06-15-2009 05:30 AM - edited 03-18-2019 10:23 AM
I have gns3 running on my laptop. I simmulated GUI on the the vg which run on the gns3. when i attempt to brouse into it, it asks for my username and password. but when i supply the information, it only display a blank page. I need help
06-15-2009 05:31 AM
Did you try to use Internet Explorer?
06-15-2009 05:43 AM
Yes, it is internet explorer that i'm using.
06-15-2009 11:29 PM
Contributions please !!!!!
06-16-2009 01:41 AM
Did you copy all the GUI files into flash on the GNS3 Simulated router?
Also are you browsing to http://
If you are not using the URL above, it will try to default to the HTTP configuration page of the router.
Bill.
