10-12-2020 11:17 AM
We have a few new models we added to CM. They do not want to register, but I can web access into them. All IP, DHCP, TFTP looks fine. However, they do all display the same error in the debug display logs on the phone:
System version: 12.5.1.12900-115 Unrestricted
Has anyone seen this before?
New models: 8811, 7832, 7821
The server is NOT in mixed-mode.
Solved! Go to Solution.
12-04-2020 08:54 AM
The solution was to move our DHCP from CUCM to a Windows server. Everything works perfectly now.
10-12-2020 11:55 AM
Can you cross-check that you are assigning the correct phone-type per device?
Could you also post logs from the phones that do not register?
George
10-12-2020 10:04 PM
can you post the error in the debug display logs on the phone
10-13-2020 06:45 AM
Here is the message, and it appears over and over again. I have double and triple checked that it's the correct phone type as well.
[11:29:18am 01/16/20] DeviceTLInfo DeviceName=SEP70C9C668DA28 IPv4Address=192.168.50.8 IPv6Address=CTL_Signature=Not InstalledCTL_TFTP_Server=N/AITL_Signature=xx xx xx xx xx xx xx xx xx ITL_TFTP_Server=CM2.domain.orgStatusCode=3
10-13-2020 07:21 AM
10-14-2020 05:18 AM - edited 10-14-2020 05:19 AM
Yes, other phones are registered. Some 7841s, 7842s, 7921, 7941, 3905. However, 8811s and 7832s do not work. , The TFTP nodes are up and running.
After some packet tracing with a TAC, we have determined that the Call Manager is not receiving any DHCP requests, but the phone is still receiving a DHCP IP. Not sure how that's possible if other phone models work.
10-14-2020 05:45 AM
so who is acting as your DHCP server. is it CUCM or another device ???
10-14-2020 06:04 AM
CUCM is acting as our DHCP server.
12-04-2020 08:54 AM
