Extension Mobility
alex goshtaei
Hi All,
I am using CUCM 6.1 and trying to configure Extension Mobility. I did all steps based on Cisco documentation but when I press service button on the phone and choose Extension Mobility, nothing happen and it seems doesn't work. even there is no error message on the phone screen.
any suggestion would be very appreciated.
thanks
Alex
5 Replies 5
Jaime Valencia
try restarting EM and tomcat services
java
if this helps, please rate
java
I did that many time, but there is nothing when I press EM service on the phone.
thanks for your reply
Alex
gsidhu
Level 3
Level 3
Check that you have checked the Enable Extension mobility tick box on the Phone Configuration page (under Extension Information settings)
Check that you have configured the URL correctly, eg
http://10.179.25.52:8080/emapp/EMAppServlet?device=#DEVICENAME#
Check that the Extension Mobilty service is running.
I did all steps, I have check URL, service, phone configuration page, but still when I press that button, nothing happen.
Alex
Try unsubscribing the service for that phone, then restart the services, subscribe the phone again.
Make sure to enable the EM box on the phone configuration page.
