,592 INFO  [http-bio-443-exec-36] CMDatabase   - CMDatabase:deviceLogin: execute function DeviceLogin ('060de90e-aa56-e5c1-972f-42314852bcfb','e27526e8-8fa0-dcd1-a196-29c8ed204fb1','8b9830ae-86b5-4595-b214-a2ca82fe923d','0','0','f')
2016-05-14 03:39:06,613 ERROR [http-bio-443-exec-36] CMDatabase   - ### SQL Error[-746] - 391
2016-05-14 03:39:06,614 ERROR [http-bio-443-exec-36] DBRequestor  - DeviceLogin: Couldn't submit login request to DBL: SEP002497AXXXXX   :    391
2016-05-14 03:39:06,614 ERROR [http-bio-443-exec-36] DBRequestor   - 625: DBRequestor.login: Dev: SEP002497AXXXXX- Calling deviceLogin(060de90e-aa56-e5c1-972f-42314852bcfb, e27526e8-8fa0-dcd1-a196-29c8ed204fb1, 576764, 0, false, 0)
2016-05-14 03:39:06,614 ERROR [http-bio-443-exec-36] EMServiceServlet  - 625: LoginService: Dev: SEP002497AXXXXX- Error# 6-DB Request Error: Couldn't submit login request to DBL: 391
2016-05-14 03:39:06,614 INFO  [http-bio-443-exec-36] EMServiceServlet - 625:Request succeeded returning<response>
<failure>
<error code="6">DB Request Error: Couldn't submit login request to DBL: 391
</error>
</failure>
</response>
DB replication is looking fine
Replication is fine.
Server Time: Sat May 14 04:51:34 AEST 2016
SERVER-NAME         IP ADDRESS        (msec)    DbMon?    QUEUE    Group ID       (RTMT) & Details
CUCM1       99.133.44.103     0.512     Y/Y/Y     191      (g_15)         (2) Setup Completed
CUCM2       99.133.44.105     0.485     Y/Y/Y     382      (g_11)         (2) Setup Completed
CUCM3       99.133.44.104     0.484     Y/Y/Y     191      (g_16)         (2) Setup Completed
CUCM4       99.133.12.105     0.351     Y/Y/Y     191      (g_9)          (2) Setup Completed
CUCM5       99.133.12.104     0.384     Y/Y/Y     0        (g_19)         (2) Setup Completed
CUCM6       99.133.12.101     0.151     Y/Y/Y     0        (g_3)           (2) Setup Completed
CUCM7       99.133.44.101     0.434     Y/Y/Y     191      (g_13)         (2) Setup Completed
CUCM8       99.133.12.102     0.320     Y/Y/Y     191      (g_4)          (2) Setup Completed
CUCM9       99.133.44.102     0.582     Y/Y/Y     191      (g_14)         (2) Setup Completed
CUCM10(PUB)       99.133.12.100     0.013     Y/Y/Y     0        (g_2)           (2) Setup Completed
CUCM11     99.133.12.103     0.264     Y/Y/Y     191      (g_5)          (2) Setup Completed
7 Replies 7
Deepak Rawat
How about deleting the ITL on one of the affected phones followed by a reset and then try.
Deepak
Thanks for your reply.
Tried that.
we deleted the CTL/ITL and even did a factory reset on the phone but it didn't help. Same issue.
Is it happening with particular phone models. How about checking the same profile on different phones wherein EM is working fine
Deepak
Deepak.. Thanks for reply. We tried that but still the same issue. We are planning to reboot the cluster. Hopefully that helps.
Sure go for a cluster reboot and then take it from there. Even though the DB replication is looking good from the output you provided but there can still be inconsistencies and tables mismatch causing these kind of issues to happen.
Deepak
Please check if your CUCM Publisher is synced with NTP.
Use the following commands to verify:
utils ntp status
utils diagnose test
f.hallier
Is the device profile associated to the end user ?
