Establishing Emergency or Power-Fail Connections on the EM-HDA-6FXO expansion module
alemunmo81
Hello Everybody
I need a help with regard to the following:
I have one EM-HDA-6FXO module installed on router Cisco 2951, and i need to establish power-fail connections in an emergency. The question is, how many analog phones can i connect on this module for use in case of an emergency??
I have understood that the answer is only one (1)  but what happens with the rest of ports FXO on the module??
Thanks in advanced.
Alexis
Rob Huffman
Hi Alexis,
There are actually 2 Power Fail connections on the EM-HDA-6FXO
During power failures or when router power is off, emergency voice connections can be made through power-fail ports on the EM-HDA-6FXO expansion module. The expansion module must be properly installed on the Cisco high-density extension module. (See the "Installing Expansion Modules on Cisco High-Density Extension Modules" section of the Cisco High-Density Analog and Digital Extension Module for Voice and Fax.)
To provide an emergency connection, connect an analog phone   using the port information listed in Table 1-3.
Note
Note:  There will not be a dial tone on port 15 or port 23 until the router is   powered down.
Table 1-3: Establishing Emergency Connections through   Cisco High-Density Extension Modules
Expansion Module Slot
Analog Phone Port
PSTN Port
EM0
Port 15 Tip/Ring
Port 13 Tip/Ring
EM1
Port 23 Tip/Ring
Port 21 Tip/Ring
http://www-tss.cisco.com/eservice/common/hardware/03cabling/router/mod3_nm_hiden_conn.html#anchor2
Cheers!
Rob
