Call Manager 8.6 Apache Version
milkboy33
Hi All,
Does anyone know if Apache is the web server that runs on Call Manager 8.6 and if so what version of Apache is running?
Also if someone knows where can one get a link to this "documentation"?
Tom
Terry Cheema
The below document shows the open source used in CUCM 8.6 (2)
Ref: http://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/cucm/os_license/CUCM_862asu2.pdf
According to this doc the tomcat version is
You can also verify it from the CLI of the CUCM by running the command "show tech version" and search for tomcat, below is the output from a 8.5:
tomcat                                 6.0.20(1)  <<
-Terry
Please rate all helpful posts
Terry Cheema
tomcat                                 6.0.20(1)  <<
-Terry
Adding one more option to the good stuff by Terry [+5], you can use the following command as well ( output from a 10.x server ) :
admin:show packages active tomcat
Active Side Package(s): for tomcat package(s)
platform-tomcat-1.0.0.0-1.i386
cm-tomcatstats-0.0.0.1-0.i386
tomcat-7.0.53-0.i386
cm-cmtomcat-1.1.0.0-1.i386
Manish
+5 Manish for sharing additional information
-Terry
You guys rock. Thanks.
