Showing results forĀ
Search instead forĀ
Did you mean:Ā
Ephone-dn as a single line possible in CME?
rdossouvi
Is there a way to configure ephone-dn as a single line in CME? it looks like the default is dual line...
Basically user  wants the second incoming call to go directly to the VM while on the line...
tobin hawkshaw
its a single line with two channels, put the 'huntstop channel' command under the dn
please rate helpful posts
6 Replies 6
tobin hawkshaw
Works perfect - Thanks a lot for the input.
This option is perfect.
Lavanya
If the e-hone-dn command has no dual-line or octo-line , it should be only one ???
check the command link :
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/command/reference/cme_e1ht.html#wp1046376
Ephone-dns are created in single-line mode if the dual-line or octo-line keyword is not used.
Amer
tried the following for testing purpose and call went directly to vm.
ephone-dn  48
number xxxx
label - Admin - xxxx
name Admin
allow watch
call-forward busy 8000
call-forward noan 8000 timeout 20
corlist incoming user-international
hold-alert 30 originator
What is the config for the ephone?
