05-16-2013 02:05 AM - edited 03-16-2019 05:21 PM
I have installed CUCM 9 cluster and it is working fine but i dont know how to configure Extension mobility in cluster.Please give your inputs.Im not using DNS In my network.Without using DNS how we achieve Extension Mobility Failover
Solved! Go to Solution.
05-16-2013 02:16 AM
If you have no plans to use DNS, then you could create 2 (or more) Extension Mobility service entries for all phones to use. Each entry pointing to a different CUCM node, ideally setting the name different so users understand why there are two listed (i.e. Primary and Backup)
The following Cisco document covers the configuration of Extension Mobility:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/7_1_2/ccmfeat/fsem.html
Stephen Welsh
CTO
05-16-2013 02:23 AM
Hello Kiran,
You can use the IP address of the server that runs the ext mob service, not required to use the DNS name if you don't need redundancy between 2 servers. I've seen people configure 2 different services with 2 different IP addresses when they can not use DNS for whatever reason, not transparent for the end-users but it's a possibility.
See this document that will help and explains it step by step: http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080a80386.shtml
Gert
http://www.cisco.com/go/pdihelpdesk
Please rate helpful posts
05-16-2013 02:26 AM
Hi Kiran,
You can configure two EM services pointing to two different nodes in a cluster on which EM service is runnning.
Secondly, u can use Server Load balancer with a virtual IP address pointing to two real IP addresses of CUCM servers on which EM is running.
regds,
aman
05-16-2013 02:16 AM
Stephen Welsh
CTO
05-16-2013 02:19 AM
There are many resources online on how to configure EM. Please look here
http://www.youtube.com/watch?v=M50sykfNe5I
http://www.voicecerts.com/2010/06/step-by-step-guide-to-configuring.html
On EM failover/redundancy if you dont have a DNS server, then you will need a load balancer. If you dont have either then you cant configure EM failover
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
05-16-2013 02:23 AM
Hello Kiran,
Gert
05-16-2013 02:26 AM
Hi Kiran,
regds,
aman
05-16-2013 04:36 AM
Thank you all.Thanks for the help.
