07-21-2011 12:35 AM - edited 03-16-2019 06:03 AM
I have been receiving this particular error code for extension mobility .After checking this code it tells that
Cannot connect to EM Service
LOGIN_SERVICE_CONN_ERROR—Unable to connect with EMService
The solution given by cisco is that restart EM service .I had done that,even I restarted the server .Nothing works
I triple checked the configurations and they are right .I am using CUCM version 8.0(3) .
07-21-2011 12:43 AM
R u using DNS name or IP?
Are you sure that the check box under the deivce->phone for enable extension mobility is checked ?
Amer
07-21-2011 04:10 AM
am using ip address
yes i have ticked the Extension mobility option under phone settings
07-21-2011 04:24 AM
Was this working before or are configuring EM for the 1st time?
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
07-21-2011 05:41 AM
This link was really helpful ,has opened a case
Thanks javalenc
07-21-2011 05:51 AM
I put that link in every reply I make here, it doesn't mean that anyone can open a case.
Does your company hold valid credentials to open a case with us???
The same link explains what entitlement you need to access our services, a- be a partner and b- hold at least one of these:
After looking at your CCO it appears your company is not entitled which means we'll have to deny you the service.
The engineer who takes ownership of the case will verify this and will let you know.
java
07-21-2011 01:04 PM
What model phone are you using? With CUCM 8.0 your phone likely is going to be accessing extension mobility using the HTTPS URL, probably
https://x.x.x.x:8443/emapp/EMAppServlet?device=#DEVICENAME#&EMCC=#EMCC# or
Try and put this URL into your browser (also try the HTTP with port 8080) but substitute your device name to see if the server responds to the request. If you see something that looks weird in your browser look at the page source and you'll see what should be passed to the phone (the login screen).
08-02-2011 04:13 AM
no still its not working
08-02-2011 05:20 AM
What did you see when you tried the URL in your browser?
