10-01-2015 06:05 AM - edited 03-17-2019 04:26 AM
when I press on the directory button on sip phone 7821 appears error xml. why ?
Solved! Go to Solution.
10-01-2015 06:28 AM
Hi Faisal,
It may be related to this bug;
Symptom:
XML error while accessing EM , Corporate directory on 78XX phones due to missing /mnt/flash2 partition.
Conditions:
Working Phone: rwfs1 (/mnt/flash) AND ubi2:rwfs2 (/mnt/flash2) : have no memory leakage
Problematic Phone : ubi1:rwfs1 (/mnt/flash) has memory problem and var/volatile goes 100 %.
SSH to the phone:
show disk
Filesystem 1K-blocks Used Available Use% Mounted on
ubi0:rootfs 65944 31008 34936 47% /
none 1024 44 980 4% /dev
tmpfs 16384 16384 0 100% /var/volatile
tmpfs 61780 0 61780 0% /dev/shm
ubi1:rwfs1 8600 1140 6984 14% /mnt/flash
Workaround:
Factory reset on problematic phones have bring them back with 2 partitions on some of the phones. This step may not resolve the issue for all phones.
Further Problem Description:
Note:
Please find defect CSCur49750, if the ip phone is not able to mount the the /mnt/flash2 partition even after upgrading to sip78XX.10-2-1ES1
Known Affected Releases: | (4) |
Known Fixed Releases: | (3) |
10-01-2015 06:28 AM
Is it only on this one phone?
What system are you using, CUCM, CME?
10-01-2015 06:29 AM
I have CME but i have one phone 7821
10-01-2015 11:22 AM
Check the workaround of the bug suggest by Rob. If didn't work, can you share the output of debug http packet and the config of voice register global
10-01-2015 06:28 AM
Hi Faisal,
Symptom:
Conditions:
SSH to the phone:
show disk
Workaround:
Note:
