Emergency phones for factories
carl_townshend
Hi Guys
We are looking at some Emergency telephones for factory shop floor emergencies, where they can dial 2 or 3 specific numbers only.
1. Does Cisco have a solution for this?
2. Do they need to be analogue phones if they are used on the CUCM, as poe switches could lose power
Many thanks
You can use ip phones with hotline feature will be an optio
For a lift we have used 3905 with hotline so that the calls will go to emergency office when they lift the handset.
Response Signature
what do you mean by hotline? do you mean a speed dial button ?
It’s not a speed dial button. With hotline when you lift the phone will dial  configured extension.
Response Signature
PTS
Your requirement can be achieved using a customer 3rd party application for Cisco CUCM.
In the solution you will be able to configure the numbers which can be dialed out from the configured Cisco IP Phones.
For details you can write to info@parsec-tech.com
www.parsec-tech.com
