01-30-2013 12:12 AM - edited 03-16-2019 03:26 PM
HI ALL ,
Can I enable call back feature on CUCM Ver 7.1 , but I am trying to create softkey template for call back but not created soft template on cucm ver 7.1
Does this feature is support in CUCM ver 7.1 for Cisco 7940 serious IP Phones .
I am trying to enable this feature refrence to this DOC
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/7_1_2/ccmfeat/fscallbk.html#wp1026315
BR ,
SANDIPAN
01-30-2013 12:28 AM
Yes, I'm pretty sure it's supported.
Have you activated the 'Extended Functions' service on CUCM?
Do you see the softkey on the phone?
Aaron
01-30-2013 01:30 AM
Hi Aaron,
Thanks for your reply !
Could you let me know how to enable 'Extended Functions' service on CUCM.
>>No I have not seen the softkey on phone .
BR,
SANDIPAN
01-30-2013 02:29 AM
CCM Serviceability - Tools - Service Activation - select a CUCM server and activate the service.
01-30-2013 01:41 AM
Are you trying to create a softkey template? You can copy the default softkey template and edit the layout. Then under the onhook or ring out option I believe is where you will add the callback key.
01-30-2013 01:42 AM
Please reference the link below for more information.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/4_1_3/ccmfeat/fscallbk.html#wp1026308
Yosh
01-30-2013 08:34 PM
Hi All ,
I Have created a softkey Template reference to the above document but unable to see any option to change layout of this template .
After creating softkey template , there are two option one is add application & second is remove application .
Please let me know were I can edit the softkey template .
BR ,
Sandipan
01-30-2013 09:25 PM
When you open the softkey template on the right navigation bar you would drop down to the key layout and click go. From there you can edit the different connection softkeys.
Hope this helps
Yosh
01-30-2013 10:18 PM
HI Yosh ,
Thanks for your support , it has been done ..
I have one query about that , let us see user A & user B , User A is connected to other user i.e Z user , When User B is calling to user A , User B only listen rings , But there is any another Feature or option is available like that " Number is busy" insted of listing the rings .
BR ,
SANDIPAN
