01-25-2012 12:16 PM - edited 03-16-2019 09:12 AM
Hi, working on a situation were a nurse needs one profile when working in one department (unique extension, ect) and another profile when working in a different department. Is this possible? If so, how many roaming profiles can a user have.
Also, if that is not feasible, any other ideas? Thanks for your help!!
Solved! Go to Solution.
01-25-2012 12:18 PM
Sure, it is possible, simply create as many as you need and associate them all to the user. I don't think there is a hard number limitation.
HTH,
Chris
01-25-2012 12:18 PM
HTH,
Chris
01-25-2012 12:23 PM
Awesome, thank you. So, the user would have multiple pins to login with depending on where they were working that day?
01-25-2012 12:26 PM
No, the PIN is always the same, when you select EM service and have multiple EM profiles associated they will be presented with a menu to pick the one they want to login with.
HTH, please rate all useful posts!
Chris
01-25-2012 12:27 PM
Thank you Thank you!
01-25-2012 12:37 PM
My pleasure, please rate the post if you found the answer helpful.
Chris
