01-21-2013 01:18 AM - edited 03-16-2019 03:16 PM
Dear ALL,
I am getting following error while searching phones we are running with cucm version 6.1.5.
Error occurred during find. java.sql.SQLException: Could not do a physical-order read to fetch next row.
01-21-2013 01:44 AM
Hi Shahnawaz,
This is more than likely a dbreplication problem. Please ensure replication is fine on your CUCM cluster.
Harmit.
01-21-2013 11:31 PM
HI Harmit,
DBreplication is fine even its 2 for all the servers, i have also reboot the cluster still the same problem.
waiting for your reply.
thanks
01-21-2013 11:47 PM
Are you entering any search criteria?
If not, try setting Phone Model to 'contains' and a type you have on your cluster, e.g. 7941 or whaveter. If you are setting criteria, then try leaving it blank.
I've had a look at the Bug DB and there are lots of bugs relating to this type of issue; I would suggest you open a TAC case to work out which bug it is and what can be done.
Aaron
01-22-2013 12:14 AM
Hi Shahnawaz,
I agree with Aaron. This does sound like a defect. Also, even though your dbreplication status shows as 2, there shoudl be tables which are out of sync. I am still suspecting the DB but it could be some other defect as well for which we would need to look at logs. Please go ahead and open a TAC case to narrow this down.
Harmit.
